Question about Necchi Sewing Machines
My needle will not stay threaded. It gets gobs of thread on the underside of the fabric, and does not stitch at all evenly. I have a 1965 Necchi Supernova, and I love the machine.
  • 3 Answers
Try rethreading, make sure the foot is up, change the needle, make sure there are no loose threads or lints under bobbin case. You might also try rewnding the bobbin to make sure it is wound evenly.
Posted on Jun 20, 2009
Necci 752 manual is needed.problem with threading and stitching
Hm, I'm not able to locate a manual but may be able to offer some suggestions.
Remove the top thread from the machine.
AVOID OLD OR BARGAIN BIN THREAD!
Use the same thread in top and bobbin.
Be sure to use a brand new needle--needs to be compatible with the thread and fabric of the project..
ALWAYS RAISE the presser foot and rethread from the beginning.
Set the top tension to the midway point.
Verify the bobbin is loaded and threaded correctly and it turns the correct direction.
Pull the bobbin thread up through the fabric before taking the first stitch. It also helps to hold both thread tails in your left hand when taking the first stitches.
Test your machine and tweak the top tension until the top and bobbin threads meet in the middle of the fabric. (Increased top tension will pull the bobbin thread up. Decreased top tension will allow the bobbin thread to pull the top thread down.)
How to Thread Necchi Sewing Machine
How to Thread Necchi 535FA 535 534FB 534 Sewing Machine and Bobbin Case (not your model, but the threading and basic instructions will be similar or the same as your machine)
How to thread Necchi model 535 FA sewing machine now with captions
Mar 18, 2018 | Sewing Machines
Hi. I have a Necchi MOD559. For some reason the stitches on the bottom stay too loose, so that I get little string hooks and not a clean tight stitch. From the top it looks great. Advice anyone?
Yep, It is called bird nesting or thread nesting. The number one reason is that the top thread is not seated completely in the top tension disk.
Install a brand new needle.
ALWAYS RAISE the presser foot and rethread from the beginning. Confirm the thread path is correct.
Now recheck your machine stitching.
Remember if the thread issue shows under the fabric, it is a top thread problem. If the thread issue shows on top of the fabric, it is a bobbin problem.
If the top thread still shows on the underside of the fabric, you may need to tighten the top thread so it will pull the bobbin thread up.
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
May 24, 2017 | Necchi Sewing Machines
Needle stitch fine. Bobbin stitch loops.
First, try a brand new needle.
Second, consider using a better quality thread. By all means, AVOID old or bargain bin threads. Coats & Clark used to be a standard, but thread quality has improved over the past few years, so you may want to check out other brands like Aurafil, Superior, Isacord, etc. Also, cotton wrapped polyester thread releases thread lint that contributes to build-up of gunk in the machine. Some sewists have noted that they experience more sewing issues when using C&C threads. However, some machines will do better with certain thread brands than others, so some experimentation may be beneficial.
Third, check the stitch on your sample again. Generally, when thread loops appear on the underside of the fabric, it is the upper thread that is the problem. If loopy threads appear on the top of the fabric, it is the bobbin thread that is the issue. You can even use a different color in the top to help distinguish which thread is the problem.
Fourth, when threading the upper thread, Always Raise the Presser Foot during the threading process so the tension disk is released and the thread can seat properly. "Bird nesting" occurs when the thread is not seated in the tension disk.
Birds nest under the fabric big loops of thread top side looks good...
Fifth, when the upper thread appears on the underside of the fabric, the upper thread tension is too loose. If the bobbin thread appears on the top of the fabric, the tension thread is too tight (or the bobbin thread is loose). Start out with the upper tension set at the midway point and tweak it from that point. The tension is ideal when both upper and bobbin threads meet in the middle of the fabric.
Also, remember that tension is not static--a tension setting for chiffon will most likely not work on cotton or denim. Get comfortable adjusting the tension to suit the project you are sewing.
May 24, 2016 | Sewing Machines
Lots of thread on bobbin side
If it is the top thread making gobs under the fabric (thread nesting or bird nesting), usually the upper tension needs to be tightened.
Install a brand new needle. Raise the presser foot and re-thread from the beginning. (Raising the presser foot allows the thread to seat properly in the tension disks.) Check your manual to be sure you are threading correctly. Re-test the stitch and tighten or loosen the upper tension until both upper and bobbin threads meet in the middle of the fabric.
Nov 27, 2015 | Sewing Machines
How do I adjust tension on a Necchi Lydia 510 sewing machine?
loops under fabric means top tension needs to be tightened
try cleaning the top tension dial with some unwaxed dental floss and see if that helps. if it doesn't then the tension dial may need to be replaced
also check to make sure the spool of thread is not getting caught on the spool holder
also try a new needle--one that is correct for the fabric being sewed
Feb 10, 2015 | Necchi Sewing Machines
Won't sew stitch patterns, thread gobs up on underside fabric
it is called bird nesting and indicates that the needle thread is not tight enough
Dec 14, 2017 | Singer Sewing Machines
Can't get the tension or the stitches to regulate
try a tension setting of 3 or 4
my mechanical necchi is set on 4, but the tension should be adjusted according to the fabric & thread & needle
here's a tip for needle & thread compatibility
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 26, 2010 | Necchi 6030 Mechanical Sewing Machine
I have a Necchi 535 sewing machine and the thread tangles
if the thread under the fabric is a matted mess
1.the needle thread tension is to loose
2.needle is either to heavy or to fine for the thread
3.check to make sure the thread isn't off the thread take-up lever
Jul 30, 2010 | Necchi Sewing Machines
Stitches are looping on the underneath and missing some stitches
Refer to the manual for cleaning.
Replace the needle with the size recommended for the type of fabric being sewn. The flat side of the needle is usually facing the back of the machine - check manual to be sure.
Always thread any sewing machine with the presser foot up. This opens the tension control so the thread can properly enter this device.
When a sewing machine is threaded with the foot down, the tension control closes and the thread cannot enter as it should
You then get loose stitches because the top thread and bobbin thread cannot make a proper stitch and the tension of the bobbin thread is pulling the top thread to the underside of the fabric.
Mar 07, 2010 | Janome Sewing Machines
Singer 301A needle breaks
do you have a book, refer to threading. This machine threads differently than most, threads like a 221 featherweight. Needle goes in backwards, and threads backwards. in wrong and you can have problems, also threading can cause your problem if you have missed tension or a thread guide. great little machine
Jun 01, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Sewing Machines Logo
123 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
