Question about Samsung Televison & Video
My samsung LE40A558P3FXXU 's freeview HD doesn't work
I have a indoors antenna with full HD but the freeview doesn't work and says HD not supported
  • 4 Answers
SOURCE: HD ready?
The TV is just HD ready (doesn't have the HD tuner built-in), you need a separate HD tuner connected to your TV.
Posted on Jan 09, 2008
SOURCE: RCA HDTV, indoor antenna and Dish Receiver 311
I want to use two (2) 311 dish receivers with only 1 outside antenna.
Posted on Jan 24, 2009
Shuttle83
  • 1139 Answers
SOURCE: what type of indoor antenna work best with this unit?cobytv/tf-tv
A simple pair of rabbit ears (standard dipole antenna) should do the trick. You will have to set the source input to NTSC/ATSC and connect the antenna to either the analog or digital F- connector inputs if you use a RF splitter you can use one anatenna for both inputs. In any event try this first.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Apr 06, 2009
oposky2006
  • 50 Answers
SOURCE: hd movie format supportet with samsung home theater
well, i think mpeg4 is the format u need. this format can be accepted by hd home theater. And u should use this video tool which can convert any video files to mp4. Besides, it can offer u mp4 hd format as output format. Then u will not worry about quality loss.
Have a try:
http://www.pavtube.com/video_converter/
Posted on Mar 11, 2010
  • 43 Answers
SOURCE: model #ds19310 only receives one
Yes it will help. Also try moving the antenna you are using to other parts of the house. I.E. near a window, that sort of thing.
Posted on May 05, 2011
Can't get Digital TV (freeview)
Change the input to antenna.
If it says cable:
On your Samsung remote is a button that says antenna. You want it to say AIR. Air is an ATSC tuuner that allows you to receive over the air HD with a pair of rabbit ears.
If it says AIR:
If it says AIR and you still can't get the HD channels. In the menu it will say Channel. In that sub menu it will say autoprogram. Make sure you have an antenna connecte to AIR in the back of the set and autoprogram AIR only.
Any questions respond to this post and I will respond.
Jan 12, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
My rca indoor antenna will not pick any channels up on my hd flat screen tv
Signal not strong enough in your area for this indoor ant...Does it work with an outdoor ant?
Nov 29, 2013 | Televison & Video
Can you show me how to connect up the scart and aerials up to the following so they operate correctly Samsung PS42C450 42-inch 600Hz Widescreen HD Ready Plasma TV with Freeview SAMSUNG DVD-SH893M 160GB...
hello firstly scart lead from sky box to tv1 in) this is at the top there are two AV inputs ,,,on the bottom AV slot this is where your DVD conects too).iff you are using sky you will not need aerial in back of tv as this is for analogue use such as indoor antenna or outdoor antenna or iff using horizon the scart lead will suffice for all goodluck
Mar 19, 2011 | Samsung PS42C91HDX 42 in. Plasma TV
HOW TO GET HDTV FOR SAMSUNG WS32Z308P
You will need an HD receiver (Freeview HD, Freesat HD or Sky). For Freeview HD you'll need to check whether it's being broadcast in your area yet. Check the freeview site
May 01, 2010 | Samsung WS32Z308P 32" TV
How do I setup my full hd freesat tv I have sky + do I take the dish cable out of the sky box or do I need another cable from the dish
If you really want to do this, well then you could use and antenna switcher, a small control box that the Antenna from the dish plugs into it and the Sky Box & Freeview each, plug separately into that box too, and then, you can select, which one the antenna is connected to. (Some even have remotes) OR you could simply "Split" the signal "IN" with an Antenna "Splitter" and run one feed to Sky & the other to Freeview. Now thats all amusing that you can get freeview from that Dish.
Feb 05, 2010 | Panasonic Viera TC-L32X1 32 in. LCD HDTV
How do i get my built-in freeview to work?
I have freeview inbuilt on my tv. I hav sky at the mo so hav the satellite dish but want to get rid of sky and just hav freeview. So how do I make freeview work? Do i need to buy some sort of cord/connection to hook up the satellite cord/connection to the tv?
Oct 14, 2009 | Toshiba 37RV525R 37 in. LCD HDTV
Dont not pick up freeview channels
if u pick up NON freeview channels, i think the antenna isnt good enough to pick up the signal..freeview requires a very good signal, very important.
If you think this isnt the problem rescan the channels
If you think the TV is faulty contact Samsung directly
Jul 15, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Televison & Video Logo
10 people viewed this question
Henry  Thomas
Henry Thomas
