Question about Ruud UAKA042 Air Conditioner
AC unit runs inside but not outside! help
I have an Lennox Elite Series AC Unit purchased it in 2005, tried to get it going today, air blowing up the vents on the inside, went outside to see if running outside and it is not, HELP!
Check your thermostat is it set on cooling, check your pressure switch it might be triped due to blocked condenser.
Posted on Jun 30, 2009
  • Laura Purcell
    Laura Purcell May 09, 2014
    Thermostat set to fan on, inside unit going, breaker box chd and in on position but outside wont turn on. there is a grey box out by unit i opened and there is a handle says on/off but you cant move it??what and where would i look for the pressure switch?
    Sergeant:
  • 340 Answers
Check breaker thermostat set cooling auto call for service.allso get it cleaned both coils.. Tom
Posted on Jun 19, 2009
  • Laura Purcell
    cant afford to call tech, but thanks
    Problem Solver:
  • 10 Answers
It's likely a capacitor issue. They fail regularly, especially when it's hot out. I had a fan capacitor go out on one of my 3 units last year and it cost close to $300 for an AC company to come out and fix it. I watched them fix it and it's something that you can do yourself if you know what you're doing and are careful to hook it up right. I have three AC units and another capacitor went out this year and I found a kit with detailed instructions with pictures and phone support at hvacrepairkits.com. It saved me over $200 on the capacitor replacement.
Posted on Aug 14, 2011
  • Laura Purcell
    we have three units and other 2 are working fine. they run downstairs. The upstairs one wont work and we have never used it for ac. we used it for heat this winter and it was fine and still wors for heat but we heat by gas.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Check power to outside controls ,,, 240 volt to the bottom of the contactor and the 24volt to the contactor!
Posted on Dec 08, 2009
    Problem Solver:
  • 6 Answers
The condenser fan motor could be blown and need to be replaced. That is a pretty easy diagnostic that a decent service technician could figure out. The parts should run maybe $100 plus the service technician's hourly labor rate.
Outdoor lennox elite ac unit not turning on
Remove the service cover on unit.check and see it the contactor is pulled in if it is then check the disconnect that is the gray box that you see on the wall to see if you are getting 220 volts to it and through it to the unit. if indoor unit is running and outdoor contactor is not pulled in check the 24 volt side of contactor. You will need a metter for this if you are not confident with working with electricity call a service company. electricity KILLS
May 09, 2014 | Heating & Cooling
Lennox elite heat pump throws cold air
The unit should give you an error code if something is wrong.
Here's the manual:
http://instalacionesindustriales.com.gt/pdf/Lennox_Minisplit_HE.pdf
Mar 25, 2014 | Lennox 7 Series MS7-HO-18P MS7-HI-18P Heat...
We have Lennox Elite Series furnace and central air. Blower would come on but air cond. did not. He replaced circuit board ECG1, I believe. I don't think he was sure if that would repair problem. Our...
Look at the inside of the cover on the furnace and it will tell you what's the code mean.
I think because was calling for Ac that's why you are having that blinking red light.
Turn furnace off on switch and turn it back on and that should clear error code .
To check your air conditioning unit that's the unit that's outside .
Check to see if contactor is pulled in .if it is and nothing is running then check the capicator. The capicator is the oval metal thing that's tuck next to the capicator with 3 wires attached to it .
If it bulky then it's bad .
That is the most common issue with these unit.
Jun 01, 2017 | Heating & Cooling
Why would my heat pump central air blow cold then warm
Sounds to me like you have wiring issues. Need to make sure all your connections are tight, wires are clean and free of bare spots (possibly from rodents chewing them)and your settings on your tstat are correct. Heat pump with back up electric heat.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 09, 2017 | Heating & Cooling
The fan is running and blowing cool air out of the unit but there is no air coming through the vents, what are the possible problems? (Lennox Elite series)
The unit could possibly have a frozen indoor coil. Turn ac to off...and fan switch to on...wait 45 minutes and see if air flow improves. Check for dirty filter which can lead to freeze up. Low on freon is also a possibility.
May 18, 2010 | Heating & Cooling
Ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
Aug 15, 2009 | Heating & Cooling
Line to evaporator iced over
I am not exactly sure as to the type of unit you have. If it is a ductless split system (inside unit on the wall, never seen Lennox make one) you could be low on charge, the metering device to drop the refrigerant pressure is in the outdoor unit. If this is a whole house system, you may have a restriction in the outdoor section somewhere. If you look into the unit while it is running, try to find a filterdrier. It is a cylinder soldered into the small line. You can also see exactly where the ice starts, that is where your restriction is. Let me know what you find out.
seth
Jun 26, 2009 | Heating & Cooling
Lennox air conditioner is blowing hot air
Check your coils for ice, check your breaker and fuses for condensing unit, and is your condensing fan running? If not, you either have a bad fan motor or capicitor. After you hit the button, and wait for it to time out, (you should hear a click) take a butter knife, and spin the fan if it is not moving. If the fan start spinning by itself after your assistance, you have a bad capacitor
Jan 29, 2009 | Heating & Cooling
Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Jun 26, 2008 | Goodman CKL60AR60 Air Conditioner
Ruud UAKA042 Air Conditioner Logo
969 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
