Question about Bose Soundlink Air digital music system - Black
Bose soundlink air errors during setup
When trying to setup using the bose software direct from bose.com as soon as usb lead is connected it tells you there was an unexpected error
dunnbiker
  • 8546 Answers
SOURCE: how to connect bose 901 speakers to 5.1 setup?
The solution is simple and cheaper than you think.
The analog 5.1, 6.1, 7.1 outputs on your receiver should be active even with digital inputs that you want to hear. Your receiver turns everything it processes into analog output just before the speakers anyway so there's no loss of access to multichannel sound this way.
What I did was to buy a separate amp for the 901's and feed the Front L&R analog audio out to the EQ which is directly in front of the amp. The Active EQ is only for the 901's which don't have woofers or tweeters so Bose flattened out its final response electronically with some serious boosting at both ends. Having it in line with any other speakers would feed them a grossly over-compensated signal.
Your receiver will drive the rest of the speakers.
This is the cheapest way to have your 901's and hear them, too. Since the 901's are really efficient you don't have to buy a big amp that would heat the room. I'm using a separate Carver amp with 2x100w for mine.
Posted on Apr 13, 2009
SOURCE: Bose link AL8 connection problems
I had a similar problem, though intermittent, using my 48 with the AL8 and room-mate speakers. I kept getting a "no signal received from media centre" message on the remote in the second room.
Assuming that the batteries are ok and you don't have a hardware problem, the problem might be that the 48 is not picking up the signal from your remote control in your second room. The signal from your remote control is a radio signal that goes directly to the 48 - it doesn't communicate via the AL8 receiver. I think the orange light will only turn green once a signal is being transmitted from the transmitter unit plugged into your 48 media centre, and this won't start transmitting until the media centre gets a signal from the remote telling it to switch on.
The aerial for all the remote controls is contained in the power cable that links the 48 lifestyle unit to your VS-2 unit. Make sure that this is uncoiled and oriented vertically, as far away from other cables as possible.
If this doesn't work, you can get an antenna extender that plugs into the RC socket on the back of the lifestyle system. Again, orient this vertically. You can get these from Bose.
Is there anything in the wall that might be blocking the radio signal? Lots of metalwork for example?
If orienting the power cable from the VS-2 doesn't do the trick, I suggest that you go to a local Bose shop. (An actual Bose shop, not just an electrical or hifi store stocking Bose products). I explained my problem and the tech guy gave me an extender gratis (its basically just an FM aerial wire by the look of it). I installed it this morning and, so far, its seems to be working ok. As my unit is fairly new, he also offered to have the kit back in the shop to check it all out and, if that didn't work gave me Bose technical support number. He even offered, if all else failed, to send a guy out to my home to get it working - and I didn't even buy it from there!
Hope this helps.
Posted on May 03, 2009
  • 74 Answers
SOURCE: error code 10 during sound calibration
Please ensure that you have turned on the Accoustimass module, this can cause communication errors when calibrating. Also check that all connections are correctly plugged in as if one is not quite sat right this may give the error, just try unplugging them and plug them back in.
Posted on Dec 09, 2009
SOURCE: Bose - Custom EQ Error: 10
Hi, I have just had the same problem and the advice from BOSE was to turn everything off and disconnect the sub from the main unit, wait 10 mins and turn everything back on, making sure to turn the sub on first.
As it happens i then noticed I had connected the sub via the BOSE link speakers plug to the main unit rather than the correct "MAIN" socket. - so if you are reading this you know I am a fool! But the sound now works.
Basically BOSE confirmed the reason for error 10 is that the main unit is not detecting the sub and speakers.
Anyway, I hope my foolish mistake, helps save time and blushes for anyone reading this link.
J.
Posted on Dec 31, 2009
SOURCE: Connecting PS2 to Bose Lifestyle 18
we use the AUX for our PS2 and it works just fine and use the yellow cord into the video in on the tv, the red and white into the BOSE
Posted on Apr 12, 2010
How to Connect the Bose Soundlink Mini to my Smartphone or Tablet?
  • Put the Soundlink Mini on charge. Then go to your Bluetooth device.
  • Go to the Bluetooth app. Turn on the Bose Soundlink Mini.
  • Press the Bluetooth button on the speaker. This makes it discoverable.
  • Watch the lights on the Soundlink Mini. ...
  • Press the 'Bose mini sou' button. ...
  • Listen to your music
  • Oct 18, 2016 | Cell Phones
    My bose mini sound link will not charge
    This could be as simple as a battery. Check that with a voltage meter. If you replace it this will probably be fine.
    Jul 04, 2016 | Bose Corp Bose SoundLink Mini
    How do I know if my bose mini soundlink bluetooth speaker needs a battery?
    [PDF]Owner's guide - Bose
    worldwide.bose.com/.../soundlink_mini/.../owg_en_sou...
    Bose CorporationMini Bluetooth® Speaker. Owner's ... to charge and discharge the battery pack several times to obtain ..... the Bose® SoundLink® Mini speaker battery lasts up.
    Sep 25, 2015 | Bose® CORPORATION Bose - SoundLink Mini...
    What happened to my Bose Soundlink? what to do?
    You probably fried your Soundlink by using the wrong adapters. In general, an adapter yields the rated output at the rated current so connecting a 19V, 3A adapter instead of a 19V, 1A adapter applied much higher voltage.
    Mar 10, 2017 | Bose Soundlink Wirless Mobile Speaker...
    Bose Soundlink Mini paired to Win 7 PC but will not play audio
    For pairing your bluetooth Bose speaker to your computer you might need to update the Bose speaker software
    I have included the link to download the actual software, and the updates available. According to the page for the download, you will need to have the speaker connected to the computer with a micro USB cord.
    SoundLink Wireless Mobile speaker update
    Aug 24, 2014 | Bose Corp Bose SoundLink Mini
    Bose soundlink mini paired to PC ( Win7) but wont play audio
    I have included the link to download the actual software, and the updates available. According to the page for the download, you will need to have the speaker connected to the computer with a micro USB cord. SoundLink Wireless Mobile speaker update
    Blue tooth speaker wont turn back on.
    Unable to connect to a device?
    Before attempting any of the following steps, make sure that you are running the latest software version on your SoundLink Wireless Mobile speaker. Click here to visit the software update center and update your speaker. If you are still having difficulty connecting to a device after updating the software, continue to the troubleshooting steps.
    Unable to connect with a previously paired device?
    Please try the following to resolve this issue:
    Perform a product resetTo perform a SoundLink speaker reset, following these steps:
    1. On the speaker, press and hold Mute for 10 seconds, the LEDs will flash briefly
    2. Press Power to turn the SoundLink speaker back on
    Clear the pairing list on both the SoundLink Wireless Mobile speaker and the source
    1. On the SoundLink speaker, press and hold the Bluetooth button for approximately 10 seconds until you hear a tone. The SoundLink speaker clears all Bluetooth devices from its memory and becomes discoverable
    2. Clear the list on your Bluetooth device. For more information, please refer to the manufacturer of the device
    3. Perform a product reset. On the speaker, press and hold Mute for 10 seconds, the LEDs will flash briefly. Press Power to turn the SoundLink speaker back on
    4. Try pairing the device again by following these steps:
      1. With the Bluetooth device and the SoundLink speaker both turned on, press and hold the Bluetooth button on the speaker for three seconds to make the speaker discoverable. The Bluetooth indicator will slowly fade on and off approximately once every second to show the speaker is in discoverable mode
      2. Set your Bluetooth device to "Discoverable." This will allow your device to discover the SoundLink speaker
      3. On your device, locate the Bluetooth device list. Select "Bose SoundLink" from the list
      4. If your device asks for a passkey, enter digits 0000 and press OK. Some devices also ask you to accept the connection. Your Bluetooth device indicates when pairing is complete. The SoundLink speaker indicates pairing is complete when the Bluetooth indicator stops fading on and off and remains on
    Be sure the SoundLink speaker is within 30 feet of the Bluetooth deviceThe system is designed to operate at a range of 30 feet. However, performance can be diminished by obstacles such as walls or metal, and may also be affected by other Bluetooth devices. Try moving the SoundLink speaker closer to the Bluetooth device.
    Be sure the source's Bluetooth function is OnMany Bluetooth enabled devices have an option where the Bluetooth feature can be turned On or Off. This option may be set to Off to save the battery life of the device. Be sure this option is set to On. If the Bose product is paired to the Bluetooth enabled device, it should automatically reconnect when its Bluetooth function is turned on. If the Bose product doesn't automatically reconnect, manually select the Bose product within the Bluetooth list on the device.
    Manually connect the SoundLink speaker in the device listSome devices will pair to a device but not automatically connect. Go to the pairing list of the device and check if this is the case. If it is, try connecting to the SoundLink speaker.
    Oct 20, 2013 | Just Wireless Bluetooth Headset Wireless...
    Cant connect Macbook to Bose Soundlink Wireless Music System
    What I did to connect to BOSE wireless speaker to my MacBook air was go in advance settings and uncheck all three options there and then press the wireless button until it beeped--> then I was able to pair it to my laptop. Success!
    Jan 02, 2012 | Bose SoundLink Wireless Music System...
    My apple computer is using windows xp. the problem is my bose wireless sound system could not connect.
    have you tried other wireless divide to it. because some device connect one device at a time. do software update of bootcamp or try reloading bootcamp drivers.
    Sep 16, 2011 | Bose SoundLink Wireless Music System...
    Bose Soundlink Air digital music system - Black Logo
    Top Bose Televison & Video Experts
    George Scott
    George Scott
    Jerry Greenberg
    Jerry Greenberg
    Are you a Bose Televison and Video Expert? Answer questions, earn points and help others
