Question about Dell Precision 380 P4 Dual Core 3 GHz (99382) PC Desktop
Yellow Amber light on Dell Optiplex 390 not booting or display what to do?
How to solve this permanent Amber light on my OptiPlex 390 tower ,achine
  • Dell Master
  • 998 Answers
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Posted on Jan 02, 2015
  • 326 Answers
SOURCE: Dell optiplex won't Boot-up.. Orange light on motherboard
its going to rather your power supply or your motherboard has died, id try a different power supply first
Posted on Aug 11, 2008
oblivion2k
  • 150 Answers
SOURCE: Dell (ie optiplex 330) would not boot with the orange light on
Do you have a lot of accessories plugged in? They may have overloaded the power supply and if this is the case you will need to buy new power supplies. If this is not the problem, check to make sure that the computers have plenty of ventilation in the back. If they don't, they may have overheated and melted quite a few different components.
Posted on Feb 27, 2009
  • 700 Answers
SOURCE: I have a Dell Optiplex GX 260 that will not boot.
Try to set it to boot first in cdrom in bios setting then place a bootable cd in cd drive that will run in DOS mode. If this boots up with a command prompt. Then your hard drive has a fault, could be a corrupt files or missing files.
Post comment if it does not help so we can device another solution.
Posted on Apr 17, 2009
  • 3278 Answers
SOURCE: Dell OptiPlex GX270 mini tower won't boot
Reinstall (remove and reinstall) your USB devices.
Could be memory error. Remove and reinstall your memory modules one at a time.
If not, could be your motherboard.
Hope this helps.
Posted on Aug 17, 2009
SOURCE: No Display in dell optiplex gx280 & Fan speed is veyy high
GM from pakistan fsd problem in motherboard chepset......you should repare u r gx 280 or heat the chepset with heat gun ........
Posted on May 21, 2010
How to solve orange solid light on my dell GX520 when i boot it
Nana, A solid amber power button on your GX520, indicates a motherboard failure. The motherboard will need replaced. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Solid orange power button on Optiplex GX520
My Dell Optiplex GX520 will not boot Forums
Dell Optiplex GX520 amber solid light no power
Aug 05, 2016 | Dell Computers & Internet
Dell optiplex mini tower, when turn on the computer amber led lights blink with a , and will not startup
If the power light is blinking amber - The computer is receiving electrical power, but an internal power problem might exist.
Apr 25, 2014 | Dell OptiPlex GX520 PC Desktop
Gx270 tower mother board amber LED solid on
If the fan is not spinning this can be the issue ...but it can also be the motherboard itself ..if you have the possibility try to change the fan ..cause if it fails to start the computer will also fail cause the cpu it will shut down the system instantly if it has no cooler working ..(gets to the shut down temperature in one sec or so ) If it seams that it is trying to start ..but , like I said , it shuts down ..just try to change the fan ...but it may be a issue with the power supply or the motherboard as well...
Dec 18, 2011 | Dell OptiPlex GX270 Small Mini-Tower...
Dell optiplex desktop freezes up at boot screen. Says drive 2 not found. Bios setup is correct and boot sequence has been setup correctly. Was working before but now freezes up.
Swap out the ram one stick at a time, bad ram has been known to cause this type of symptom, the other thing to check is the motherboard, check the led light on the board is green, if not and it is yellow or amber indicates motherboard issues.
Aug 10, 2011 | Dell OptiPlex GX520 PC Desktop
Hello! I have a dell optiplex gx260 pc i am having a problem that my pc does not boot it does not show any screen nor any beep its backlight light orders are A OFF B Yellow C OFF D OFF i have...
If the power LED is flashing amber, there may be an issue with the power supply, if it is solid amber then the motherboard itself (or if it has an expansion card in a slot, maybe the card)
Jun 08, 2011 | Dell OptiPlex GX260 PC Desktop
IN dell optiplex sx280 model system we are using in this amber power led blinking continuly yellow color because of this not able to boot the system. kindly give the solution for the same
Hi there!
A blinking amber/orange light on the power button of your Dell Optiplex means a hardware failure. If you know how to strip down your computer to basic component, then I suggest you turn on with only the motherboard, processor, memory and PSU. If you are not familiar with this, I suggest you bring the computer to a qualified technician.
Hope this helps
May 09, 2011 | Dell OptiPlex SX280 PC Desktop
Computers & Internet Logo
247 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
