Question about ViewSonic PJD6531W Projector
Power supply unit failed how to get this fixed?
CANNON IR3300 SHOW E0003-000 ERROR WHAT PROMLEM MADE AND WHAT CAN I DO
The main thermistor reading is lower than 140C when paper is moved
The fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact or has an open circuit; or, the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty. Caution To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
State Turn on the power switch, and clear E002/E003. Thereafter, turn off and then on the power switch. Does the fixing heater operate? NO: See "The fixing heater fails to operate." 2. Wiring Is the wiring from the DC controller PCB to the fixing film unit normal? NO: Correct the wiring. 3. Fixing film unit, DC controller PCB Try replacing the fixing film unit. Is the problem corrected? YES: End. NO: Replace the DC controller PCB
TRY OUT THAT IF U FAIL email me@ kagimuj@ymail.com
Dec 15, 2017 | Cannon Office Equipment & Supplies
My TV takes a long time to come on. How do I fix it
This is a very common problem with your tv, what has most likely happened (about 90% of the time) is the power supply has failed, more specifically there are a few caps in the power supply that have most likely failed. The unit will require component replacement to get it working again. .
Dec 19, 2016 | Televison & Video
How can I fix my PC, Acer with NMD processor, whenever I try to power it on it fails. I have tried to check the power supply but it seems ok.
Sometimes the on board battery that keeps the BIOS going when the computer has no power can fail. This can stop the computer from starting.
Open it up and look for the battery,get the number, get a new one (should be a couple of bucks) and then change it. Leave power on otherwise it will reset BIOS. What I mean is leave it plugged in and power on to do it even though the computer is not starting.
Dec 29, 2014 | Acer Computers & Internet
Power supply unit failure
It could be the IC101 (MR2920) and the zener D104 both failed, or IC1 (MD5001T) failed as well, here is the link where I've descrived how I fix the issue on my DVR-520H, it is in italian but you can translate it with Google: http://www.plcforum.it/f/topic/181344-riparazione-guasto-alimentatore-pioneer-dvr-520h-dvr-520h-failure/
Feb 08, 2013 | Pioneer DVR-520H DVD Recorder
Power supplierd but does not start recorder no
Hello:
If the unit is competely dead, then you may of blown a fuse or the power supply has failed in the unit. If you take off the top of the unit while unpluged check the fuses near where the power cord attaches to the inside of the unit this is the power supply area, If you have indicators lit or the display is coming on then the unit may have a bad power supply or the System control board has failed. It which case its cheaper to just purchase a new unit.
Jul 14, 2010 | Panasonic DMR-E85H DVD Recorder
All it says is PLEASE WAIT
The problem indicates a power supply issue. There are two capacitors that fail in the power supply (the power supply is located under the hard drive holding bracket). You can observe the failed capacitors because they will be appearing slightly bloated, with a slight leakage of substance on the top. By replacing them with spares de-soldered from a functioning but useless electronic device, you can completely restore your unit. The "Please Wait" message is caused by the hard drive not spinning up. The issue was that the power supply was not delivering the proper power to the hard drive. Don't replace your hard drive, you will lose your recordings. Test the power first. If you dont have a good knowledge on fixing this issue then you can get your unit fixed for a flat rate of $130 by Panasonic. There is a special number to call:
1-888-439-2676 1-847-468-5543
Thank you !!
Jun 04, 2010 | Panasonic DMR-E85H DVD Recorder
My wii console will not power on. have checked all plugs and everything is connected and outlet has power
HI. the power supply board has failed. There is a fuse(3amps) inside the power supply unit. you will need to remove the cover from the power supply to access this fuse. once inside the power supply, inspect the fuse. if it is truly blown, replace it. if the fuse is not blown, this will confirm a failed power supply unit. it should be replaced in this case...
Aug 04, 2009 | Nintendo Wii Console
Changed video games and then it would not turn back on. No power to the wii box.
((Contact Nintendo for a repair ticket if the unit has failed))
My x-box don't turn on at all
the power supply unit has a light indicator..
green orange and red,
if your power supply unit shows green light, it means that there is no problem with your power supply, but try to check the power cord that is directly connected to the power port of the console
if it shows orange, it means that the power suppy unit is in standby mode, try other wall outlet
if its red, dude you have to let the power supply unit to let for a couple of hours, and if its still red you have to replace your power supply unit..
Jun 25, 2009 | Microsoft Xbox 360 Console
ViewSonic PJD6531W Projector Logo
74 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
