Question about Candy Ovens
The timer has a locked symbol on it
Timer locked
Oven keeps beaping and has a alarm symbol showing
Sounds like the timer was set and time is up, the issue is whichever model oven it is has a specific way to stop the alarm. Some just require a simple pressing "cancel" while others use a combination of buttons. I would try pressing either the arrow up or down, if not present just press the "timer" button, see if the alarm symbol changes or disappears
Nov 10, 2016 | Ovens
A key symbol is showing. How do we unlock
Hello. Look on the control panel for a button(or set of buttons) that are usually pressed for 4-5 seconds. The button(s) will have a lock symbol or the word "lock" beneath it. You press and hold the button(s) until the lock symbol goes dark. That tells you the lock has been disabled.
Nov 03, 2015 | Ovens
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
My Neff oven is displaying the locked "key" symbol...does anyone know how to unlock please?
Locking the oven:
Using the main oven function selector, switch 3 x in
rapid succession from the 'off' position to the
oven light function and back again.
- s - is displayed.
The oven cannot be unintentionally
switched on, e.g. by children.
To release the oven, switch 3 x from
the 'off' position to the oven light.
- s - goes out.
Mar 21, 2013 | Neff B1641 Single circotherm super...
Gaggenau EB944-110 Pyrolytic oven stuck in some kind of mode after power outage. Oven worked perfectly but there was a mains cut. After restoring power it appears to be stuck in some kind of strange...
Yes this could be the problem. If you can't set the timer to manual mode the oven will not work. Turn the oven to on so that when power goes to it you will see the oven indicator light come on. Play with the timer buttons until the oven indicator light comes on. If it won't work you probably need a new timer.
Feb 11, 2011 | Ovens
Our oven "locked" and we
If the oven has a timer dial, this may be the problem, set the timer to "off" or to the Hand symbol.
Oct 28, 2010 | Frigidaire Ovens
Oven failer
You have reset the timer from the auto function, to the manual function.
You should see a hand symbol showing for manual operation.
It is a question of pressing the buttons in the correct sequence., or if it is a anologue timer, turning the knob until you see the hand symbol showing.
Hope this helps.
Dec 24, 2009 | Zanussi ZBF360X Electric Single Oven
Lock symbol on oven won't go away
Unplug for 60 seconds and plug back in
Apr 30, 2009 | Ovens
Need to know how to use the timer
The manual for this Oven is available free to download at http://www.safemanuals.com Regards Vortash
Apr 28, 2009 | AEG B3101-4 Electric Single Oven
Bottom fan oven not getting power but top oven/grill is working
Check that the oven is not stuck in AUTO or TIMED mode. Also set the clock to the correct time if you can.
Nov 05, 2008 | Ovens
Ovens Logo
13 people viewed this question
Top Candy Ovens Experts
ray gallant
Dado
Tom Chichester
Are you a Candy Oven Expert? Answer questions, earn points and help others
