Question about Yard Machines MTD Gold 185 HP Lawn Tractor 13AJ771S004
Bolens 13am762f765 not charging battery - Yard Machines MTD Gold 185 HP Lawn Tractor 13AJ771S004
Model # 13AM762F765. Where is the solenoid located?
most are located on the back side of the dash . lift hood and look around where the starter wire goes to ,or comes from if the battery is there it might be just below battery
May 01, 2016 | Bolens 13.5 HP Manual 38-in Riding Lawn...
Battery isn't charging.
check to see if the machine has a regulator in the charge circuit as that will be where a problem will be
May 05, 2015 | Bolens 13.5 HP Manual 38-in Riding Lawn...
Bolens manuals what size belt
Check with mtd.com help desk. Tech support is good. Vbeltsupply.com is a good source for odd sized belts.
Jul 16, 2014 | Garden
Lawn tractor wont start
How do you know the battery is fully charged? Simply hooking a battery up to a charger does not ensure that the battery is being charged. The symptoms you mention are indicative of a dead battery.
Jan 29, 2014 | Bolens 13.5 HP Manual 38-in Riding Lawn...
Bolens 13am762f765
CHECK ALL BELTS FOR STRETCHED SIGNS AND WEAR. MAKE SURE A BELT IS NOT SLIPPING AFTER HEATING UP. ALSO CHECK ANY MECHANICAL SHIFT RODS OR LINKAGE
Dec 19, 2013 | Garden
I have a Bolens Model 13AM762F765 38inch cut 15.5 HP twin blade lawn tractor. It runs like a champ as long as I do not engage the blades or put it in reverse. It will stall if either of these two things...
Sounds like a safety switch. Just as there is a safety switch under the seat that shuts mower off if you get off seat while engine is running, theres also safety switches for, pto, drive, reverse, etc. I would get a multimeter and look for switches under chassis and test with meter for continuity.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Aug 08, 2013 | Mtd Garden
Cant find motor Model number on Bolens MTD 2005 Riding mower 15.5 hp I/C OHV
Per your own question that is the model # just use the 13AM762F765, There should have been a 2nd set of numbers and those would be your Serial number 9 digits followed with (000005) which is year built. I have exact same mower
Mar 04, 2012 | Briggs & Stratton Garden
How do I put a genuine factory parts deck drive belt O.E. 954-04062/754-04062 on 38"Bolen's lawn tractor model#13AM762F765
To start with, the easiest way is to remove the mowing deck from the tractor. It will really be tough if you don't or can't. You may need an owners manual to guide you through all the steps.
1. Remove the cutting deck from the tractor 2. Work the old belt off (if not broken) the mandrel pulleys and idler pulleys 3. Pull the belt away to reinstall a new one 1. Work the new belt around both the mandrel pulleys 2. Make sure the belt is in all the pulley grooves and inside all the belt guides 3. Now you have to reinstall the mowing deck. Here are some diagrams that should help you.
http://www.ereplacementparts.com/bolens-13am762f765-2005-lawn-tractor-parts-c-27272_27390_27402.html
Apr 19, 2011 | Garden
Yard Machines MTD Gold 185 HP Lawn Tractor 13AJ771S004 Logo
60 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
