Question about Dishwashers
Cuisina dw007 when you turn on E4 and beeping displays
2 Suggested Answers
SOURCE: e4 code on dishwasher
Hi
Sorry, I still don't know what the problem is. I've been washing up by hand! Looks like I will have to call an engineer out at some point .... I'd better save some money :-)
Janine
Posted on Sep 03, 2008
Dishwasher is beeping and showing code E4
There really isn't a standard for dishwasher error codes. Need to know the manufacturer and model number to proceed. This could be a fault with the float in the fill or overflow sensing that there's too much water. You might try removing the water and letting the machine dry out. Could be too much suds from combo cheap detergent and rinse agent.
Feb 27, 2015 | Washing Machines
Hi... I just bought Electrolux Dishwasher ESF2433W. When i first time turn it on, light at "Normal" button keep on flashing with beeping sound. After checking the trouble shooting manual, it actually refer...
E4 Overflow
Sometimes during trasport it is possible that styrofoam float mechanicaly activated overflow microswitch. So, you should check complitely overflow system.
At any time, if overflow micro-switch act and keep for longer than 2 seconds, the E4 would occur. When E4 occurs, the drain pump will run until flowmeter keep motionless for 2 minutes (if the model with the pressure switch (83/63),drain pump would run till the pressure switch reset and continue draining for 60 seconds.) and all the other components will be stopped immediately. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown. Note: Priority level of E4 is the highest. E4 operation is valid after other error operations have done. When E4 operation has done, all the others are invalid.
Dado
Feb 20, 2015 | Electrolux Dishwashers
E4 error code comes up when you turn on dishwasher
Hello.
This code means an error code. That the
dishwasher electronic control has detected a condition it needs to check. When you see a code, follow these steps to solve the problem:
  • Press "Stop/Clear" to clear the display and stop the beeping if any.
  • Reprogram the dishwasher.
  • If the code still displays, turn off the power to the dishwasher at your breaker box and wait five minutes and clean all part (area) that are open to water carefully before turning it back on.
Thanks for using fixya.
Jul 31, 2011 | Dishwashers
Dryer turns off after approximately 20 seconds. Error code E4
E4 Tumbler rotation failure If during a cycle the tumbler rotational speed drops to 0, all outputs will be turned off and error code E4 will be displayed.
May 17, 2011 | KitchenAid KHGV01RSS Dryer
I have waves split air condition its cooling is good but some time in the display e4 is coming and that time my ac is not giving cold air what is this.tell me some one.
The e4 that displays on your air condition come up simply because there is an error during the operation of the system. E4 means Error 4 which is a code that is interpreted as low pressure switch.
E4 simply means there is low pressure switch, the pressure switch turns on automatically inside the air condition, so when you turn it on sometimes the switch jams and does not open so the air condition will be on but would not get cold because the switch jammed and it displays an error signal to let you know there is a problem in the system.
Take care
Jul 09, 2010 | Heating & Cooling
Oven control lock beeping along with F3:E4 flashing on the display
Hi-- The code described; F3 E4  indicates an open circuit- oven sensor.  As far as oven problems go this one is easy to fix. -------Unplug sensor and check resistance. Normal is around 1100ohms. ---If open, then replace with new part.  <This will solve the problem>.  You did not provide any other information besides 'beeping' and 'F3:E4'.  A simple Model # from the tag on unit is required for any service or information.  However, since this is a specific fault code, the oven temperature sensor is the most likely suspect. Please acknowledge this post. Solution is to replace the oven temperature sensor.  Thanks-  Ed
Mar 30, 2010 | KitchenAid Ovens
I get an E4 error message when I turn on the machine.
The first thing I would check is to see if you turned the water valve on under the sink.
Jul 22, 2009 | Danby DDW497W 22 in. Countertop Dishwasher
Continuous beeping and code E4 on display
"E4" code relates to the overflow detector There appears to be an internal sump. Lean the machine back about 35-45 degrees to remove the excess water from the dishwasher. It might be messy so be prepared. By design the sump collects water from condensation i.e. (Cold outside machine wall, hot inside machine wall) hence condensation builds up and is suppose to and should evaporate in the right environment. Placement and installation locations play into a big part of the design.
You will notice by observation just in the center there is a polystyrene float. This is what activates the overflow switch which throws the error code.
This problem is simple to fix, just take off your kitchen plinth and turn off the dish washer power. then at the base of the dishwasher there are 2 plastic clip access panels, take a blunt screw driver or knive to help you ease out the plastic panel. once this is off, simple take a dish cloth out mop out the water, particularly from the left hand side as this is where the sensor is. Once dry (ish) replace the panels and switch on - DONE! its that easy
Jan 19, 2009 | Dishwashers
Kenwood dishwasher
E4 means overfilled which in practice means there is water in the tray at the bottom of the machine. Lean the machine forwards and the water will drain out and clear the fault code. chances are it will fill up again so if it repeats the leak will need to be found.
Oct 27, 2008 | Kenmore 46123 Stainless Steel Electric...
E4 code on dishwasher
Hi
Janine
Sep 02, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
