I need a reset code for this error.
Can you help ?
thanks
Gary
This error is idicating that the fuser motor is not turning. Rotate the green fuser knob to see if it is hard to turn. If freely turning then a gear, motor, or DC Controller board is bad. If hard to turn then try to find what is keeping it from turning. The motor Assy is behind the cover right next to the fuser knob. Good Luck.
Canon ir 6800 cn error code E000014-001 and E000072-0101
can u help ?
thank
thean
Ir3300 error000014-0000
Pl solve this error code e000014-0000
[email protected]
The fixing pressure is not possible by the fixing motor ....
Fixing motar kaha par lagati hai
Ir2520 errore e000014
My fixing web thingamobber that tells you when it is done was broken off so the printer didn't get the memo and the fixing web came through and stopped the rollers ? I replaced the web and it works again.
error code e000014-000 on canon ir 5000
error code E000014 on canon ir 2520 .
ir3300 error code E000014-0000
6570 error E00014-0000
