Question about Miele Novotronic Premier 500 Front Load Washer
Check drain light, fusing all the sockets in the house
Miele premier 300 had the drain check indicator light on, drained fluff filter, next every time I go to put a load on it fuses all the sockets in the house. I have been trying to undo the filter using players as it says in the manual but it just spins round, how can I undo it? Maybe there is something trapped in there like a sock? If I could only remove the filter then I could possibly save my self pounds
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 15 Answers
Do you mean it blow the fuses in the house?
Must be an electric problem with it. Something is overloading the unit perhaps electric shorting in a switch. Ask an electrician, that is safest if you do not have experience with electricity.
Posted on Jul 29, 2017
zaids
  • 456 Answers
SOURCE: The ?Check ? indicator lamp is flashing, but hoses & filters look good
complicated
Posted on Dec 17, 2007
  • 1294 Answers
SOURCE: Miele WT 945 Washer Dryer - Spin not working + Water Inlet/Drain Light Flashes
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Your filter of the water inlet valve is accessible outside the machine; it is at the water entry point. Close your faucet & check this out; this gets clogged often.
Hope i am helpful...... Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 25, 2008
mgprice
  • 744 Answers
SOURCE: Miele Washing Machine Code: Check drain
This means that the drain attached to the pump is clogged, remove the drain plug check fro debris and replace...you should be good to go.
Posted on Jun 23, 2009
  • 177 Answers
SOURCE: Miele Novotronic W 833 won't drain
hi,
if your washing machine drains into a spigot in the u bend under your sink you will probably find a blockage here. you need to remove the drain hose and have a look in the hole.
if not when you remove the fluff filter have a look in the hole and make sure the drain pump turns freely. you can also run a drain spin cycle with the fluff filter removed and make sure the drain pump is working.
Posted on Jun 14, 2010
Testimonial: "Thank you!"
  • 251 Answers
SOURCE: miele w435 soft-tronic check drain check inlet
Hi - Try this empty the trays out of the washer - remove bottom wash arms by pulling upwards - below tha is a steel mesh - turn the plastic handle to unlock & remove the mesh - on the left of the tub locate a steel clip - below this is the housing for the pump - unclip & lift upwards - you will get a rush of water its ok - then clean the foodstuffs etc from in here as the propeller or impellar is found - turn machine on as the machine will a;lways start with a pump run - switch off after 20-30secs - check & assemble - try & see if it will work.
Cheers
Posted on Jul 02, 2011
After washes it displays check detergent. some washes are also not spinning properly and cloths are still quite wet. Can you help I have a miele gala grande w 3000
Hi dear.
Basically you can check fluff filter otherwise you may need to have a technical assist. Fluff filter located on front LHS bottom corner of your machine.. Open plastic cover. Place small bowl under fluff filter area to collect about 2 Lt of water. Slowly turn fluff filter anticlockwise to let it drain remaining water in there.. Then remove it and check for blockage. ( Step by step You can get full instruction from your machine's user manual on cleaning and care section.) If that does not solve the issue you may call Miele to assist you or local repairer. I hope that helps.Thanks.
Jan 16, 2016 | Miele Washing Machines
Premier 300 Not spinning
Check if the drain hose is blocked. Check the wires aren't loose on the drain pump. If all that's ok you will need to replace the drain pump.
Jul 08, 2013 | Miele Novotronic Premier 500 Front Load...
Miele Touchtronic w1203 , the intake and drain fault indicator lights are both flashing at the same time
Seems that the inlet valve or water flow is low , check the inlet flow or check for clogged filter.
Also check the lint filter and the cache filter. remove and clean drain pump. This must solve the issue.
Jan 17, 2013 | Miele Washing Machines
Miele 3204 won't spin or drain
Dec 02, 2012 | Miele Washing Machines
hi,
Jun 14, 2010 | Miele Novotronic Premier 500 Front Load...
Miele novitronic w830. Drain wont work. I've cleaned the outlet of dirt and the wheel inside the outlet is spinning freely. Reggadles, red light comes up.
Have you tried checking the drain spigot under the sink where the waste hose connects as it can be blocked at this end?
Try draining the unit into a bucket instead of the sink this will eliminate the washing machine as being the problem if it works ok.
is the drain pump actually turning? select drain or drain spin and have the fluff filter (outlet) removed so you can see if it is turning. if it isn't turning there maybe a broken wire to the drain pump causing it not to turn or the drain pump is jammed with something although you mentioned you could spin it freely.
hope this helps
Jun 01, 2010 | Miele Novotronic Premier 500 Front Load...
Miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic Premier Plus washing machine drain filter
yes - use a rubber mallet to separate it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 07, 2009 | Washing Machines
Miele Novotronic Premier 500 Front Load Washer Logo
43 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
