Question about Samsung CLX 3160fn All-In-One Printer
Oki mc560 belt reset
Belt change reset
I just bought an OKI MC560 and after I hooked it up it says release the sensor lock and restart. I cant print to it
All you need to do is unlock the scanner. Just open the flatbed cover and on the left edge is the slider for the lock. Slide it towards you and that's it unlocked.
Nov 27, 2017 | OKI Office Equipment & Supplies
Can I reset the belt
How to reset your OKI C3300 C3400 C3600 laser printers ...
? 2:40
https://www.youtube.com/watch?v=czyqKMpy2-E
Oct 6, 2014 - Uploaded by Toner Man
How to reset your OKI C3300 C3400 C3600 laser printers drum unit ... drum message you can install the chip on your drum unit and continue printing. ... Replacing the Transfer Belt on an OkiC3000 Series Printer - Duration: ...
Nov 26, 2015 | OKI C3400n Laser Printer
Streaking in pics printed on oki mc560
Check your consumables, ie. toner, drum and transfer belt. It may be time to change them.
Oct 20, 2014 | Oki Electric Industry MC560 All-In-One...
Oki mc562 scan to multiple pdf
If you are using the ActKey utility for scanning, in the Button settings there is a section called Output Settings. Under that is a pull-down for the file type. that can be changed to a Multi-Page PDF
Mar 07, 2014 | Oki Electric Industry MC560 All-In-One...
Oki c5800 belt life reset
It may require a complete service kit, you should check with Okidata to see if there is a kit available or what steps you should take to reset the life counter.
Jan 29, 2013 | Oki Electric Industry Okidata C5500, C5800...
I need to know the size of the IT Belt reset fuse in an Oki c5500
Have you contacted OKI Data? Live customer support is available 24/7 (within the US and Canada) at 1-800-OKI-DATA.
Jan 14, 2013 | OKI C5500n Printer
Scanner Init error!!
some solution ? i have the same problem :(
Jul 10, 2012 | Oki Electric Industry Oki MC560N...
My Oki C5800 says "Replace Belt, 355: Belt Life" but I was told I could reset it without changing it if it was still good. How?
requires a fuse that sits underneath the transfer belt. However the belt itself would be full of waste toner that would need to be emptied
Jun 30, 2010 | OKI C5800Ldn Led Printer
Printer pauses after a couple of pages
This is normal, if annoying - it just means that the LED bar is getting too hot and the printer pauses to let it cool down. Really the only solution is to operate the printer in a cooler location.
Jul 04, 2009 | OKI Office Equipment & Supplies
Samsung CLX 3160fn All-In-One Printer Logo
55 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
