Question about Oreck XL2600 Vacuum
I need diagram of replacing on/off switch for Oreck XL2600
All I need is diagram of how to replace on/off switch for my oreck vacuum. I have new switch and need to install. My oreck manual does not show how to replace switch.
  • Anonymous Mar 31, 2014
    need to replace the filter
    Sergeant:
  • 206 Answers
Manual would not, they want you to pay a service tech.
Believe this model has switch in grip,
1. Unplug unit.
2. remove screws from grip.
separate the grip halves to access switch.
3. I believe the power cord, where it enters the grip, has slip on terminals that fit on the switch. Just substitute the wires and re-assemble.
Should not require any soldering. Be careful, routing of the cord in the handle is difficult as I remember, depending on the year model, sometime in late 90s they went from a molded in strain relief to a serpentine path.
Posted on Jul 30, 2009
Detent to make it stand upright when not in use!!!
Contact your local Oreck dealer and they can adjust it for you.
Aug 07, 2013 | Oreck XL2600 Vacuum
How to tell if switch bad..xl2 stopped working
If you have power in the outlet and the vacuum does not come on 9 times out of 10 it is the switch especially in the oreck or if the switch feels like there is no snap or click when turning on and off
Nov 20, 2010 | Oreck XL2600 Vacuum
I took a defective switch out of my xl2. I need to know hwere I can buy a new switch
Easiest solution will be to go to an authorized Oreck shop. Next best bet may be any vac shop. Third option is online, but likely they don't want to sell it you, but have you take it to an authorized dealer for liability reasons.
Oct 14, 2009 | Oreck XL2600 Vacuum
How do you install the switch for the oreck vacumn properly?
The Orecks I have worked on have a plastic handgrip area surrounding a metal handle rod.
Undo the handle screws and the handle should separate like a **** shell revealing the switch and harness. Pull gently on the wire terminal with a pair of needle nose pliers not behind it.
Be careful not to flex the switch contacts as they may break off. reinstall any insulation around the switch before reasembling.
Sep 08, 2009 | Oreck XL2600 Vacuum
On/off switch for Oreck XL2600HH
Would have to assume by now you figured this out. However, need to open up the handle. It is a clamshell arrangement. Remove switch from handle, pull one wire at a time from the switch. The electrical connectors are a push-on type. Replace each one, one at a time, to the new switch, and then re-insert switch into handle. Close up the clamshell, tightening all of the screws, but do not strip the plastic housing.
Jun 19, 2009 | Oreck XL2600 Vacuum
My Oreck beater bar is not turning. The bar is free of hair or strings, the motor is working, just the bar will not move
If the motor is working then check the drive belt. There's a door on the right hand side of the Oreck that comes off with a cross head screw. Check the drive belt isn't broken. If its intact then its a possibility that the beater bar has seized up - beater bars from Oreck are available although you should check EBay to see if you can get a cheaper part. Sounds like a drive belt problem though.
Mar 05, 2009 | Oreck XL2600 Vacuum
I put a new belt on my oreck xl and it is burning through why?
The problem you are having is that the brush roller is not spinning freely when the belt is not on. if the end caps of the roller can be removed, clean the dirt & carpet fiber out and test. if it can not you just may need to replace the roller
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Feb 01, 2009 | Oreck XL2600 Vacuum
Oreck vacuum cleaner stop working; earlier it was off-on while in
Check that the main plug socket isn't coming off from under the handle.
Jan 10, 2009 | Oreck XL2600 Vacuum
Oreck XL 2600HH
The fan has a nut holding it unto the motor shaft. I sent you the wiring diagram to your email, hope it helps.
Oct 01, 2008 | Oreck XL2600 Vacuum
Oreck XL
Your roller brush is probably bound with hair and is not able to move
Nov 30, 2007 | Oreck XL2600 Vacuum
Oreck XL2600 Vacuum Logo
841 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
