Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Frozen coils on the Refigerator side.
The coil tubing in the back of the refrigerator is freezing over with ice. I have defrosted it and as soon as i plug it in within minutes condensation forms and ice builds up.
    Problem Solver:
  • 19 Answers
Make sure the evap fan is running,and the coil should covered for propper airflow
Posted on Jun 21, 2009
Freezer fan runs not freezing . seems to be locked in defrost mode
read the manual book of the freezer ,,,and see if ice is not blocking the way......
Nov 20, 2015 | Amana Refrigerators
Where is the evaporator fan motor? My Freezer and fridge would quit cooling/freezing. I took the back panel off in the freezer a week ago and the evaporator coils were completely frozen over with ice. I...
I do not believe the problem is the fan. sounds like the frig. is low on Freon this is what will cause the ice build up. you need to find the leak, you can do this by spraying soapy water on coil tubes & watch for bubbles. repair leak & recharge.
May 25, 2015 | Samsung RS261MDBP Side by Side...
The refrigerator has frozen on the back side of freezer and has stopped freezing. The other side is not cooling. Ice maker stopped.What is going on?
The frozen on the back side of the freezer is due to your unit haveing a defrost issue where either the defrost thermostat which is the most popular to show a fault in this type of situation, or the defrost heater, or the defrost timer or adaptive control has a fault . If you have a multimeter you can perform and ohms test on the thermostat which should read around .50 or higher and the defrost heater which usually is around 26-28 ohms. If you had a 0 reading then this would tell you which piece has a fault. I will await your reply as to your finds.
Thank you
Rick
p.s these parts are located behind that inside rear wall panel which is removeable if you were to see any ice up condition on the evaporator coil this would confirm your defrost issue and you would first use a hair dryer to defrost the evaporator coil of all ice.
Nov 19, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Model GSS25SGMCBS coil freezes.heater checkedout ok service man changed the circuit board for $312.After 3 days, same problem again. Freeze temp ok but refrigirator sectio quit working after coil freezes....
Control board is new, heaters ok, Check defrost thermostat and thermisters located on evaporator.
PC board not getting information to defrost properly.See site below
Also check the fill tube at ice maker . Iv'e seen these get loose and fill evaporator with water causing ice block
good luck
GE Refrigerator Repair Guide
Aug 16, 2011 | GE GSS25SGMBS Side by Side Refrigerator
The freezer fills with water and overflows about once a week.The food is partially frozen and the ice is clear and wet. The fridge is cold and no problems but the freezer doesn't fully freeze and water...
your evaporator coil in the rear area behind the freezer back panel is frozen over with ice and the coil can no longer deliver cold air due to ice blocking the air flow from the evaporator fan,remove this rear panel,defrost it with a hair dryer,check the defrost heating coil for continuity,they go bad regularly,if not the heater coil under the evaporator coil,it may be the defrost timer in the refrigerator section of the unit that powers the defrost coil that needs replacement
Jul 25, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
It works but the freezer and refrigarator does not get cold
Could be the same issue my parents are experiencing with their refrigerator. It was working but not actually cooling enough. Their's started when they noticed the ice in the trays were not freezing. The bottom section of the freezer was cold but the top section was not. When I examined it I found that the evaporator coil was totally frozen over, which doesn't allow air flow to occur over the coil. I defrosted the coil and it began working again and ice was able to be frozen in their trays. But, after two weeks the same thing has happened again. When I looked at it the first time I suspected it could be two things, they were either leaving the door ajar, causing humidity (moisture in the room) to leak in and freeze on the coil, but my strongest suspicion was the defrost system was not functioning. But instead if replacing parts or tryingto troubleshoot the defrost cycle, I simply defrosted manually to see how it would behave from that point. Seems like my first conclusion was may be correct. The defrost is not working, thus allowing the coil to freeze over again.
In doing some research tonight, it seems this model may have issues with the defrost system. Could be a bad heater, defrost controller, or two thermistors that were mentioned in another posting. I am going to check them tomorrow and see if they are good (heater element and thermistors).
Not sure if this is your issue, but a quick look at the back plate for signs of frosting or ice build-up (on inside of freezer compartment, backside of freezer) will give you an indication if the coil is frozen over. If there is ice or heavy frosting, your coil is more-than-likely frozen over and preventing adequate airflow movement from the freezer compartment and freezer fan.
Hope this helps.
Jun 14, 2010 | GE GSH22JFT Side by Side Refrigerator
Freezer freezes fine/ Cold air not getting to Refigerator side
I can offer a suggestion. It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
Oct 23, 2007 | KitchenAid KSRS25IL Side by Side...
My Jennair Side by side has ice in freezer bottom and leaks water
This sounds like the defrost drain line is clogged and frozen. Every 8-12 hours the defrost cycle melts the ice buildup on the coils and is supposed to drain out to the pan under the fridge. Once this is blocked or freezes up the next cycles continue to put liquid water over the existing ice which then freezes, etc. till finall the area is frozen enough for water to find it's way out the door seals. You will need to take the back interior panel off the freezer side to view the coils and drain line. It will take lots of hot water to melt the ice in the drain area and the drain line in order to run a cleaning tube (basically a piece of 1/4" tubing like the water line tubing a couple feet long that you can force down the drain to make sure it's not plugged). Once you push the cleaning tube down the drain and can see it come out the other end in the drip tray pull it back out and pour hot water down it once more to watch that it drains fast. That should do it!
Feb 08, 2007 | Maytag MZD2665HE Side by Side Refrigerator
Refrigerator won't get cold
You likely have a defrost cycle failure. The freezer's cooling coils need to be frosty and cold so the air that the fan pulls over them can cool the fridge section. If the defrost cycle fails, the coils freeze up to a block of ice and air flow suffers (fridge is about 55 degrees F). The freezer stays cold only because there's a block of ice in there now... sometimes that cold "sinks" to the bottom and only the food at the bottom stays frozen (and can even freeze food at the bottom of the fridge compartment while the rest is warm). To be sure, you'll need to take the rear interior panel off the freezer back wall and check the coils to see if they are frozen solid. If they are then there's a defrost cycle failure. If they are showing a nice white frosty pattern evenly all over the coils then that's normal and maybe the evap fan (right above the coils) is not blowing air up properly or is not working at all. That fan should run if the compressor is running, etc. the only time it doesn't run is during an actual defrost cycle. Once you find out what condition the coils are in it should be simple to direct you further on the problem.
Jan 05, 2007 | Maytag 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
