Question about Lasko 3300 Wind Machine Fan
Fan only operates in low speed ???
I cleaned fan well but when I turn it on it is lacking the power, it now only runs at a very low speed. I don't want it to start a fire or anything. Is there something I can do to fix the speed ? Thanks.
  • Rob
    Rob Apr 22, 2014
    Oh,, sorry i was thinking it was a fan on a computer for some reason. Must have mixed up questions. sorry
    New Friend:
Ours is doing the exact same thing!!! It's so frustrating! I wish I knew what was wrong with it.
Posted on Aug 05, 2015
  • 64 Answers
Maybe you cleaned the fan off well enough that it only needs to run on low because since its now able to do its job?
Posted on Apr 22, 2014
  • Rob
    Rob Jul 06, 2015
    It may only be a bad capacitor which controls the speed. But, is it worth getting repaired?
I have a 2006 buick lucerne 3.8 v6 cxl.my coolinf fans dont come on .i need to know how to change the relay and the fuse.
Your vehicle cooling fan's are controlled by three relay's , couple of fuse's an the PCM - engine computer . The engine coolant temp. sensor is a input to the PCM , when engine temp get's to 212 the PCM will turn on the cooling fans in low speed . Checking to see what the actual temp is with a scan tool an a infrared thermometer at the thermostat housing ,an looking up the specification's in a service repair manual is how to diagnose . Not guessing an replacing parts . Plus learning how the cooling fan's work .
Relay Driven Dual Cooling Fan Diagnostics Reading factory service info as to how they work also would be a good idea .
Cooling Fan Control - Two Fan System
The engine cooling fan system consists of 2 puller type electrical cooling fans and 3 fan relays. The relays are arranged in a series parallel (S/P) configuration that allows the engine control module (ECM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block. The ground path is provided at G104.
During low speed operation, the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan S/P relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the ECM supplies a ground path for the high speed fan relay and the cooling fan S/P relay through the high speed cooling fan relay control circuit. This energizes the cooling fan S/P relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time, the high speed fan relay coil is energized closing the relay contacts, and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit, to the right cooling fan. During high speed fan operation, both engine cooling fans have their own ground path. The result is a parallel circuit with both fans running at high speed.
The ECM commands the low speed cooling fans ON under the following conditions:
• Engine coolant temperature exceeds approximately 94.5°C (202°F).
• A/C refrigerant pressure exceeds 1447 kPa (210 psi).
• After the vehicle is shut OFF, if the engine coolant temperature at key-off is greater than 101°C (214°F), the low speed fans will run for a minimum of 60 seconds. After 60 seconds, if the coolant temperature drops below 101°C (214°F), the fans will shut OFF. The fans will automatically shut OFF after 3 minutes, regardless of coolant temperature.
The ECM commands the high speed fans ON under the following conditions:
• Engine coolant temperature exceeds approximately 104.25°C (220°F).
• A/C refrigerant pressure exceeds approximately 1824 kPa (265 psi).
• When certain DTCs set
At idle and very low vehicle speeds the cooling fans are only allowed to increase in speed, if required. This ensures idle stability by preventing the fans from cycling between high and low speed.
Dec 10, 2017 | Buick Cars & Trucks
How to replace coolig fan sending unit on a 2008 chevy uplander
Why ? Did you test ? Hook up a scan tool to see if the PCM/ECM - engine computer is reading coolant temp. ? Testing not guessing ? Do you even know how the system works .
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the engine control module (ECM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block.
During low speed operation, the ECM supplies the ground path for the low speed fan relay, which is Fan 1 Relay, through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from Fan 1 Fuse 29 through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the Series/Parallel relay, which is the Fan 2 Relay, and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. The ECM supplies a ground path for the high speed fan relay, which is the Fan 3 Relay, and the Series/Parallel through the high speed cooling fan relay control circuit. This energizes the Series/Parallel relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the Fan 3 Relay coil is energized, the relay contacts close to provide battery positive voltage from Fan 2 Fuse 33 on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have their own ground path. The result is a parallel circuit with both fans running at high speed.
When the request for fan activation is withdrawn, the fan may not turn OFF until the ignition switch is moved to the OFF position or the vehicle speed exceeds approximately 10 mph. This is to prevent a fan from cycling ON and OFF excessively at idle.
Feb 27, 2017 | 2008 Chevrolet Uplander
Fan is not working on 2001 Chevy Silverado 2500 truck radiator fan motor?
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block.
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan s/p relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM supplies a ground path for the high speed fan relay and the cooling fan s/p relay through the high speed cooling fan relay control circuit. This energizes the cooling fan s/p relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the high speed fan relay coil is energized closing the relay contacts and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Your best bet would be to take your vehicle to a qualified repair shop !
Aug 19, 2016 | 2001 Chevrolet Silverado 2500
Engine cold. Start engine reading says engine hot ac off. Fans run all time.
Are the fans running on low or high ?
Circuit/System Description
The engine control module (ECM) commands the fans ON in either high speed or low speed, depending on cooling requirements. In low speed, both fans are turned ON at a reduced speed. High speed has both fans turned ON at full speed.
In low speed operation, the ECM applies ground to the coil side of the fan low relay. This energizes the coil and applies voltage directly to the left cooling fan through the switch side of the fan low relay, which is fed by the fan 1 fuse. The right fan is connected in series to the left fan through the de-energized fan control relay so that both operate at low speed.
In high speed operation, the ECM applies a ground to the coil side of the fan low relay, the fan control relay , and the fan high relay. On the fan high relay, the energized coil closes the switch side of the relay and applies voltage directly to the right cooling fan through the switch side of the relay, which is fed by the fan 2 fuse. At the same time, the ECM energizes fan control relay pulling the switch side over, providing a direct path to ground for the left cooling fan, which has voltage applied through the energized fan low relay. In high speed mode, the fans are operated as a parallel circuit with full voltage applied to each.
You should have it hooked up to a scan tool that can read engine sensor data parameters . Check for DTC'S - diagnostic trouble codes etc...
Circuit/System Verification
  1. If DTCs P0480 or P0481 are set, perform those diagnostics first.
  2. Ignition ON, verify with a scan tool that the control module is not commanding fan activation.
  3. Ignition ON, observe that the fans are not activated.
Your best bet is to take it to a ASE certified repair shop !
Jan 10, 2016 | 2009 Chevrolet Silverado 1500
My car 2008 Chevy Uplander warning light came on stating A/C shut off for engine protection. My question exactly as 1posted 2011. Gauge not Reading. Fan running continuously. Doesn't seem hot.
What gauge not reading , Temperature ? you posted back in 2011 ? You did feel you should take it to the repair shop ? You need to take this to a ASE certified repair facility ! This is a complex electronically controlled cooling system , Three relay's controlled by the ECM -engine control module turn the fans on in two different speeds ! There could be DTC'S diagnostic trouble codes stored in the ECM, HVAC module , BCM !
The engine control module (ECM) commands the fans ON in high speed or low speed. In low speed, the fans are configured in series. In high speed, the fans are configured in parallel.
In low speed operation, the ECM applies ground to the coil side of the low speed fan relay, which is the Fan 1 Relay. Voltage is applied directly to the left cooling fan through the switch side of the low speed fan relay. The right fan is connected in series to the left fan through the de-energized Series/Parallel relay, which is Fan 2 Relay, so that both fans operate at low speed.
In high speed operation, the ECM applies a ground to the coil side of the low speed fan relay, the Series/Parallel relay, and the high speed fan relay, which is the Fan 3 Relay. Voltage is applied directly to the right cooling fan through the switch side of the high speed fan relay. The left cooling fan obtains voltage through the low speed fan relay and ground through the Series/Parallel relay.
When the ECM is commanding a fan relay ON, the voltage of the control circuit should be low, near 0 volts. When the ECM is commanding a fan relay OFF, the voltage of the control circuit should be high, near battery voltage.
One of the relays could be stuck on ! An for the gauge you have to have it removed an fixed , there is a stepper motor behind the gauge needle an they go bad ! Or replace the instrument cluster !
May 14, 2015 | Cars & Trucks
My ac is not working I have a Chevy Tahoe 2005 the fans won't turn on either .
Hi Maria , The A/C system wouldn't keep the fans from running but none working cooling fans will keep the A/C from working ! This is a fairly complex system if your not familiar with this sort of thing ! I will add the description from the factory service manual.
Do you have a check engine light lit ? The thing to do would have it check at the dealer or a ASE certified repair facility ! They could hook up a advanced scan tool an diagnose fairly quick ! Or you could find a wiring diagram an try testing with a volt meter yourself ! But watch yourself so you don't short out the PCM - engine computer !
May 01, 2015 | AC Cars & Trucks
2004 Venture Chevrolet minivan cooling fan circut
Are you talking about the radiator fan? How hot does the engine get in degrees F? Some makes and models, the radiator fan won't turn on till about 220 degrees F. Check for applicable trouble codes, see if any code that refers to the radiator fan circuit or coolant temp sensor? Some of the national brand auto stores will check codes for free.
Of course, as far as overheating in general, you have the thermostat--water pump and other possible issues. Are you losing coolant?
Dec 14, 2014 | Chevrolet Cars & Trucks
Kenmore over the stove microwave,model # 721.62629200,only low speed fan works on the keypad,no high speed fan.
The fan has a setting for high speed, low, and off. Fan only running at low speed.This indicates problem towards. 1) the fan motor. 2) The loose fan wiring. 3) The fan switch. IN the unit there is a motor for fan.If the motor gets weak or short. The fan will run but only at low speed.Because at high speed the motor will require more power to run.In this case motor needs to be checked and replaced. The other possibility is the fan wiring.There are two wires going from fan to motor and two going from motor to power board.If any of this wire is got loose or getting short then this will stop the fan to run in high speed.In this case the wires needs to be checked and reconnected properly. In the unit there is a switch internally.When you select the fan to high speed mode the switch goes up. when you select the fan to low speed mode the switch turns down.But if the switch is faulty or got worn out.Then it will not move properly up/down.In this case switch needs to be replaced.IN some brand models the High speed and low speed are directly controlled from front control panel.There is no switch in that models.In that case the control panel needs to be checked and replaced. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 10, 2010 | Kitchen Ranges
Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply: my cpu fan is running but at a low speed. When i t...
In my opinion you have a faulty power supply, replacing only the fan may not solve your problem. Try replacing the power supply.
May 16, 2010 | E-Machines Emachine T5026 power supply **...
I'm trying to find out how many cooling fan relays are in a 1999 Ford Taurus SE with the 3.0L Vulcan OHV engine. This model year has done away with the CCRM (Constant Control Relay Module), so the relays...
fuse #9 protects the 2 cooling fan relays.
It looks like the hgh speed cooling fan realy is in a thin box mounted sideways between the battery and fender.
It has high speed relay, autolamp relay, autolamp headlamp relay, horn relay, washer motor relay, wiper hi/lo relay, wiper park relay.
Section 03-03: Engine Cooling 1999 Taurus, Sable Workshop Manual
DESCRIPTION AND OPERATION Electrical System NOTE: With A/C ON, the cooling fan motors will run continuously. Cooling fan motors will not cycle ON and OFF with A/C clutch (2884) .
NOTE: An exception to this is when vehicle speed is over 61 km/h (38 mph) and coolant temperature is below 100°C (212°F), and A/C head pressure is below 1.71 MPA (250 psi). The cooling fan motors will then automatically shut off.
The cooling fan motors are mounted within a fan shroud (8146) behind the radiator (8005) .
Engine Cooling Fan Control CCRM Applications The PCM monitors certain parameters (such as engine coolant temperature, vehicle speed, A/C on/off status, A/C pressure, etc) to determine engine cooling fan needs. The PCM controls the fan operation through the Fan Control (FC) output (single speed fan applications) or the Low Fan Control (LFC) and High Fan Control (HFC) outputs as shown in Table 2. Although the fan control (FC), low speed fan control and high speed fan control relays are normally open relays, the FC/LFC circuit is wired through a voltage inverter inside the CCRM. The voltage inverter ensures that the PCM must turn on (ground) the FC/LFC output to turn the fan off. This is done so the cooling fan will operate in the event of an open FC/LFC circuit.
Stand-Alone Fan Control Relay Applications The PCM monitors certain parameters (such as engine coolant temperature, vehicle speed, A/C on/off status, A/C pressure, etc) to determine engine cooling fan needs. The PCM determines engine cooling fan control requirements and controls the fan operation through the Low Fan Control (LFC) and High Fan Control (HFC) outputs (Table 3).
Jun 29, 2009 | 1999 Ford Taurus
Lasko 3300 Wind Machine Fan Logo
441 people viewed this question
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
