Question about Stihl Garden
Vibration coming from cutting blade through the machine Stihl hl75k
I have cleaned out the cutting mechanism and greased the interior workings. Vibration is still there
  • Stihl Master
  • 1,807 Answers
Do you have bent blades.? Try removing the 'driveshaft' and adding a coating of grease, the shafts can become dry within a plastic liner and start to vibrate
Posted on Jan 02, 2015
I have a 2001 Hyundai Tiburon, the drivers tail light will go out/on if I hit a bump 2 mechanics have changed the bulb checked the fuse and wiring and can not figure it out. Anyone had this issue?
Corrosion of the bulb socket that holds the bulb in place. Try cleaning out any corrosion and use dielectric grease in the bulb socket. Do not use any other type of grease. If this does not work, you will have to buy new bulb sockets.
Aug 17, 2015 | 2001 Hyundai Tiburon
Took my ybr125 to Canterbury...on the downhill drag past Boughton I really gave it beans and suddenly the engine cut out and the engine management light came on for about three seconds and went...
Since the YBR was introduced in 2005 I am going to go out on a limb and say it is computer controlled. Being a single I would also ask how much vibration is involved at RPM?
I would take the following steps; Check mechanical connections of all wiring especially any held against engine or frame areas where corrosion or vibration may cause poor conductivity. Check the spark plug connection also.
Be sure to check all the grounds as these are often overlooked. Remove the ground terminal, clean, grease and reattach. If the problem reoccurs then you will need to access the computer for any codes.
Mar 07, 2015 | Yamaha Motorcycles
Makes squealing noise (tyres?)
Most commonly, that sound would be coming from your brakes. Have you had them checked or replaced recently?
Brakes will squeal if they get worn down too far and require brake pad replacement. Sometimes they will squeal in perfectly harmless condition such as when they get wet, which should clear up quickly as they dry, or if they experience too much vibration. New brake will also sometimes come with either gaskets, metal clips, or a sort of anti-vibration grease or putty to reduce squealing from harmless vibration.
In any case, I would recomend having somebody knowledgable (or service center) check the brake pads for wear and replace if neccessary.
On more rare occassions, the squealing could be coming from other sources such as being in need of chassis lubrication, axle grease, and so forth. Most more serious mechanical wear or failure would sound more like a grinding noise.
Oct 15, 2013 | Land Rover Cars & Trucks
How to fix a door latch on a 1994 nissan pickup
I just joined 10 minutes ago.........I think I can help you.
Use a spoon or wide screwdriver to pop the plastic rivets that hold the interior of the door on. Takes some courage as they dont come away easily, about 8 in all.
1, Remove the window winders, by either pushing the "ring" that touches the interior till it stops and then slide the winder off the toothed stub.pop the cover off and use screwdriver/socket to remove winders.
2, Use old eating knife or wide bladed screwdriver around edge if soft interior of door and pry/pop the hidden plastic rivets, releasing the soft interior away from the metal or the door.
3, You may have to twist off the latch, just like a bottle cap.
4, You will see the wire coat hanger type metal that connects to the latch and locking mechanism.
If you have some grease with you you can also grease up the mechanisms for the lock, lock release, window, mirror.
That's how it is on my Volkswagen.
Good luck, Dave
Apr 02, 2013 | 1994 Nissan Pickup
How do I clean the stainless steel interior of my electrolux icon microwave
Hello - Interior cleaning after convection, mix or broil cooking:
Spatters may occur because of moisture and grease. Wash immediately after use with hot, soapy water. Rinse and polish dry. Harder to remove spatters may occur if oven is not thoroughly cleaned or if there is long time/high temperature cooking. If so, you may wish to purchase an oven cleaner pad with liquid cleaner within it-not a soap filled steel pad-for use on stainlessor porcelain surfaces. Follow manufacturer's directions carefully and be especially cautious not to get any of the liquid cleaner in the perforations on the wall or ceiling or any door surfaces. Rinse thoroughly and polish dry. After cleaning the interior thoroughly, residual grease may be removed from the interior ducts and heater by simply operating the oven on 450 F for 20 minutes without food. Ventilate the room if necessary.
Interior cleaning after microwave cooking:
Cleaning is easy because no heat is generated to the interior surfaces; therefore, there is no baking and setting of spills or spattering. To clean the interior surfaces, wipe with a soft cloth and warm water. DO NOT USE ABRASIVE OR HARSH CLEANERS OR SCOURING PADS. For heavier soil, use baking soda or a mild soap; rinse thoroughly with hot water. NEVER SPRAY OVEN CLEANERS DIRECTLY ONTO ANY PART OF THE CONVECTION MICROWAVE OVEN.
Nov 09, 2012 | Electrolux E30MO65GSS Convection Microwave...
The interior of my euro-pro kitchen rotisserie convection oven model TO241R needs major soot and grease cleaning. Is there a way to clean it on high temperature setting? If not, please recommend a...
Most toaster ovens don't have a self clean function, because they are not made of the same sturdy metal that full ovens are made of. Clorox Clean-Up works pretty well if you spray it on the grime and let it sit for 5-10 minutes before wiping it away. Let it sit longer for tougher dirt.
May 03, 2011 | Toaster Ovens
Vibration problem
Bad SteadyShot mechanism in the lens assembly. May be dirty or broken. If you are able, you can try to clean the mechanism, but it is very fine work. Better to let it done by professional.
Aug 17, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
2004 Buick Lesabre, drivers door hinge seizing
Grease will not flow into the interior of the hinge joint. Lube with WD-40 first to wet the area, work the door back and forth, then lube with a few drops of engine oil, again work the door. Wipe the hinge dry after a few minutes, and again the next day. Grease the door-position holder, the wipe clean after a few door moves.
Aug 08, 2009 | 2004 Buick LeSabre
Garden Logo
118 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
