Question about Gestetner DSm735 Black and White Copier
Error code aficio sc329 - Gestetner DSm735 Black and White Copier
Aficio error sc329
I AM SURE THE ENTIRE MEMORY HAS BEEN FORMATTED.
PLEASE ENTER SP MODE AND ENTER SP 21039 AND 21094
AND THIS ERROR WILL NOT APPEAR AGAIN.
Jul 11, 2014 | Ricoh Aficio 450 Copier
How to clear toner alert
open the front door and close again, wait for toner to load.
if this problem persist,open the front door and remove toner unit,use a flat screw driver to press on the door sensor and check if the toner motor is working properly.
if the motor is in good condtion,service the toner unit and make sure that the unit is toner free and insert new toner.
if this condition persist, enter the sp mode and clear all memory by sp 5801 for mp5ooo, aficio 1035-4545,645,2035,2045,235,735 or sp801 for 1022,1027,1505 and restart the machine.
for aficio 1035-4545,645,2035,2045,235,73 enter sp21093 and 21094 mode before making a copyor else the error sc329 will appear.
good luck
Apr 04, 2014 | Ricoh Aficio MP3350
My probleme ricoh aficio mp 4500 sc 329
sc329 on the MP4500 is a laser pitch error. The most likely fix is either to have a technician initialize the laser beam pitch adjustments or examine the laser unit to make sure none of the harnesses are getting in the way of anything.
Aug 14, 2011 | Ricoh Aficio 450 Copier
Code 326 329
still sc329 error
Nov 26, 2010 | Ricoh Aficio 2035 Copier
SC329-00
HOPE YOU SPEAK ENGLISH the error is due to the laser unit malfunction..after memory clear usually..you need to press the yellow clear button then 107 then hold down the stop/cancel button for 5 secs till the screen changes.. then copier sp section 2 drum then look for laser pitch beam adjustment you need the 400dpi and 600dpi initialisation to be done.. this should clear it then turn off the machine and wait 10 secs and turn back on.. hope this helps ..Adios
Jul 14, 2010 | Ricoh Aficio 1035 Copier
ERROR CODE SC329 IN NASHUA AFICIO 3445
ca 107 c then inter the sp mode then clear error
Jan 14, 2010 | Ricoh Aficio 450 Copier
ERROR CODE SC329 IN AFICIO 450
Laser synchronization error
The main scan synchronization
detector board cannot detect the laser
synchronization signal for more than 5
consecutive 100 ms intervals
I have error code sc329 on my Aficio/ricoh copier. What does it mean and how to fix it. Please help. Thanks
In some models this code means that the laser has aged and must be replaced.
But he would be interesting to know that model is for being safe of this.
Sep 13, 2009 | Ricoh Office Equipment & Supplies
Error code
Thats not good. Its a laser problem. You are probably going to need a service call.
Mar 09, 2008 | Ricoh Aficio AP410N Laser Printer
Gestetner DSm735 Black and White Copier Logo
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
