Question about Brother MFC-440CN InkJet Printer
Stop the junk mail!!
I receive a lot of fax junk mail and i don't want it. How can I cancel these from printing and block the junk mail???
  • 484 Answers
You can go to the government's Do Not Call web site and register that fax' number. It will not necesarily stop all junk mail, but most of it will stop, and you can then report any callers who continue to send junk mail to that phone line.
Posted on Jun 19, 2009
  • 334 Answers
You can collect them then turn in the companys. Look into local laws to see how to turn them in, junk mail on faxes is illegal.
How to erase memory in Brother 8690 MFC - it keeps printing unwanted faxes which are stored in the memory! It is junk mail and 20 pages long and I want to cancel it. When I press "Stop" and pull the power...
Try to press and hold Job Cancel button until a message Job Cancel (All) appears. Press OK to confirm.
If not working, the next is what I found in user manual:
Remove paper from the printer to stop it printing. Turn it on, if not.
Set Remote Access Code, if not already, pressing Menu, 2, 5, 2. Enter three digits - 1, 2, 3 - for example and press OK.
Dial your fax number from a telephone or another fax machine using touch tone. When your machine answers, immediately enter your Remote Access Code (these 3 digits followed by *). If you hear one long beep, machine is saying that you still have faxes in memory. Then you hear two short beeps, that mean the machine waits your command. Use the dial pad to press 9 6 3.
If you hear one long beep, fax messages have been erased from the memory.
Nov 03, 2017 | Brother Office Equipment & Supplies
Where does this junk mail come from -ie Viagra and pens e-mails. i am disgusted with them and always delete them without opening them i may cancel my yahoo e-mail account if this keeps up.
Switch to Gmail, it has a lot less junk mail than hotmail and yahoo mail. I have all three. Use Yahoo or Hotmail for your address when you might receive junk and use Gmail for friends and business connections that you know are legitimate.
Dec 13, 2010 | Yahoo Mail
My fax machine is in auto print off mode how do i switch it to auto recieve mode
Hi; Receiving to Memory Temporarily You can enable memory receiving feature temporarily. Received faxes will not be printed automatically.
  1. Press [ON/OFF] to select <AUTO PRINT OFF>.
  2. ??? The fax starts receiving documents in memory.
  3. ??? To cancel, press [ON/OFF] again.
  4. ??? When <AUTO PRINT OFF> is cancelled, received faxes will be printed automatically.
good luck
Oct 15, 2010 | Canon FAX-JX200
Cancel printing/receiving long, unwanted fax?
You should show an Icon in the task bar when printing,right click it.Then click cancel print job.You can also get there by start menu,then click printers and faxes.Then click your printer and cancel print.
Note:you can always do a print preview by clicking the little arrow(in explorer)next to the printer Icon.Then pick what pages you want to print,click apply,then print.Hope this helps?
Dec 19, 2009 | Brother MFC-7220 All-In-One Laser Printer
How can i block a junk fax number in a hp j3640 thanks in advance
Set the junk fax mode
By default, Block Junk Fax mode is turned On . If you do not subscribe to a caller ID service through your phone provider, or do not want to use this feature, you can turn off this setting.
To set the junk fax mode
Press Setup .
Press the right arrow to select Basic Fax Setup , and then press OK .
Press the right arrow to select Junk Fax Blocker Set Up .
Press the right arrow to select Block Junk Fax the press OK .
When prompted, press 1 for Yes or 2 for No .
Add numbers to the junk fax list
There are two ways to add a number to your junk list. You can select numbers from your caller ID history, or you can enter new numbers. The numbers in your junk list will be blocked if Block Junk Fax mode is set to On .
To select a number from the caller ID list
Press Setup .
Press the right arrow to select Basic Fax Setup then press OK .
Press the right arrow to select Add Number to Junk List , and then press the right arrow to select Number and then press OK .
Press the right arrow to scroll through the numbers from which you have received faxes. When the number you want to block appears, press OK to select it.
When the Select Another? prompt displays, do one of the following:
If you want to add another number to the list of junk fax numbers , press 1 to select Yes , and then repeat step 4 for each number you want to block.
If you are done , press 2 to select No .
To manually enter a number to block
Press Setup .
Press the right arrow to select Basic Fax Setup press OK .
Then press the right arrow to select Junk Fax Blocker Set Up and then press OK .
Press the right arrow to select Add Number to Junk List press OK , and then press the right arrow to select Enter Number .
Use the keypad to enter a fax number to block and then press OK . Make sure you enter the fax number as it appears on the display, and not the fax number that appears on the fax header of the received fax, as these numbers can be different.
When the Enter Another? prompt displays, do one of the following:
Remove numbers from the junk fax list
If you no longer want to block a fax number that number can be removed from the junk fax list.
To remove numbers from the junk fax list
Press Setup .
Press the right arrow to select Basic Fax Setup then press OK , and then press the right arrow again to select Junk Fax Blocker Set Up then press OK .
Press the right arrow to select Remove Number from Junk List .
Press the right arrow to scroll through the blocked numbers. When the number you want to remove displays, press OK to select it.
When the Delete Another? prompt displays, do one of the following:
If you want to remove another number from the list of junk fax numbers , press 1 to select Yes , and then repeat step 4 for each number you want to block.
If you subscribe to a caller ID service through your phone provider, you can block specific fax numbers, so the HP Fax does not print faxes received from those numbers in the future. When an incoming fax call is received, the HP Fax compares the number to the list of junk fax numbers you set up to determine if the call should be blocked. If the number matches a number in the blocked fax numbers list, the fax is not printed. (The maximum number of fax numbers you can block varies by model.)
Thank you.
Sep 17, 2009 | HP J3680 Officejet All In One Printer
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
BLOCKED CALLS
specific fax numbers so the device does not print faxes received from those numbers.
When an incoming fax call is received, the device compares the number to the list of
junk fax numbers to determine if the call should be blocked. If the number matches a
By default, Block Junk Fax mode is turned On. If you do not subscribe to a caller ID
off this setting.
▲ Some models have a Block Junk Fax button. Depending on the model you have,
Block Junk Fax button: Press the Junk Fax Blocker button, select the Block
Junk Fax option, and then select On or Off.
Color display menu: Press Setup, select Basic Fax Menu, select Junk Fax
Blocker Setup, select Block Junk Fax, and then select On or Off.
your caller ID history, or you can enter new numbers. The numbers in your junk list are
blocked if Block Junk Fax mode is set to On.
Feb 11, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Trying to cancel incoming fax on panafax uf-8000
there is a feature called junk fax that will stop all incoming faxes
Jan 08, 2009 | Panasonic PanaFax UF-8000 Laser Fax
How to clear Memory in Sharp UXP115
FIRST:1-PRESS START/MEMORY KEY IF YOU WANT TO TRANSMIT THE PAGES WHICH STORED UP TO THAT POINT IN MEMORY THE REMAINING PAGES WILL BE REJECTED FROM THE FEEDER.AFTER TANSMISSION THE MEMORY WILL BE CLEAREED.AND YOU CAN TRANSMIT THE REMAINING PAGES.YOU NEED ALSO TO TRANSMIT THE PAGE WHICH WAS BEING SCANNED WHEN THE MEMORY FILLED UP.
PRESS STOP IF YOU WANT TO CANCEL THE TRANSMISSION.
Feb 20, 2008 | Sharp UX-P115 Plain Paper Thermal transfer...
Brother MFC-440CN InkJet Printer Logo
95 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
