Question about Fargo HDP5000 Thermal Printer
HPD 5000 printer is displaying an error 290 message, how do we fix it?
I have a fargo HPD 5000 and I am getting the error 91 stating the ribbon is out..i have changed and its still showing the same error. am I doing something wrong?
Hi Camille - that is indeed the error message for "ribbon out". This has a few possible causes:
1. Make sure you have the right ribbon for the printer. The standard color (YMCK) ribbon is #084051; if dual-sided, the standard YMCKK ribbon #084052; if monochrome/black print only, that is ribbon #084060.
2. Make sure the ribbon is loaded correctly. The spools are color-coded, so make sure the orange on the ribbon spool is in placed with the orange on the carrier - ditto for the blue.
3. Make sure you've changed the "ribbon", not the "film". The ribbon has orange and blue spools; the film has yellow & green spools.
4. Make sure the ribbon is loaded properly on the carrier - it goes the "long way" around the carrier, across the silver/metal rollers.
5. Try another new ribbon - they're RFID tagged, and occasionally an RFID tag is bad, missing, or corrupted.
6. Verify you have the latest printer firmware, to ensure all ribbon manufacturing site-codes (embedded in the RFID tag) are recognized as valid for your printer.
If you have continued problems, we can help with further support, including potential repairs. Good luck!
Safe-Card ID Services
Charlotte, NC USA
https://www.safecardid.com/
Feb 14, 2018 | Fargo Office Equipment & Supplies
Clean unable 5A error message Brother MFC-290... Plz Help me.
Hello, the error message your printer display is as a result of your printer's purge until it had reached it counter limit and you have to reset the printer by leaving it unplugged for at least 2 hours and then boot it back up. this will flash the memory of the machine.
Thanks
Jul 04, 2011 | Brother MFC-290C Printer
Strange message on the Message printers' monitor
try to search the error in the net and you will know the answer just put the brand and the error type of your printer
Nov 24, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Xerox phaser 6180 mfp error code 133-290
Before attempting to resolve the error 133. -290, print a copy of the configuration report on the copier / fax. Use the navigation on the front panel to access the configuration menu to get the impression. Review printing to make sure it understands the network settings. This is a protection against configuration settings being lost when you troubleshoot.
Clearing Memory reset the memory of the Xerox Phaser 6180MFP, Dell 3110cn or Dell Machine 3115cn to erase the stored contents and eliminate corrupted data. Disconnect the analog line and power cord from the printer. Wait at least 10 minutes. Then reconnect the analog line and the power cord. As the machine starts, press the "All Clear" "Stop" buttons to prevent automatic printing of the status page. Check the error display panel 133 to 290 times the machine is fully initialized.
Corrupt Adjustmen
Jun 20, 2009 | Xerox 6180MFP/N Printer
Denon DCM 5000 error code
The disc is loaded upside-down in the disc rack or the disc is dirty or scratched, try another disc and make sure the top side (label side with printing) is facing towards the back of the rack, away from you. The bottom or data side should face out towards the front of the rack. If that does not work then your laser picups inside may need cleaning. Make sure your disc is clean and now scratches.
Feb 08, 2009 | Denon DCM-5001 100-Disc CD Changer
Pixma ip500 error message 5C00 - what does it mean?
I have the same message and print haed does not move at all.
I will pay for it to be fixed next week (after Easter) and let you know the cause.
Cheer's Steve
Mar 18, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
HP Color Copier Error Code
Try turning off the device, and holding down the # and 6 keys simultaniously while turning the power back on. If that doesn't work reply back with the EXACT sequence of messages that display. I will continue to research the error code to provide a better solution.
Jan 01, 2008 | HP 290 Color Copier
Error Message sc376
I am pretty sure Sc376 is your Magenta not Cyan. try replacing your magenta developer unit and your magenta drum unit. If you buy them from a dealer you will have to buy all the colors not just magenta. Try Ebay first and search for supplies for your model.
Oct 17, 2007 | Ricoh Aficio AP3800C Laser Printer
Fargo HDP5000 Thermal Printer Logo
46 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
