Question about Seiki 26" 720p LCD TV - SC261FS
Want to change tv aspect atio
Switctching to hd Switching
I've got the Panasonic TCP50G25 series tv and I think it's great. The only thing that I can't seem to figure out and really wish I could is when I'm watching an HD channel I want to know how to get it so...
THE ONLY WAY TO CHANGE THAT IS TO CHANGE THE ASPECT RATIO OF THE TV AND/OR THE HD BOX. IT WILL BE LABELED "FORMAT" "ASPECT" "WIDE" "SIZE" ONE OF THOSE AND CHANGE UNTIL YOU GET THE DESIRED SIZE.
Dec 17, 2010 | Panasonic TCP50G25 50 in. TV
White flickering line across top of tv with non HD channels
It appears that when you go back to normal tv from hdtv you are able to see the overscan area. Change the aspect of your image with the appropriate button on your Vizio remote and or cable remote. Apparently the button that changes the aspect on the Vizio remote is the wide button. The cable remotes will usually have hd zoom (#), aspect or format.
Sep 28, 2010 | Vizio L32 32 in. LCD HDTV
Change the aspect ratio
you can set the aspect on either remote. the best thing to do is set the proper aspect on the tv remote for regular (sd) channels, and then again for hd channels. the tv should remember these aspect settings and revert to them when you switch back and forth from sd to hd. if you have satelite, there is usually another aspect on there you can change depending on the program, but i usually recommend leaving it alone. if you are on an hd channel with side bars, switch to the sd version instead of changing aspect so you dont have to keep flipping it back and forth.
May 26, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Aquos automatic aspect switching
Go into your menu and take it out of Auto Mode.(format)
Oct 26, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Onkyo TX-SR606 aspect ratio issue
you may want to try changing the aspect ratio on the HD box and the DVD as opposed to the receiver. This should do the thing
Mar 04, 2009 | Onkyo TX-SR606 Receiver
Philips LCD TV wont change aspect ratio
In your philips menu there is an option to turn of your auto aspec ratio to OFF then using your sky remote go to services, 4 then picture and ensure that this is set to 16:9
Job done
Cheers
Little Dish Fitter
Dec 24, 2008 | Philips 32PF7321 32 in. HDTV-Ready LCD...
I change the screen to zoom and aspect control will not change at all?
If you're viewing an "HD" channel, the aspect ratio will not change.
Try switching to a non "HD" channel or DVD and try again.
Oct 06, 2008 | Panasonic PT-52LCX65 44" HDTV
Aspect
I have this same problem with my hitachi 55 inch ultravision luckily i have a warrenty still in effect so i called them and they said... Analog channels are not formatted for wide screen aspect (4, 6, and 10 ect.) this is a normal thing don't worry. It automatically returns to 4:3 because analog is full screen only, and it will return to 16:9 otherwise or whatever you have it set to. Nothing you can do but the good news is your TV isn't broken!
Sep 12, 2008 | Hitachi 51F500 51" Rear Projection...
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Heads cut off and no score...
Try your setting on your cable box (Screen position)
also maybe wide mode try switching to wide zoom good luck
Dec 10, 2007 | LG 42LC2D 42 in. LCD HDTV
Seiki 26" 720p LCD TV - SC261FS Logo
13 people viewed this question
Top Seiki Televison & Video Experts
Andrew Taylor
Andrew Taylor
shaun taylor
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
