Question about Sharp 32SC26B 32" TV
When l turn on my sharp 32sc26b tv there is a plain screen
2 Suggested Answers
SOURCE: TURN TV ON JUST PLAIN
Do you see the backlight ever coming to the screen?
You will want to open the cover, disconnect the backlight inverter and try again to see if it will stay on even without an image.
If it does it's the inverter.
if it still shuts it's most likely (not guaranteed) either the power board itself or the main board.
A good tech should be able to test the power board independantly fairly quickly.
Posted on Jun 30, 2011
Is the Sharp 32SC26B 32" TV HD compatable
Refer its user manuals' specification page for more details.
Electro help
Oct 05, 2014 | Televison & Video
Failed signal
Yes, check the cable as your tv's tuner does not receiving signal. The BLUE SCREEN on most of this brand means you have no signal from an outdoor signal or so. Thanks for using Fixya.
Apr 03, 2014 | Sharp 32SC26B 32" TV
Audio Static on Sharp 32SC26B
Chances are your main board is bad, its where all the sounds are producted, a new board should correct the issue, its something you can install yourself with a screw driver, have the set unplugged for about a day before replacing the board so all the capacitors are discharged..you can get a new board at shopjimmy.
TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 09, 2018 | Sharp 32SC26B 32" TV
Audio static when using any power switches in house
You could try a power strip that has voltage spike protection in it, but to tell you the truth, TVs and other electronic devices are supposed to accept such interference without malfunctioning.
Dec 12, 2011 | Sharp 32SC26B 32" TV
TURN TV ON JUST PLAIN SCREEN (NO IMAGE), THEN HEAR A CLICK & TV TURNS ITSELF OFF- THEN ON AGAIN... CHANGED BATTERIES IN REMOTE & TRIED TO TURN TV ON DIRECTLY FROM TOP... NOTHING WORK. THIS IS A...
Jun 30, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My tv made a little noise and then the picture disappeared. The screen is black with a vertical line of picture approx 1/4 inch wide going up the middle of the screen. Is it fixable?
Generally this is not good news. Even in the event this TV is repaired, it will work very long. This TV has a horizontal problem. This is the most stressed area of any conventional TV. The Horizontal Output Transistor will need replace, the flyback transformer is bad, you have bad power supply with horizontal capacitors that are bad, and last, is a possible bad picture tube. This TV is not worth the effort or money to repair. Thanks for asking and show all hands of support!
May 20, 2011 | Sharp 32SC26B 32" TV
How to program a philips universal to a sharp tv and what code
Hello
Codes for Sharp with Philips universal remote are
0509 0913 0907 0603 0002
....... 0502 0224 0228 0202 0111 0813
You can also check with these codes too. These are common universal remote codes for Sharp
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Mar 20, 2011 | Sharp 32SC26B 32" TV
Color problem
Usually this is a problem within the convergence circuit. In all probability with a set under warranty, the entire board will be replaced or the whole set will be replaced. The only repair "delay" should be the time to get the replacement board. If hte set is within 60 days of purchase, I would request immediate replacement at the place of purchase.
Dan
Apr 30, 2008 | Sharp 32SC26B 32" TV
Slanting Picture
The yoke has probably come loose and tilted.. From the rear of the set looking on the back of the crt you'll find a copper wire wound magnet called the yoke. It terminates on the neck of the yoke with a clamp. With the set off slightly loosen the clamp and turn the yoke assembly in the opposite direction - key word here is slightly - and apply power to check the alignment.
Keep doing this until you achieve the alignment you want. And always remember to unplug the set between attempts.
Nov 05, 2007 | Sharp 32SC26B 32" TV
Sharp 32SC26B 32" TV Logo
15 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
