Question about Belkin Data Transfer Kit (F1B024-2E) Networking Switch
Moving a Belkin Data switch F1B024-E
I'm trying to move the data switch to another computer, hooking up two printers. But when I try to print nothing happens. It's showing both printers in the printer list, but neither work. Do I need to change any settings for this?
  • 40 Answers
Re: moving a Belkin Data switch F1B024-E
It All Depends Sometimes You Have To By A Dynamic Switch Where You Can Find It At Walmart To Be Able To Run More Then One Thing Also You Might Want To Uninstall And Reinstall Your Printers Because A Containing File Could Have Gotten Corupted! Please Mark How Helpful I Was ! Thanks And I Hope This Helps!
Posted on Jan 27, 2008
0 characters
3 Points
How do you hook up a SG100D-05 Desk top switch?
Usually slot one is connected to your router and then you can connect 4 other computers to the switch.
Aug 15, 2014 | Cisco Networking Hubs & Switches
Belkin representative informed me that the Easy Transfer Cable will not work with AMD. I have two AMD processors one with Windows Vista and the other with Windows 7. Is there any way to make this...
This doesn't sound right. Data transfer doesn't have anything to do with the processor. The operating system does. I'm going to research this and find out. I thinks the representative is full of _____!
Jan 03, 2011 | Belkin Serial, Parallel, VGA, Network, USB...
Usb drive not recognised
First of all THe Belkin F5u237 is not a USB Drive. It is a USB Hub. If your running Windows XP it should see any device connected to the hub. If it dosen't see anything connected you may need to add the power supply to the hub.
Dec 14, 2010 | Belkin (F5U237) 7-Port USB Hub
Disappearing files from Hard Drives
find if you portable deviceshas any SAFETY REMOVE function, if you using hot plyg and unplyg function without firs safety remove it causes this action, same is in flash drives. because writting process is not finished when unplug and last transaction had not been writen and file allocation table has wrong data in it.
Aug 18, 2009 | Belkin Wireless USB Hub
HP printer will not print over wireless network using Belkin hub
Try turning everything off, wait a couple of seconds and then turn it back on.  Also try disabling McAffee to test.  When you go to printers and faxes on the PC, what is the status of your printer?
Apr 16, 2009 | Belkin (F5U237) 7-Port USB Hub
Connect to Konica photo copier/prtr with Belkin F1B024-E switch
if you're using a utp straight through cable, just connect your 2 pc to your switch then install supporting software to both pc.. then go to control panel then printer and faxes and find printer..
Feb 10, 2009 | Belkin Bitronics Data Switch Kit [...
Blue screen with multifunctional printers
Normally the USB hub is design to connect to the device that doesn't consume electricity like handy drive,MP3 player.So in your case the multifunctional printer, I think this one really need a direct connection to your PC,instead of going through USB hub.Try to move some other device to connect to this hub and connect your printer directly to PC..due to many restriction with printer like electricity,port,etc...
Apr 17, 2008 | Belkin Wireless USB Hub
Peripheral switch
Port 2 is problem. same way test plug computer 1 in to port2. test . if print not works confirm that port 2 is only problem . replace the switch.
Mar 05, 2008 | Belkin BLKF5U201 USB Peripheral...
Belkin Parallel AutoSwitch F1U115E
Please advise of further info. All the connected PC's are running on XP. One is not connecting to the network. Sounds like the "Local Area Network" setting needs to be set for "Automatically assign an IP". Go to the start menu, select "Run" and type in "CMD". Type "IPCONFIG" and enter. This will display your network setting and IP address. If there is no IP address, then you will enever have a connection. If the IP address is listed, it will display a unique IP address, a subnet of and the ip address of the gateway. Please respond with any further.
Jan 24, 2007 | Belkin F1U115E Parallel Switch
Belkin Data Transfer Kit (F1B024-2E) Networking Switch Logo
357 people viewed this question
Top Belkin Networking Hubs & Switches Experts
Cosma Papouis
Cosma Papouis
Ed Mac
Are you a Belkin Networking Hub and Switch Expert? Answer questions, earn points and help others
