E13 apell washer dryer
Fault E 13
2 Suggested Answers
KevinWhite
  • 1902 Answers
SOURCE: Bosch E13 error on washer
Hello & Welcome to FixYa
E13 error in your Bosch WFMC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Jul 30, 2011
Hoover washer dryer wd 9616c error code e13 and burning smell from the rear????
The automatically suggestted E13 guidance that the system posts referring to Bosch machines is irrelevant I'm afraid. On a Hoover, the message means "Faulty module connections. Check all connections between modules and associated wiring." The chances are that you have a partially dislodged connector on the main board, or on the connector that goes to the motor
Oct 14, 2015 | Hoover Washing Machines
Error code E:13
I thin E13 is motor error, I will check.
Sep 03, 2008 | Bosch Nexxt 300 Series WFMC2201UC
How can I fix my washer when it stops with an E13
E13 indicates your input voltage is to high
also can happen with faulty motor/ brushes
Jan 31, 2015 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I have a smeg washer drier wdi 146 with error code e13. Can you tell me what the problem might be. Thanks
i beleve your door interlock is fautly
or the wiring too it can overheat and cook
so youll need a new one from smeg uk
and check out the connector for any issues
see here for some details
although its a different model i would assume the company uses the same error code setup for all its models
and i would order direct from smeg
http://www.ukwhitegoods.co.uk/forumsphpbb3/washing-machine-forum/error-code-e13-smeg-wdi12c6-washer-dryer-t75513.html
Dec 20, 2014 | Washing Machines
Bosch E13 error on washer - shows e-13 and door will not open.
Kevin
Jul 30, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Grey screan with apel and cross over
this meens that your apple os is corrupted. backing up you info on another mac computer and reinstalling osx would fix this.
Jan 05, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Washer not draining and rinsing
Hello Wet Towels, well to be honest outside of the test program I have never seen a fault code E13. If it was an error E03 I would check my water to make sure it was turned on, the cold inlet hose wasn't pinched, or debre filling the filter screens in the hose or water valve. That is what the care and use says about E03. In the back of your owners manual it tells you what the fault means and how to correct it. If this doesn't work call for service to resolve your issue. Hope this helps.
Aug 10, 2008 | Washing Machines
Just moved
E13 code means Pressure switch Fault
To check :- Remove Plug First ( Remember Safety First )
The pressure switch is at the top, its move likely to be a blocked pressure bottle, which is under neath the tub accessed via the rear bottom access panel 3 to 4 screws. the bottle is on the side of the filter with a small clear tube going up to the pressure switch. Clean this bottle out.
E19 code means Power Failure during Programme
Mar 10, 2008 | Hotpoint WMA64 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
