Question about Michele Watches Michele Mw06a01 Unisex Stainless Steel Diamond Set Watch £945
How to replace michele mw06a01 band clasp - Michele Watches Michele Mw06a01 Unisex Stainless Steel Diamond Set Watch £945
HOW DO YOU REMOVE A GUCCI WATCH FROM YOUR WRIST?
This is so called ''snap-on'' butterfly clasp. There is no release mechanism and simple pull is needed to open it. Use your strength on do not worry - it won't brake.
Aug 26, 2014 | Paolo Gucci PG501TW Wrist Watch
Need a better closure on my Navajo wrist band
I would need to know what the width of the band (at the watch case) is, and a photo or two would help so I can see just what has and has not worked for you. If you want, you can email me: chiefo@wbcable.net
Mar 28, 2017 | Watches
Where can I get a new band for my KS4003 Kenneth Cole watch? The clasp won't open and I didn't want to pay $65 just for a new clasp. How much is the band?
Thank you for contacting FixYa,
You can contact Kenneth Cole for a replacement band but I am afraid the band is probably going to be alot more then the $65 for the clasp. I would honestly just replace the clasp unless the band is worn in which case I would do the band.
Sorry.
KC can be reached at 1-800-KEN-COLE
Oct 02, 2010 | Kenneth Cole Watches
Other than removing links, can I make smaller adjustments to the band on my Omega seamster limited edition?
mcdevito75 here, You should right at the clasp, simply remove the pin and move the entire band up thru the other adjustment holes you see along side the clasp itself. If there aren"t any additional holes along side of the clasp for the band to move up closer to the clasp lock, then no other adjustments can be made.
Aug 18, 2010 | Omega Seamaster 2541.80 Wrist Watch
Received Skagen watch Order No: W256417 today. Mesh Band is too long for me. I do not understand step 2 of instructions Ray Reeves
Ajusting the Clasp - Skagen signature mesh bands are easily adjustable in just three simple steps:
LIFT - SHIFT - PRESS Lift the slotted clasp, Shift the adjustable buckle to the desired position (make sure the clasp is set in one of the indentations on teh back of the band), Press the slotted clasp closed.
Aug 18, 2010 | Skagen Watches
The clasp broke from my Fossil watch. Can the
mcdevito75 here, Without seeing the watch it"s hard to tell, but I would figure the clasp could be repaired, but the cost may equal a new band and clasp. Look for a small watch repair shop in your area and compare repair cost of the clasp with that of a new band.
Jul 06, 2010 | Fossil Watches
Pin that holds metal band clasp is missing
If it is only the pin that holds the metal band, this is an extremely inexpensive part that is available at most stores that sell watches.
May 24, 2009 | Casio G-Shock MTG900DA-8V Wrist Watch
Replacement band for the Invicta 2307
SORRY but FIXYA sells nothing .check with your dive shop
Aug 17, 2017 | Invicta Watches
Watch band missing link
Hi lovingdesert ,the only thing you do is go to a service center for watch,if they have clasp like of your Anne Klein,maybe they have an extra. sometimes customer leave thier adjusted clasp. or go to Anne Klein site,and order an extra clasp.
Jun 17, 2008 | Watches
Michele Watches Michele Mw06a01 Unisex Stainless Steel Diamond Set Watch £945 Logo
Top Michele Watches Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Michele Watches Watch Expert? Answer questions, earn points and help others
