Question about Mr. Coffee IDS76 Grinder
On off button
How do you turn this grinder on and off
Grinder manuals
The grinder should have come with a special wrench that fits the "nut" that holds the wheel on. There should also be a button to push to lock the shaft. With the grinder unplugged gently push the button in and turn the wheel till the shaft locks then put the whrech on the nut and spin it off.
Sep 07, 2014 | Craftsman 4 1/2 in. Small Angle Grinder
I just bought a hand grinder from a guy but don't know how to take the disc off . it has a button u push but no nut on the disc
If there isn't an arbor nut holding the blade/disc on the grinder you have a disc with the threaded center built into it. While holding the arbor lock button down you have to turn the disc by hand until it breaks free and spins off. It may be on vary tight as it is a self-tightening thread so the disc won't come off while you use it.
Feb 22, 2012 | Black & Decker Black And Decker 4-1/2"...
Grinder will not grind or turn on
will not stay turned on. have to keep hitting start button
Jun 28, 2011 | Cuisinart Supreme Grind DBM-8 Electric...
Hi, I'm trying to change the fiber disc on a DeWalt DW402 but after pushing the locking button on top I'm not able to unscrew the wheel. If I turn counterclockwise the wheel turns, but it seems I...
  • 1 Check the grinder before you begin. The newer discs on rotary grinders have patented buttons that allow you to remove the disc without any tools. You may have one like that. In models like this, there's usually a spot to depress and then remove the disc.
  • 2 Turn off the grinder before you attempt to remove and change the disc on your rotary grinder. If it's battery powered, put the grinder in lock position so you can't accidentally turn it on. If it's electric, unplug the grinder from the wall.
  • 3 Look for a nut in the center of the disc. This is a give away that you need to use your special wrench. Sometimes the grinder comes with a tool necessary to loosen and remove the nut. Other times you need to use a wrench.
  • 4 Lock the wheel into place before you begin. You can find a button or switch at the side or back that allows you to do that. When you lock the wheel in place, the disc remains still as you loosen the nut in the center.
  • 5 Remove the nut in the center with either the tool provided with the grinder or a shop tool and lift the disc off your rotary grinder.
  • 6Lift the disc off the rotary grinder. If you have different discs, remember to check for the best fit. Put the nut back on a different way for different discs. Check for a rim and indentation on one side of the nut and a flat side on the other. A visual inspection of the disc for the rotary grinder gives you information about the side to use.
  • Here is a diagram of your grinder and the tool you are looking for is number 50...
    http://www.ereplacementparts.com/images/dewalt/DW402_TYPE_6.pdf
    Jun 11, 2011 | Dewalt 4 1/2" Small Angle Grinder D28402
    How do you remove and release the quick grinder pad?
    There is a button at the front of the grinder usually black or red, depress it lightly and rotate the wheel (unplug grinder please) wait until you feel it fall into spot, depress tightly and hold then turn wheel and unscrew to replace pad. Reverse to reassemble.Good Luck....
    Apr 21, 2011 | Metabo ® 12 Amp 9000 RPM Model WE14150...
    I own a metabo 9-125 quick but can't don't know how to place the blade
    On the silver part on top of the grinder is a button , press this button and hold it down. now turn the blade until it stops moving, this locks the blade, keep holding the button down and turn grinder over ,and turn the nut counter clockwise, and remove it , take old blade off ,put on new one .it should go over the shaft and at the bottom on a "fit" Make sure it is on the "fit". replace the nut and tighten. If you dont get the nut tight enough it will loosen while in use and the disc you are cutting/grinding with will wobble and may even come off causing possible injury .
    Jan 29, 2011 | Metabo ® 12 Amp 9000 RPM Model WE14150...
    Whatever the setting is at the grind is always fine. What can I do to re-calibrate the grinder?
    Grind Adjustment Tools required: Large blade and medium Phillips head screwdrivers In order to adjust the grind, follow these steps (Refer to figure A): 1. Remove all coffee from the hopper. 2. Set selector knob to the finest setting (Espresso or Turkish) depending on the model. 3. Loosen both knob retainer screws in selector knob one turn only. 4. While pressing the bag switch, located behind the spout, press the START button so that the grinder will run during adjustment. 810 model - Press the ON or START button so that the grinder will run during adjustment. 5. With the grinder still running, turn the adjusting screw in the center of the selector knob slowly to the right until a slight clicking noise is heard. Immediately turn the adjusting screw to the left one grind setting. This is the finest grind obtainable. 6. Tighten both of the knob retainer screws. Once the ESPRESSO grind has been set (Turkish for Model 835, 875, 890), the other grind settings will automatically set correctly. 7. Press the STOP or OFF button. IMPORTANT: Always be sure the grinding burrs are not touching while the machine is running on the ESPRESSO/TURKISH setting. Otherwise serious damage to the motor may result. dr_buckhead.png
    Nov 19, 2010 | Grindmaster 810 T Electric Burr Grinder
    Grinder setting jammed won't turn
    HI
    When making adjustments to any grinder it should be grinding at the time. Rotate the adjustment setting to a larger number, say 10 an try again. Then if it starts, turn it down to the number you want.
    Nov 05, 2009 | Pasquini GMSC Electric Burr Grinder
    I don't know how to change the grinding blade on my makita angle grinder.
    There is a nut that you release from the middle of the grinder wheel, (grinder blade)
    This nut is flat and has four holes in it.
    You will see you are providing a spanner wrench to remove this nut. The wrenches' actual name is Lock Nut Wrench. It has a U shaped end with two pins sticking out. On on each side of the U shape.
    The pins are inserted into the holes in the flat lock nut, located in the middle of the grinding wheel. The wrench is laid flat against the grinding wheel, with the two pins of the wrench going into any two holes of the nut.
    At the top of the Makita grinder you will see a Black button. The button is pushed down to keep the grinding wheel from spinning. Holds the grinding wheel in place, as you turn the lock nut loose. When you release the button, a spring inside pushes the button back up out of the way.
    As you view the Makita grinder, Release Button towards the Back, grinding wheel towards you, the nut is turned to the LEFT, to loosen. It is a Left threaded nut.
    The grinding wheel spins to the Right. Using a left threaded nut insures that the nut will stay tight, due to the direction the grinding wheel spins.
    Oct 01, 2009 | Makita Usa Inc 9557PB 4 1/2" Angle Grinder
    How do you change the grinder disk. I have the tool with the two pronges that slide into the nut but the wheel keeps spinning. There must be a trick?
    On the top of the grinder there should be a button. hold that in while turning the disk (please have the grinder unplugged while you do this).
    The button wil drop further in when it finds the notch in the gear. This will lock the spindle, allowing you to remove the retaining nut.
    Apr 18, 2009 | Makita 9015A 5" Electric Angle Grinders
    Mr. Coffee IDS76 Grinder Logo
    24 people viewed this question
    Top Mr. Coffee Coffee Makers & Espresso Machines Experts
    Greg Cann
    Greg Cann
    Henry  Thomas
    Henry Thomas
    Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
