Question about Home
Replace blade on konig ring cutter - Home
3 Suggested Answers
SOURCE: can't find replacement cutter blade for Rival 2275
Go here
http://abtecparts.com/Rival_grinder_2275.htm
Posted on Jan 14, 2010
How do i relplace blade f4790
The old cutters simply pull straight up and will unsnap from the shaver. Replace by snapping the new blades onto the stems
Feb 15, 2015 | Health & Beauty
Can I replace the blade on my paper guillotine?
On a paper cutter with blades that slide on a track you are able to replace the blades but not on a guillotine, it appears the only solution is to buy a new one.
Sep 29, 2013 | Office Equipment & Supplies
Superior tool 37100 blade replacement
From Superior Tool Website, look up the tool, then click on "How to Use".
Blade Replacement:
1. Remove large pivot bolt and nut
2. Slide blade down through handle
3. Remove one (1) end of coil spring
4. Remove "E" clip from 1/4" pivot pin,
remove pin and blade
5. Install in reverse order
6. Torque nut until tool ratchets correctly
Mar 13, 2013 | SUPERIOR TOOL CO superior tool 37100...
Can I replace just the blade on my pizza cutter? It seems a shame to buy a new one as it really is in good condition, just the blade is blunt.
The Web Restaurant Store sells pizza cutter blades for a good price, although as the pizza cutters themselves are not expensive, you might find it just easier to buy a new one.
http://www.webstaurantstore.com/american-metalcraft-pcw-4-4-pizza-cutter-replacement-blade/69332864.html
Feb 28, 2013 | Home
Blades need sharpening or replaced. Where do I go in JHB area
Braun syncro 7526 foil and cutter blades is Braun Series 3 combi 30B foil and cutter replacement pack.
Apr 18, 2011 | Braun Syncro 7526 Electric Shaver
Took blades off to clean and oil unit and can't get the unit back together.
First when you remove the clipper blade did you notice a plastic part 1" long color gray, if you have lose this part your clipper blade not work. This is call a blade guide. Clipper blade installation, Place Plastic guide on spring,2 place cutter blade on guide,(this is the smaller blade) now hold cutter blade with two fingers now place comb blade on top of cutter blade (this is the bigger blade) replace screws while holding blades in place.
Mar 21, 2010 | Oster 76974-160 Hair Trimmer
The blades on my Braun complete 8975 are not sharp anymore.
You replace foil cutter, that braun complete 8975 replacement foil and cutter blades is braun series 3 combi 30B foil and cutter replacement pack.
Jan 30, 2009 | Braun 360° Complete 8985 Electric Shaver
UP-DR100 Error 0008 problem
Problem: The Printer does not detect the Reverse position of the cutter during initialization.
Either there is a scrap piece of paper obstructing the path of the carriage that houses the cutter blade or more than likely impact on the lower left side of the printer causing a bend in the metal that holds the Reverse switch.
This switch will trigger a sensor telling the printer that the cutter has reached the Reverse position(left side)
The grinding noise is caused by the cutter carriage rubbing on the inner side of the door panel. The door panel shifted inward and is obstructing the path of the cutter blade.
Solution:Replace the door panel and check for damage on the left side of the cutter blade path and bend the metal piece to realign the switch so that the plastic carriage makes contact when reaching the left side. Or replace the whole cutter blade assembly.
Any replacement parts can be ordered from imagingspectrum.com.
Jan 30, 2008 | Sony UP DR100 Thermal Photo Printer
Home Logo
459 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
