Question about Samsung 4 Channel Dvr
View samsung sde-5001 - Samsung 4 Channel Dvr
I want to find the manuafacturer of the sde brand television
You get remote codes , if any, from the provider of your cable services.
Aug 30, 2016 | Samsung Sme-2220, Sde-3000
I bought a Samsung DVR 4 CHANNEL SDE-120/SDE-3000/SDE-3001 AND WAS TOLD THE PASSWORD IS 4321 HOWEVER IT'S NOT IS THERE ANY WAY TO RESTORE THIS DVR TO FACTORY SETTINGS YOUR MY LAST HOPE TO FIX THIS PROBLEM...
Hi Katrina, The default username is admin (case sensitive) and your default password is 4321.
How ever if not Try 0000 or 1111 or 3333 .
good luck
Marc
Feb 02, 2015 | Samsung Home Security
Samsung SDE-4002N all channel blink
Sounds like a bad VGA output. Can you try another output if it has such as HDMI?
Oct 01, 2014 | Samsung SDE-4002N 8 Channel DVR Security...
How can I view a backup video from a USB on my laptop
You cannot. You can setup on your network and use Internet Explorer to download the video via a network connection.
Sep 27, 2014 | Samsung SDE-4002N 8 Channel DVR Security...
Samsung sde 3004n help
http://www.samsungsv.com/Download/UserManual-SDE-3004-ENGLISH_Web-0210.pdf see that very usefull manul at page 28 and above
Jun 30, 2013 | Home Security
No picture,circle with slash
This means that there is no camera signal getting to the DVR. Could be a bad camera, or camera power supplies, or connection to DVR or camera.
Feb 13, 2013 | Samsung SDE-120n 4 Channel DVR System
Remote and mouse do not work on samsung sde 4001 security system
Easy fix...because you are using VGA screen ...you need to push pretty fast on your remote the following ( do this twice) fast....push. Freeze. View. Return. That should fix it. If twice oes not fix it keep doing it...it will work. Good luck.
Dec 28, 2012 | Samsung Home Security
Forgot password
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 02, 2012 | Cell Phones
Samsung sde 3004n works but can't get to menu up
i am having the same problem did you fix yours if so how. please help
May 06, 2012 | Samsung Cameras
Samsung 4 Channel Dvr Logo
26 people viewed this question
Top Samsung Home Security Experts
Heilcode
Level 1 Expert
Mike
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
