Rih-3267 Yellow timer light keeps flashing even when turned off
4 Suggested Answers
  • 35 Answers
SOURCE: Well when I turn on
well yes obviously the flashing red light means that if u do not turn off ur PS3 it will die. but depending on how long u have had ur PS3, it may be becuase the life span is almost over.
if u have not had for a couple years it is most likely a manufacturing error
u should send it in to sony before the warranty is up and have them take a look at it
Posted on Jul 27, 2008
SD Tech
  • 14553 Answers
SOURCE: the timer light keep flashing , tv won't turn on ws-65511 65 inch
Green light should blink if set unplugged for 70 seconds and go out:
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different s so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
SD TECH
Posted on Nov 03, 2012
SD Tech
  • 14553 Answers
SOURCE: My Panasonic. 27 inch triple play will not turn on
The unit is either in shutdown (self protection) or the unit is not making it out of standby===someone needs to look at the power supply inside the unit to check voltages etc.
Posted on Dec 14, 2012
I recently replaced the TY-LA1000 lamp but I'm getting a yellow flashing light that goes on every 5 secs.I made sure that it was installed correctly and tried resetting the timer by pressing + and - o
Yellow flashing light? Did you get any picture? Bet, not!
It means: your lamp door interlock is not engaged: did you forget to turn the locking knob? Did you install lamp compartment door? That might be the only issue. Lamp timer blinks 'red", while TV works normally. Reset the timer, it's gone, along with annoying message. Yellow means: interlock or thermal protection is off. Try to repeat lamp installation procedure. then, you'll find out your mistake. don't need to remove the lamp. It would be "red", if lamp won't fire up.
good luck,
Alex.
Dec 06, 2011 | Panasonic Televison & Video
My Sony tv will not turn on. The standby/timer light keeps flashing red.
Problem with the Sony Trinitron KV-J16PF 20" TV The standby/timer light keeps flashing red
Jun 07, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I am having problems setting up coralife aqualight power center
You need to plug them into the two yellow outlets, not the blue ones. The blue outlets are for night lights if you have them. Set the timer for 6 and stop at 12am. If you plug them into the two yellow outlets they should go on at 6 and turn off at 12, however If you also plug something into the blue outlets they will turn on as soon as the yellow outlets turn off, it's sopposed to switch from your day lights to your night moon lights automatically provided you got the moon lights plugged in the blue outlets. Hope this helps....
Jun 01, 2010 | Coralife Zilla Aqualight Power Center
When i turn on my PS3 it as it starts up a yellow light comes on
The yellow light is also know as the yellow light of death casued by a hardware failure. It can be casued ny over heating a bluray drive failure, a hard drive failure or even a powersupply failure. You know you have it when you power up the yellow light flashes then you hear some beeps then the red llight flashes. I would suggest returning it if you have that option or getting it fixed somewhere else as a last option.
Apr 16, 2010 | Sony PlayStation 3 40GB System
Reset tv timer pt-61lcx65 after lamp installation
MAKE SURE LAMP DOOR IS COMPLETELY CLOSED,THATS WHY POWER LIGHT FLASHES YELLOW
Jan 10, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Well when I turn on my ps3 the green light turns into a yellow light some people call this the yellow light of death after it goes yellow it turns into a flashing red light I try to repaet it but it keeps...
Jul 25, 2008 | Video Game Consoles & Games
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
