Question about Samsung LE Televison & Video
Samsung LE32R71 vertical color stripes
LE32R71B has sound but no pix only vertical strpies
5 Suggested Answers
  • 1039 Answers
SOURCE: Half of my screen will turn in to vertical colored stripes
T-con board. Check lvds cable for tight connection.
Posted on Sep 16, 2009
nileshsingh2
  • 246 Answers
SOURCE: Switch on. Picture OK for 3-4 seconds then vertical stripes only
IT NEEDS SERVICING, THROUGH THE CERTAIN HEAT ON THE VERTICAL IC, THERE HAS BEEN DRY JOINTS ..RESOLDER IT, FOR BEST RESULTS TRY TO RESOLDER THE OTHER HEATED PARTS..IT WILL WORK
Posted on Oct 13, 2009
SOURCE: Turn on Samsung LN-T4665F and vertical colored
when I turn the modelLN-T4661F TV on it just clicks and clicks any help how to fix it.
Posted on Nov 29, 2009
ladywinn
  • 5138 Answers
SOURCE: Our Sony KF50WE610 suddenly has
Optical Light Engine Assy Call Encompass Parts 1-800-638-3328
or UED 1-800-648-6657
Posted on Mar 04, 2010
I have a 52 inch Samsung TV, on the screen have solid, color vertical lines on the right, about 1/8 wide, on the same time the half of screen blink on the right too.
not knowing the model... i will try to help with this common samsung issue, if i can. / unplug the tv, and wait a few minutes to avoid shocks. / remove back panel. you will see several ribbon connectors, (about an 1" to 1 1/2" wide) usually near the bottom. / carefully remove the ribbon (ONE AT A TIME) and clean the contacts GENTLY with a pencil eraser. (DO NOT use chemicals) / reinsert the ribbons and try the tv. // vertical stripes are almost always the result of poor contact between ribbon and socket. / NOTE!. you can do a quick test before opening the set by [carefully!!!!] twisting the screen and watch to see if the vertical stripes change or disappear. / if the stripes change, bet on it being the ribbon contact problem.//// hope this helps, it has worked on a number of TVs.------Jay
Oct 26, 2015 | Samsung Televison & Video
Rca 32" lcd tv.vertical lines on entire screen,no pix.
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
www.youtube.com/watch?v=PWoz_-3OHIMJan 25, 2013 - Uploaded by Tampatec I have a LG 42PM4700-UB plasma tv that just went black. The red power .... I have a RCA 32 inch it has no sound or picture !Just a light blue ...
Sep 09, 2015 | RCA L32HD31 32 in. LCD HDTV
Color strpies with black around
internal screen needs to be replaced take to nearby apple store.
Jul 11, 2014 | Apple iPhone 5
Samsung CLX-6220-FX vertical lines when scanning and copying
The reason for such lines if they appear only on scans/copies from the automatic document feeder (adf), but not on regular scans and printouts is that there is dirt on the small glass stripe next to the scanner area that is used for scanning from the adf. Just clean that glass stripe and the lines should go away.
Jan 21, 2014 | Samsung CLX 6220FX - multifunction fax /...
Hp pl5060 Plasma TV has no sound or pix. Screen flashing white
I have a seven year Plasma TV HP PL5060. When I turn on the TV, I have sound but no picture, the screen display (power on) is a snowy blue screen and vertical pink stripe. What is causing this problem and how can I fix it cheap. I can afford a TV repair man at this time, because I am laid off from work. Thanks.
Dec 15, 2012 | HP PL5060N 50 in. Plasma HDTV
I have a Samsung LE32R71B 32 in. A small red light at the bottom blinks but you can not turn it on Can anybody help me???
try factory reset switch tv to standby the info menu mute red standby button go to reset wait few mins then swich on
Aug 17, 2010 | Samsung LE32R71B 32 in. HD-Ready LCD...
My Toshiba tv picture has switched.
sounds like your power supply output is low. does the size "bounce" when pix changes?
Dec 28, 2009 | Toshiba 36A40 36" TV
Televison & Video Logo
53 people viewed this question
Jerry Greenberg
Jerry Greenberg
