Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
How can this process be reversed? I formatted my drive with a mac OS X leopard, and now I can't find it when I plug it in my PC. (It has been used as a Time Machine, therefore everything on it is deleted, but the mac-files) I can see on the info of the drive that it is mac-formatted. I've tried the walkthrough on the Seagate internetpage, but without any luck. - Even though the file is extracted in the drive. Has anyone got an idea how to make it work on a PC again? Thanks
  • 484 Answers
Do you have the little jumper switchs set to master or auto-detect? Once that is done, you might try to find an older DOS 6.2 setup disk 1, and use FDisk, to low level format the drive to FAT32 format, then put Windows back on it.
Posted on Jun 19, 2009
My IMac g4 has a not enter sign logo with flashing folder , after I installed a new 250GB hard drive that has OS X 10.5. I even updated my RAM up to 1000 GB. When I re-installed the old drive it work, but...
The folder and do not enter sign means that the drive is not compatible. I'm going to guess that the drive came out of an intel Mac that had leopard loaded on it. This is not going to work with a PowerPC Mac. Do a clean install of leopard and you should be fine. I believe g4's go up to 10.5 and g5's go up to 10.5.8.
Nov 14, 2012 | Computers & Internet
Tip
Formatting an external hard drive with Mac OS X's Disk Utility
Formatting your new external hard drive is not as difficult as you may think. In fact, you don't even have to be a computer techie or uber-Mac geek to perform this procedure successfully.
The tool you would use, to format your drive within your Mac OS X system, is the built-in utility application called Disk Utility.
Disk Utility is Apple Inc.'s defacto utility application, for performing disk related tasks within the Mac OS X volume.
From creating new images, to burning CDs and DVDs to formatting hard drives, Disk Utility performs well enough to keep not only your Mac OS X volume on your hard drive error free, but keep your hard drive healthy and error-free as well.
I could go on in detail, admirably describing more features of this versatile Mac OS X tool, but the purpose of this FixYa tip, is to show you how to easily format your external hard drive. So that is where I will take you now.
There are generally two formats in Disk Utility that you can use to effectively format your hard drive.
Mac OS Extended (Journaled) - if you want a Mac readable hard drive only
MS-DOS (FAT 32) - If you want your external hard drive to be read by both Mac and PC.
--STEPS FOR FORMATTING YOUR HARD DRIVE WITH DISK UTILITY--
• First, make sure your external hard drive is connected securely to your Mac and is turned on.
•Next, from your desktop, click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities* folder.
(*You can also get to the Disk Utility application via Applications > Utilities folder)
• Now, locate and launch the Disk Utility application.
When Disk Utility opens you will see a left side window, which will show
all connected hard drives and optical drives. It is here that you
should see your external hard drive listed in that window.
• When you locate it, simply select it and then select Partition
from the tabs on the right hand side.
• Change the Volume Scheme from Current to 1 Partition
• Make sure to provide a name for your new external hard drive.
• Select Mac OS Extended (Journaled) from the Format
drop down menu, for a bootable Mac only external hard drive.
• Or select MS-DOS from the Format drop down menu, for a bootable Mac & PC external hard drive.
From there, click the Options button, located toward the bottom of
your window.
This will open a partition scheme selection window as seen in this screen shot:
• Select GUID Partition Table for bootability on a Intel processor based
Mac.
• Or select the Apple Partition Map for bootability on a PowerPC based Mac.
• Click the OK button.
Finally, click the Partition button and allow Disk Utility to format your new external hard drive.
When this process is complete, you now have a newly formatted, ready to use hard drive.
Believe it or not, this process can be completed faster than you think.
Using this method with Disk Utility, I was able to format my new 1TB Iomega USB external in less than 20 minutes.
Final Note:
I used the external hard drive as the focus for showing you how to format and prepare your hard drive for use on your Mac, but this feature can also work with internal hard drives as well.
For more information about some of the disk repairing features of Disk Utility, here is a great support link for this nifty and quite effective Apple utility for the Mac OS X platforms:
Using Disk Utility to repair a disk
Thanks for reviewing my Mac OS X Tip!
Regards,
-Mactechtrainer
on Feb 11, 2010 | Computers & Internet
How do I format my WD Elements SE 500GG for Snow Leopard for a MacBook?
To format the drive for MAC OSX
1. Connect the drive to your computer.
2. Open Disk Utility. (Applications folder > Utilities folder > Disk Utility). Select the hard drive in the left hand column and click on the Erase tab.
3. In the Volume Format drop-down menu, select Mac OS Extended *.
4. Once you have selected the format and have named the drive, click on Erase. You will be presented with a 'Are you Sure' dialog.
5. The drive will format and upon completion will be available for use.
Note: * For the best performance, we recommend using Mac OS Extended format. However, if you will be transferring files between a Windows system and a Macintosh, format the drive as MS-DOS (FAT32) or use a program such as MediFour
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 23, 2011 | Western Digital Computers & Internet
My macbook pro running leopard 10.5.8 will not recognise my hitachi 320gb external hard drive
Find the drive and make sure it is formatted as a FAT32 drive. Mac computers only recognize drives in that format. If it can't be seen at all, try plugging it into a PC and then formatting it as FAT32. It should then be recognized by a Mac computer.
Mar 08, 2011 | Computers & Internet
My macbook shows a white screen and a sound only and after that nothing happens
JUST TRY TO FOLLOW THE STEPS IT WILL BE VERY HELPFUL
Many computer shoppers choose to buy a Mac not only to use OS X, but Windows as well. That is one strong advantage that Macs have in the Mac vs PC war. Apple computers are capable of running Windows, either through Bootcamp or virtual machines.
So, why aren't Windows PC's capable of running OS X? Well, Windows PC's are capable of running OS X. But, it is against Apple's licensing agreement to do so. Thus, this article is intended for educational and demonstration purposes only. If you want to run OS X the best way possible, get a Mac.
*In order for this to work, your computer must have a processor that supports virtualization. If it does not, you may receive errors. For the most part, any newer processor lines: Core 2 Duo, Quad Core, and Core i7 should all work fine.
But, don't expect to not get errors if you are using an older Pentium 4 machine. The processor must be Intel and not AMD*
Because we will be installing OS X on top of Windows through a virtual machine, the first step is to get some virtual machine software. For this demo, we will be using VMware's Workstation 7.
If you do not feel like purchasing Workstation 7 at this time, you can get a limited trial here. The download may take a good half an hour to complete. Workstation is a 512MB file.
Upon download, go ahead and install Workstation 7 onto your computer. The installation process is very simple just launch the installer, and the VMware installer will guide you through the rest.
One thing to note, when it asks your if you want to do a custom install or a typical install, choose typical install. After the installer finishes, restart your computer
Now that you have Workstation 7 installed, you need a pre-configured VMware virtual machine file to install Snow Leopard on top of. Download this file (alt download) and save it to your desktop.
After you have the pre-configured virtual machine file downloaded, you will need to extract the files using WinRAR or another archive utility. If you do not have an archive utility, you can get WinRAR here.
Note: This file is just a disk image framework, no viruses or anything like that. VMware Workstation uses the disk image format to save and contain virtual machines.
Time to start installing Snow Leopard. Launch VMware Workstation by using the path Start > All Programs > VMware > VMware Workstation. Open up the VMware disk image framework that you just downloaded and extracted.
Select File > Open. Navigate to your Snowy_VM folder, open it, open up the next folder that says "Mac OS X 10.6 Server (experimental).vmwarevm, and choose the 2KB file that is named Mac OS X Server 10.6 (experimental). Click the open button to load the virtual machine.
From the Mac OS X Server tab in the VMware Workstation window, click the edit virtual machine settings icon. You may adjust the hard drive size, memory, etc, to your liking.
Select CD/DVD (IDE) and under the Connection settings, select Use ISO Image File. Click the Browse button and navigate to the Darwin_Snow.iso which is located in your Snowy_VM folder. Click the Open button to select the virtual machine.
Now it's time to power on the virtual machine. Click the Power on this virtual machine option. As soon as the process starts, hold down the F8 key on your keyboard. You should be prompted with a boot menu screen.
If you have not done so already, insert your OS X Snow Leopard Install DVD into your computer's CD/DVD drive. So far, you have loaded a workable virtual machine and framework into VMware Workstation.
Now it's time to actually install Snow Leopard onto that virtual machine disk image. You should see some settings icons located at the bottom right portion of the VMware window. Right-click the icon that looks like a CD and choose settings from the pop up menu.
Go back into the boot screen and select the option C Boot from DVD. Press the F8 button on your keyboard for advanced options and type "-v" without the quotes and hit enter. Now, VMware Workstation should boot your Snow Leopard install disc. It may take a couple of minutes to load
That's all there is to it. You should now be at the normal Snow Leopard install screen. Click continue on the first screen that comes up. On the second screen, click the utilities option in the install window and select disk utility. Use disk utility to change the hard drive format type to OS X Extended (Journaled). Exit disk utility and let OS X install completely.
Upon install of Snow Leopard, your virtual machine will restart. After it restarts you will need to do a couple of things to get into Snow Leopard. Select CD/DVD options, like you did before, and use the Use ISO Image File option.
Sep 26, 2010 | Apple MacBook Mac Notebook
I have macintosh so when i put the external hard drive it works with no problems but when i want to get sth as a backup from windows ,,the pc cant see the hard drive,except if i formated the hard drive,how...
Your Mac can read Windows hard drives, but it can't write to them. There is a free software to allow the Mac to read Windows formatted drives, but it's a bit technical. You have to install Mac-FUSE (search Google) and NTFS-3g (go to www.macupdate.com and search for NTFS-3g).
There is commercial software that will allow Windows to see Mac OS Extended (HFS+) formatted hard drives, including MacDrive. I believe it's about $50. If you are using Windows on your Mac via Apple's BootCamp feature and you have Mac OS X 10.6 "Snow Leopard", make sure you install the drivers from the Snow Leopard disc that will allow Windows to read Mac formatted disks.
You can also format your external drive as FAT 32 from your Mac (use Disk Utility in /Applications/Utilities). But FAT is ancient. That's MS-DOS's filesystem. It's not great. But if you want to do it, use your Mac (yes, your Mac because it can format larger drives as FAT than Windows can):
**WARNING***WARNING*** this will ERASE all data on the hard drive. Back up first!***WARNING
1. Click the magnifying glass in the upper right corner of your Mac's screen.
2. Type: Disk Utility
3. Click the Disk Utility Application that comes up (or press Return if you're using Mac OS X 10.5 or 10.6).
4. Click the icon of your external hard drive.
5. Click the Erase tab.
6. Change the format to FAT 32 and Give the drive a one word name, no more than 8 letters.
7 Click the Erase button. ***WARNING*** This will erase your drive!
8. Now the drive can be read by Windows or Mac OS X.
Whew! Lots of info. I hope this helped. Please let us know if it helped. Let us know if it didn't, too. We'll do our best to help. If this helped you, please rate me.
Bot
May 28, 2010 | Apple Computers & Internet
Leopard OS
Is the hard drive SATA or IDE. On IDE, I know you can use delpart. Locate a SATA tool to wipe the partition of SATA drives. Install LEOPARD as usual then after rebooting.
Jul 25, 2009 | Apple Power Mac G5 Desktop
Im trying to copy from mac to pc using seagate removable hard drive and its not working? When i plug the Seagate into my PC nothing happens
The hard drive volume format is only for MAC. Check the volume format if it is MAC OS Extended or MAC OS Extended (Journaled). If it is, then change it to MS DOS to make it readable and writable to a PC and MAC OS
Jul 08, 2009 | Seagate 500GB Barracuda ES.2 SATA 3Gb/s...
I can't install any OS because by DVD drive doesn't detect it!
have you tried using fdisk and delete partion then make new partion and set active partion then boot from CD which will then format drive then install OS
Jun 24, 2009 | Computers & Internet
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
130 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
