Question about Microsoft Windows 7 Ultimate for PC
I am not able to open my WinPed program. The timer just keeps spinning but the program will not open
Iam not able to get my WinPed software program to open. The timer wheel just keeps spinning. How can I fix this problem?
    Problem Solver:
  • 13 Answers
Have you tried uninstalling it and then reinstalling it? If YES then have you tried uninstalling it and then running a registry cleaner and then reinstalling it?
Posted on Jan 06, 2016
The machine will wash but will not spin the program keeps running but when it comes to the spin cycle it will not spin but the timer keeps going
Hi Christine - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Jul 11, 2013 | Electrolux Washing Machines
Washing machine washes then will not spin HELP HELP dirty clothes
When you set "the timer to drain and spin only". After "drain" program finished - not pump or motor sound or all sound stoped, the machine is freeze?
The meaning is sometimes, the sensor of water level doesn't working properly. The "drain" program is keeping running.
May 27, 2017 | Washing Machines
Installing the battery can't get the door opened to insert battery
Drawer pulls straight out. Use small screwdriver or metal nail file.
Copy following link for illustration and CR2 battery, and ez-to-follow programming, and wiring options.
http://waterheatertimer.org/images/ST01C-program.html#battery
Remember the drawer is also 'plugged' into the timer, so do not bend small metal prongs on drawer.
This timer comes with 1 year limited warranty against defects in workmanship.
The battery operates timer functions, so once battery is installed, the timer can be programmed before timer is installed in wall.
Be sure to reset timer before programming to eliminate stray code on the memory chip.
Once timer is programmed, the programs remain inside memory chip forever, even with power loss and no battery, until timer is reset of re-programmed.
Reset this timer: Hold down on-off button and momentarily push round reset button with paper clip. Keep holding down on-off until display changes, then release on-off button and begin setting current time and programs.
Nov 27, 2012 | Intermatic & Self-Adjusting Wall Switch...
I have a plug and grow. but iam not sure how to set the timer as it didnt have any instructions with it
Timer is not identified.
1) Add a comment with in-focus photo of timer posted on flickr
2) Open following link for analog timer instructions:
http://waterheatertimer.org/How-to-set-timers.html
Jun 05, 2011 | Hardware & Accessories
I want to reprogram my timer to a new on time,and off time. do i have to clear the existing program,and start from scratch? if yes, do i use 6a an on/off program at specific times. next question: ...
To reprogram times, it might be easier to clear all programs. Read the manual. Sometimes you have to read it several times. Or scan it into computer so you can see print larger. Or go to manufacturer website and download manual. Some manuals are impossible to find, some have unclear instructions.
For programming help. Post brand and model number of timer so product is identified. Some products have nearly identical numbers but are very different. It's a zoo of products. So be specific.
Timers generally repeat 1 week or 1 day. Do you have a in-wall timer? Or box-type timer
Intermatic in-wall EJ500, ST01C, EI600 offer Daylight Savings & Dusk to Dawn operations. EI600 has 5 year warranty. Other two have 1 year warranty.
http://www.intermatic.com/products/timers/in-wall%20timers/electronic%207-day%20astro%20time%20switches.aspx
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers.aspx
Click product number to see manual. Download manual to your computer> go to File at top of browser, click 'save' -or- click 'print'
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/ST01C-program.html
If you have a boxtype timer, Intermatic makes timer with photoelectric sensor
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers.aspx
Aug 14, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
AWM6140/3 Wahing machine
it's a prgramme timer issue mate, you either need the timer flashing with updated software or a replacement timer
Aug 24, 2009 | Whirlpool AWM6140 Front Load Washer
Doesnt go through programs
sounds like you have a bad timer or lid switch. does it finish a cycle but not advance or does it just keep washing or does it wash then stop and get stuck? if it just keeps doing one cycle like wash wash wash you would have a bad timer. if it washes then stops and gets stuck you have a bad lid switch. But then again if you had a bad lid switch it would never spin. What is the brand name of this washer?
Jun 10, 2009 | Washing Machines
Pc suit software
Download PCsuite software from www.sonyericsson.com.
What do you want to do on the PDA's powerpoint? you cannot edit or create .pps files, only open them. The easiest way is to go to the location where you opened the file and open it from there, not from the PDA's application. Another point to consider is if the file was created with Office 2007, there is normally an "x" the .pps (yourfile.ppsx). so unless th creator made it accessible to previous versions ( xp, 2003 etc) the phone wont recognise the format and wont open it
Sep 05, 2008 | Sony Ericsson P990i Smartphone
Task manager n other programs disappearing within no time when iam opening them
Hi
go for a clean install after partitioning
some files are corrupt in you installation
Jul 13, 2008 | Microsoft Office Professional 2007 Full...
Microsoft Windows 7 Ultimate for PC Logo
55 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
