Question about 3M Polygun Ii Glue Gun Adhesive Applicator
Metal to metal gluing sikaflex - 3M Polygun Ii Glue Gun Adhesive Applicator
Rearview mirror on 2004 Chevy trailblazer is loose wont stay in position, looks like a round clip has popped out to hold mirror in place
The round metal piece needs to be glued to the windshield. Specific glue is sold at any autoparts store. Once glued in place, the mirror slides onto it.
Oct 08, 2016 | 2004 Chevrolet TrailBlazer
How to attach canvas top to tailgate
if there are no connectors made into either part, use velcro strips like some outdoor winter clothes have on them..use the nonstick (smooth) part on the metal gate and the rough side onthe fabric top..these are self sticking adhesive backed but they can be glued on both places also.. good luck// velcro strips can be glued on the metal with weatherstrip adhesive and the fabric side can actually be sewed in place if desired..once its done its done too...
Jan 22, 2013 | 1996 Geo Tracker 2 Door
Can i remove glued cover from my ipad?
try to heat up the cover with a hairdryer first and peel it off from one side continuously heating it up there.:
remove-glued-cover-from-ipad-24izmgwjpqkk3mw4hcixslyy-2-0.jpg remove-glued-cover-from-ipad-24izmgwjpqkk3mw4hcixslyy-2-2.jpg same procedure here: How to Remove Bumper Stickers
Sep 06, 2012 | Apple iPad (16 GB) WiFi Tablet PC
What is the best way to remove a metal botton glued to windsheild without damaging the windsheild, the metal button was glued to the windsheild backwards, and needs to be detached so it can be reglued on...
Usually a razor blade scraper is good for removing anything from glass and won't scratch the glass. they can be bought at any hardware store.
Sep 09, 2011 | 1998 GMC Jimmy
Paddle end came off. What glue is best for gluing it back on? Silicone glue sounds good to me.
To withstand the forces, a better product to use is Sikaflex - this is a polurethane glue
May 24, 2010 | Hobie Boating
Repair the boton of a violin, need to know what type of gue is used to join the baseto the side.
If you are gluing small pieces of metal to wood, or small pieces of wood to metal, we recommend:LePage's Metal EpoxyJ-B WeldFaststeel Epoxy Putty if you have gaps to fillIf you have a large amount of surface area, we recommend:LePage's Press-Tite Contact (solvent-based)LePage's Press-Tite Green Contact Cement3M Fastbond 30-NFtip.gifClamping can make the difference between success and failure here.tip.gif Whenever you are gluing metal it's a good idea to clean it first with steel wool or sandpaper. (Rust never sleeps.)
Mar 30, 2010 | Maxam Violin
Seperate rearview mirror from plate both came off
f
Replacing the rear view mirror on a Ford Explorer is easy. The only obstacle you might encounter is fear of breaking the glued metal plate off the windshield. Do not sweat it. You can buy glues at the auto parts store to reattach the mirror to the windshield (Difficulty: Moderately Easy).
Instructions:
  1. Tap gently at the base of the mirror where it slides on over the metal plate glued to the windshield and pull upward. Some rear view mirrors have a small Allen screw that tightens the base of the rear view mirror to the metal plate. Disconnect the electrical plugs if your rear view mirror has them.
  2. Pull the rear view mirror clear of the metal plate. Clean around the metal plate glued to the windshield. If the metal plate has come off because of harsh weather or from hammering too hard at it, reattach it with glue designed for this job.
  3. Clean the area where you will be attaching the metal plate on the windshield. Apply the glue evenly on the surface of the metal plate that will go against the window. Be sure to clean and scrape off all the old glue before applying the new glue. Gently push the metal plate against the windshield in the spot you wanted it and hold tight for five minutes.
  4. Wait a day before putting the base of the mirror or replacement rear view mirror onto the metal plate. Do not force the base over the plate. Forcing it will likely dislodge it again. Press firmly until it will not slide along the grooves of the metal plate. Reconnect your electrical plugs and tighten the Allen screw if your new mirror has one. Adjust the mirror according to your safe viewing preference
Hope help with this (remember rated this help). Good luck.
Mar 12, 2010 | 1999 Ford Explorer
RELACING FACIA
Yes look to see if the metal is glued on or screwed on, if it's glued on use a safty razor plade to cut it free but I could help you more with a picture of what your working on.
Oct 05, 2009 | Compaq Presario 5000 PC Desktop
How do you remove just glass from drivers side mirror?
I don't know your vehicle. However, a few months ago one of the side mirrors was broken on our pickup truck (a Chevy Silverado). We had the glass shop put in the new mirror and they just glued the new mirror on top of the broken one.
Nov 12, 2008 | 2006 Subaru Forester
3M Polygun Ii Glue Gun Adhesive Applicator Logo
70 people viewed this question
Top 3M Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a 3M Craft and Hobby Expert? Answer questions, earn points and help others
