Question about Evo Pv500 Pro Dvr Digital Video Recorder Pv-500-evo 720p Hd
Pv 500 evo2 vibration noises after recording - Evo Pv500 Pro Dvr Digital Video Recorder Pv-500-evo 720p Hd
Sound noise feedback during recording
Noise can be a big problem when trying to record into a computer. Reducing and canceling out noise using several simple techniques will help increase recording quality and increase your satisfaction with recordings. Solutions range from complete room overhauls to simple changes in the placement of the microphone and other objects in the recording.
Use a stabilized microphone to reduce vibrations. Many hand-held or headset microphones will pick up on vibrations and movements from the user. These vibrations can carry over into the recording and reduce the quality of the recording. Using a microphone stand or stationary microphone will reduce noise while recording. Mic stands will help increase recording quality and off a possible solution that requires very little financial investment. Set up a designated sound room that is set away from the rest of your home. The farther the recording area is from windows and doorways, the better. Windows allow very small amounts of noise to filter in from the outdoors and create white noise in the recording. Hang blankets on the walls around the recording station and use many rough objects in the recording room. Sound travels in waves that bounce back and forth between smooth objects. Blankets and other rough objects will help reduce sound vibrations. These additions to the recording room will reduce ambient sounds from both the room and outside the building by blocking sound waves from bouncing back and forth in the room. If you can make a considerable investment in the room, there are several acoustic products on the market than help nearly eliminate echoes and outside noises. Install software that filters out unwanted sounds and echoes. Many computer applications exist that use programs to increase the quality of recordings and reduce the ambient noise levels in a recording room. Software is used to reduce echoes and feedback in a recording studio. Several free applications can be used to achieve the desired effects when recording. A program called Audacity is one of the most effective software packages that can help reduce noise in recordings. http://audacity.sourceforge.net/ Software can also be used to reduce electronic humming and other white noise that can be picked up during a recoding session. Buy a high-quality microphone with noise and echo cancellation. One of the best investments that a recording specialist can make is a high-quality mic. The microphone itself can reduce many unwanted noises and echoes in the recording room by filtering the actual sounds that are recorded.
b>
Jan 15, 2013 | Computers & Internet
Sound noise feeback during recording
b>
Jan 15, 2013 | Logitech Webcam
I get white stripe in my video or the screen become with strange colors suddenly... what's my problem?
You may be recording things that have inbuilt security. Some of the things you get on Sky or Cable have security programs built into them, so that they cannot be recorded. When you record them they either come up as a static picture, or the picture jumps around, or it has a line through it. It's usually pay per view items that have these problems.
Jul 21, 2011 | Evo Pv500 Pro Dvr Digital Video Recorder...
When in use channel b is crackling is this repairable
Yes it is repairable by competent electronic technician.
The problem MAY be very simple or hard to locate. It may be a poor solder joint. Check if vibration of the unit causes the noise.
Sep 27, 2010 | Peavey Pv 2600 Power Amplifier
I have problem with my samson g track mic. When I record my vocals I can hear backround noise on my vocals. and I dunno how to get of that 100% I need clear voice not noise on my vocals :((
The Samson G Track microphone is very sensitive. If you have it on the heavy metal base on your computer desk it will pick up the vibrations of computer fans. It's vital to get the microphone off the desk using a mike stand with a boom or invest in the G Track spider holder if you want to use the desktop stand.
You can do a test just by holding the microphone with your hand. You should get very little noise apart from the fan noise with will be very faint. That noise is much easier to remove than the vibration noise as removing the vibration noise affects how your voice sounds.
Hope this helps.
Jan 25, 2010 | Samson G-TRACK USB RECORDING MICROPHONE...
Vibration of the bike when doing 80kmph
they are right the mach 500 is a bone shaker
Feb 14, 2009 | 2005 Enfield Bullet 500
Choppy recording and playback
If the heads become dirty, “NEED HEAD
CLEANING” appears during recording. During
playback, moreover, the following symptoms
appear.
≥Mosaic-like noise appears partially or the
sound is interrupted.
≥Black or blue mosaic-like horizontal stripes
appear.
When normal playback cannot be performed
even after the head cleaning
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
cassette.
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Mar 27, 2008 | Panasonic PV-GS150 Mini DV Digital...
PV-HS2000 Showstopper freeze up and noise
send to Panasonic Digital Svc Center, 410 B Airport Road, Elgin, IL 60123 - $149.95 + $30 return shipping. You have a bad hard drive and they will take care of it for you.
Dec 24, 2007 | Panasonic PV-HS2000 Showstopper 30-Hours...
Evo Pv500 Pro Dvr Digital Video Recorder Pv-500-evo 720p Hd Logo
Top Evo Home Security Experts
Lawrence Oravetz
Are you an Evo Home Security Expert? Answer questions, earn points and help others
