Question about Toys
Repair Green machine - The frog band
Not working when switch on
    Problem Solver:
  • 9 Answers
Replace your switch.
Posted on Sep 07, 2014
Can you repair my green machine .....the frog band ???
sadly we do not d repairs to any thing here only suggest fixes
Nov 07, 2016 | Baby Gear
On/off switch disengages unpredictably
re: Delta 10" Bandsaw (model BS150LS)
My green ON and red OFF buttons are faulty. Sometimes pushing OFF doesn't turn it off (dangerous!!) I've pulled the on/off switch from the machine and have taken it apart somewhat. It seems to just be a physical flaw in the cheap plastic part. If you take the on/off switch in (pull off the 4 wires from the back) and take it to an electronics place, they should be able to give you a replacement. Maybe no one that fits the machine, but something that will at least work. Shame on Delta, shame. Used to be a respectable name but now it's all just cheap Chinese junk inside.
Nov 29, 2011 | Delta 28475X Industrial X5 14 inch Band...
The screw to used to move the frog to adjust the throat is missing. Can I get a replacement? Is there another part of the adjustment assembly missing?
Auctions and search engines.
Some plane Mfgs. had custom threads made. Modern bolts and screws from the hardware store may not work. Take the plane to a genuine hardware store where someone will help.
There are typically 2 slotted machine screws that secure a frog to the plane.
The plane will work fine without the slotted frog adjustment screw near the brass thumb wheel.
Really old metal planes had no frog adjustment screws.
The new frog adjustment feature did boost sales though.
If the threaded bolt for the brass thumb wheel is missing it will need to be replaced so the cutter can be easily adjusted.
Jan 20, 2011 | Fulton Tools & Hardware - Others
Green drum doesn't work
there is a small connection underneath the drumpad itself the chances are it is loose ...if you do a quick search you will find they are very easy to take off and repair
Apr 03, 2010 | Nintendo Rock Band for Wii
When swiched on, the screen displays green vertical bands which almost obscure the picture. By switching off and then back on, the green bands disappear but the vertical edges on the image are very...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi
Most likely a power supply component has aged and thus changed value and/or failed. Take it to a reputable repair person.
Mar 13, 2010 | LG RZ32LZ50 32 in. LCD Television
Tv works , red color band is good the green and blue are stagard
Sounds like the convergence IC's are bad. You'll need to contact a local tv repair center and ask about it. They usually run about 25 bucks a piece (give or take a few) and you'll probably need both of them replaced. If your semi-technically inclined you might be able to repair your self with the right equipment and service manual for that specific tv.
Oct 26, 2009 | Toshiba Televison & Video
Bugaboo Frog Flat tires
Any bicycle shop will be able to repair the tires for you.
Apr 06, 2009 | Bugaboo Frog Stroller
Using the Leapfrog click start TV computer game, the TV scrolls.
In the battery compartment to the cosole there is a switch, one is for the US. switch the lever to this side and it should work fine
Jan 14, 2009 | LeapFrog Leap Frog Clickstart My First...
Toys Logo
640 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
