Question about Brother DCP-8040 Copier
How do I clear a paper jam in a Brother DCP-8040 copier?
3 Suggested Answers
  • 37 Answers
SOURCE: to get reset code for errors on brother dcp 8040
6E
Heater temperature does not go up enough.
(Slower temperature rise rate than 2°C/5
sec. is detected.)
To cancel the trouble status follows these steps:
STEP1 .Press MENU *,2,8,6,4
STEP2.The machine beeps for approx. one second and displays “MAINTENANCE" on the
LCD, indicating that it is placed in the initial stage of the maintenance mode, a mode in which
the machine is ready to accept entry from the keys.
STEP3.Now you are inside the simulation Press 01 to reset the trouble status.
STEP4.To exit the simulation press 99
Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine
exit from the maintenance mode, restoring it to the standby state.
Pressing the Stop button after entering only one digit restores the machine to the initial
stage of the maintenance mode.
If again 6E occurs try to check the halogen lamp or power supply PCB.Contact authorized technician to do this checking.
Posted on Feb 28, 2009
  • 13433 Answers
SOURCE: error: "paper jam", in brother
Hey try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 03, 2009
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured
Clean 50 is either Dirty Encoder Stripe or broken Maintenance Unit. In first case clean thoroughly the vertical Encoder Stripe and it should work. In case 2 better exchange the machine
Nov 23, 2015 | Brother Office Equipment & Supplies
Error 50 of Brother printer DCP-130C
Details of this error code are.
50,51,52,57,5A,5B,5C
5D,5E The machine does not work due to a paper jam or some sensor problem. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) If the problem still continues after clearing the paper jam, please contact Brother Customer Service from "Contact Us".
May 01, 2011 | Brother DCP 130C All-In-One InkJet Printer
What model toner for the DCP 8040
Hello
The Brother DR-510 Compatible Printer Drum ( Brother DR510 ) is used for the Brother DCP 8040 Laser Toner Printer.
For more information visit http://www.priceless-inkjet.com/cartridges.BrotherDCP8040.html or
http://www.inkcarts.com/brother-dcp-8040.html
Hope this helps, if so do rate the solution
Jan 19, 2011 | Brother DCP-8040 Copier
Continuous paper jam light
Will it turn both ways? you may have the roller on the other way around not meshing on the shaft properly. Therefore not turning, and or the clutch is doing the opposite to what it should be doing.
Oct 16, 2009 | Brother DCP-8040 Copier
Machine error 7a on brother mfc8640d
Same problem with mine! You can replace cheaper than repair!!!!!
Apr 28, 2009 | Brother DCP-8040 Copier
Paper Jammed Error
sensor might be dirty ,actuator might not be flagging or wrong paper size in properties
Apr 24, 2009 | Brother DCP-8040 Copier
Error: "paper jam", in brother dcp 8040, but not paper jam helpppppp?'
Hey try this
alternative :
Brother DCP-8040 Copier Logo
50 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
