Question about KitchenAid KESC300 Electric Kitchen Range
KitchenAid KESC300 range error code
My range has an error code SA66 or 5A66 or 5R66.
3 Suggested Answers
  • 126 Answers
SOURCE: kitchenaid electric range yker1201 with f2e0 error
F2-EO indicatwes a shorted key pad. Electronic parts on ranges sometimes have warranty for five years (may only cover parts) so check your owners manual to see what your warranty is then call for service. It is a good idea to save reciepts of repair for future reference if neccessary.
Posted on Jan 02, 2009
jyackle5
  • 8197 Answers
SOURCE: KitchenAid Superba Gas Range error code F3 E0 when
The F3 E0 means
Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse Good luck
Posted on Nov 27, 2010
Control panel is so dim I cannot see anything on display. No error messages were received. Panel has gradually darkened and is totally off now.
it is the backlit display, i just replaced one lastweek that done the same thing,, you will need to replace it to get the lights to work,, repair clinic.com should have one for your model
Jan 19, 2011 | KitchenAid KESC300 Electric Kitchen Range
After cleaning, the oven will not work, it keeps flashing F5, whats the problem?
Hello & Welcome to FixYa
Error code F5 is a door latch failure and is displayed due to malfunction of door latch-switch assembly. First try to check the door latch switch, if fine then recommended repair is replacement of door latch-switch mechanism. Please get back to me if you have any other questions.
Kevin
Jan 01, 2011 | KitchenAid KESC300 Electric Kitchen Range
Whirlpool Accubake Range - error F6 E4 , how do I stop the beeping
Replace the sensor as shown in the F6 code
F6 Computer logic interrupted (timing) Replace Electronic Range Control (ERC)
Error Code: E4
Cause: Shorted sensor
Example: Disables cooking in affected oven
Corrective Action: Check sensor
Nov 02, 2010 | KitchenAid KESC300 Electric Kitchen Range
Gives codes F-2 &F3 what is the problem jachin2145@comcast.net
Hi, Error Code F2
An F2 error code indicates a failed connection with the keypad. Ensure that the connection between the keypad and control board is tight, and press the "Cancel" key. Wait one minute to see if the error code returns. If it does, the keypad is defective and needs replacing.
Error Code F3
F3 error codes are triggered by problems with the oven temperature sensor. You cannot tell whether the sensor has shorted out or has simply failed to generate a reading if your Whirlpool range only displays two-digit codes. On a Whirlpool range with four-digit error codes, the F3-E0 code represents a failed temperature sensor and F3-E1 represents a short in the sensor. Regardless of which code is displayed, replacing the temperature sensor is the only way to correct the problem.
Hope that helps.
Thanks for using fixya...
Oct 27, 2010 | KitchenAid KESC300 Electric Kitchen Range
CONTROL PANEL WON'T WORK AND HAS - F2 E0 - ERROR
Remove the power and disconnect all connectors to the control board and put them back on one at a time. If it still won't work the board may be faulty.
Aug 26, 2009 | KitchenAid KESC300 Electric Kitchen Range
ERROR
it means one of your door latchs isnt reading could be faulty
Sep 11, 2008 | KitchenAid KESC300 Electric Kitchen Range
Error code F1E2
The code F1E2 refers to a watchdog circuit in the ERC (Electronic Control Card). This can only be corrected by replacement.
Dec 29, 2007 | KitchenAid KESC300 Electric Kitchen Range
Kitchen Aid KESC300 smooth top electric stove
Look on the back of the oven for a tech sheet. This will tell you what the code means and what to check. May be an oven temp. sensor or oven control bad. Can't remember what f7 is without looking at the tech sheet.
Sep 30, 2007 | KitchenAid KESC300 Electric Kitchen Range
KitchenAid KESC300 Electric Kitchen Range Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
