Question about GE Profile PFS22SBSS Bottom Freezer French Door Refrigerator
Fridge works but doesn't isn't cooling
Accidentally left the left side door open last night. Came down this morning and the fridge temp was 56 (recommended 37) and the freezer was -7 (recommended 0). Shut the door, left for the day, returned 5+ hours later to find nothing had changed.
Now compressor doesn't seem to be running at all.
In need of service?
  • GE Master
  • 4,655 Answers
I will help but you need to confirm your model number. Is your model the one listed above your post? Let me know, Sea Breeze
Posted on Jun 20, 2009
  • John Tripp
    John Tripp Jun 20, 2009
    Some things cannot wait, I assume you have called the repairman by now. If so Thank You I am pretty good with the profile and just wanted to make sure that was your model.. Sea Breeze
Kelvinator cyclic 410 Upside Down Fridge Freezer. Fridge not getting cold. Freezer is working fine.
Is the fan in freezer compartment working? Is the damper fully open to allow cold freezer air into fridge section?
Sep 23, 2017 | Refrigerators
Freezer is frosting and refrigerator is warm.
As far as your freezer frosting up, sounds like a door seal problem, run your fingers along the seam of the door seal, there should be no splits/holes in the seal.
As far as the refrigerator either there is a secondary fan motor, or there is a obstruction blocking the air movement, if the freezer has a bad seal, its suspect ice is still building up.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Jul 08, 2013 | KitchenAid KSRV22FV Side by Side...
I made chicken broth last night and didn't let it cool properly before putting the broth in the refrigerator. About 7 hours later when I woke up this morning, the refrigerator was hot and most of the...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp. The problem could be the electronic control if you have one or the mechanical linkages.
Nov 03, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Freezer temp on GE profile French door fridge was rising rapidly. I believe I did not shut the freezer door tightly after retrieving something about 9pm. Outside of freezer on sides of fridge was very...
This is by design. It should be warm. This is where the heat exchanger is located to save space.
No worries.... right now it is being over-worked until it reaches operating temp.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My son got into my fridge lastnight-left open, now won't cool
evaporator coils is probably frosted from condinsation.shut door set at normal setting and give some time.
Jul 26, 2009 | Frigidaire Freezer Refrigeration White...
We left the freezer door open all night by accident two days ago
I turned the fridge side off on mine, and left it overnight (last night!). This morning there is frozen stuff in the freezer. I think the compressor motor just needed ALOT of time to cool down b4 it would work properly again
Jan 11, 2009 | Whirlpool GC5SHEXNS Side by Side...
Vegetables in crispe are freezing
Check for blockage of the damper door which regulates airflow from the freezer into the fridge. It might have gotten some ice buildup there while the freezer door was open.
Jan 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Left the door open on my Freezer last night and now it doesnt wor
After looking at some advice from others I turned the internal dial to the OFF position, then turned it back to 6 or 7, and left it for 20 minutes, and it is now freezing again.
Jan 04, 2009 | Freezers
Left door open on freezer last night and now it wont work
turn it off for a day or two let it defrost and then turn it on. it just has frozen up the coil, or the compressor has heated up cause it was working to hard turn it of for a cople of hours to let the compressor cool
Jan 04, 2009 | Frigidaire FRT21P5A Top Freezer...
Samsung r521jlmr
The sensor on that unit is probably near the door. This happens a lot on Walk in coolers/freezers also. As long as the temp goes back down in a few minutes, the unit is ok.
Jan 29, 2008 | Samsung RM255LASH Side by Side...
GE Profile PFS22SBSS Bottom Freezer French Door Refrigerator Logo
672 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
