Question about Compaq Presario 700 470024-192 Notebook
Wireless doesn't work on f700
I was using the wireless yesterday, it worked fine then i turned it off. when i turned it on again, no matter where I set the switch, the light stays orange... out of frustration, i switched it then hit it... and magically the light turned blue. ????? turned off the computer and turned it on again today, and it's not working again. does anyone know what to do? please help.
  • ognip2007 Jun 20, 2009
    Thanks! This all is over my head, but the detailed instructions really helped. The device manager says that the WLAN driver is working properly so I guess that the internal network adaptor is NOT secured which would explain why hitting the computer worked once. Thanks again!!! Btw, I turned on my computer this morning and the wireless is working... This was all a mystery to me, but not anymore. THANK YOU FOR YOUR HELP!
    Scholar:
  • 94 Answers
The internal network adaptor may be fragile, and not secured properly. However, I would not suggest you try to secure it as it may break.
So, just make sure your wireless LAN device driver is properly installed. TO check, right click my computer, properties, then "hardware" tab, then device manager. There, check for your driver under "Network Adaptors" and see if it is properly installed.
If it is not, you can re-install it from the company's support& download site.
If it is installed, go to a more experienced techician to securely fasten the internal network adaptor in place.
Posted on Jun 19, 2009
JBL BP600.1 protection
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Using an ohm meter to the sub will confirm whether its bad or not. Invest in a cheap test set of 6.5" speakers.
.A thumbs up would be greatly appreciated if this answer is helpful to you.
Jun 02, 2013 | JBL BP600.1 Car Audio Amplifier
I recently got the Gateway NV52L15U Laptop and the Wi-Fi has been working fine. Yesterday when I got on the computer it would not let me connect saying I need to "Turn on wireless capability." When I go to...
Okay, i finally have found a solution to this problem, it may sound crazy but hear me out and give it a try. Turn the computer off and turn it back on(admittedly i stumbled upon this trying to enter the bios settings). Then proceed to hold down the function key and press all the buttons on the top line of the keyboard (you probably only need to press the wireless button but hit all to be sure). the computer will idle and take a little longer to come on but when it does the wireless should be working fine again. Also try pressing them all without holding the function key to ensure.
Feb 03, 2013 | Gateway Computers & Internet
I have a D-link DSL-2750U router worked fine till yesterday, but now its power led keeps on giving a red light it should give green a second or two later but it keeps givings
Reset router. There are two resets. A simple push reboots and holding it in clears all custom settings. Try the first.
This is a quick fix and usually does it. Test with network cable and work your way backwards to modem if you still have problems.
Nov 11, 2012 | Computers & Internet
My Dell desktop using Windows XP can't connect to my Belkin 5720 router but my laptop still works?
This sounds like a hardware failure, but just in case go to your computer Control Panel-Network Connections(Network and Sharing Center for Vista and above), and check your Network adapter settings. If your Network card is not showing, you may have a driver issue, or a bad NIC (Network Interface Card). It shouldn't matter that your router says" wireless hardware not detected", because you are hardwired from the computer to the router. I would check to see if you may have turned off, or blocked Ethernet connections on your router, I would then change my Cat5 (Ethernet) cable, and finally open the desktop and change out the NIC (Network Interface Card).
Mar 24, 2012 | Belkin Computers & Internet
Wii console not working correctly
When you connect to the internet wirelessly and Wii Connect24 your Wii will stay connected and recieve messages, updates, etc. That is why the disk area stays blue and the amber light stays on. Sometimes this will create a power failure. Just unplug your Wii from the wall and let it rest for a few minutes and plug it back in. The problem should be solved.
Feb 22, 2010 | Nintendo Wii Console
Orange Livebox working fine yesterday morning, now doesn't
have you check your phone line also go in to the admin settings and re put your username and password back in it should sort out as i've had the same problem if it don't work get back to me thanks
shaun
Mar 16, 2009 | Computers & Internet
Voyager tail lights stay on
brake light switch or a headlight switch
Nov 11, 2008 | 1995 Plymouth Voyager
Panasonic SC-PT950 Wireless Speakers Question
It is pairing process again.
Inside the Main set operating instruction can help you solve it.
Aug 13, 2008 | Panasonic Home Theater System System
2Wire router
if your wireless connection is not working even if the wireless light is lit up on ur 2wire modem/router....try to delete the 2wire network from the prefered list...go to network connection, right click on wireless netwrok connection, go to properties and click on wireless network..select the 2wire netwrok on the prefered list and remove..reconnect to the network by clicking on view available wireless netwrok and select the 2wire network again...if its asking for a WEP key or password take a look at the bottom on the modem a 10 digits number enclosed in brachets..thats the network or wep key. access 192.168.1.254 and click on home network, got to wireless settings---edit settings...change ur wireless channel to 10 adn power settings to 10, save ur changes=)...ohh and by the way make sure that the wifi switch of ur laptop is turned on=)
Jun 01, 2007 | 2wire 2700HG-B Router (2700HGB)
Compaq Presario 700 470024-192 Notebook Logo
294 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
