Question about Drills
How do i re-grease makita 3200c drill - Drills
5 Suggested Answers
SOURCE: Makita drill 6349D
dont think its http://www.toolbarn.com/product/makita/6349DWDE/
Posted on Oct 05, 2008
rockitman187
  • 2559 Answers
SOURCE: I have one makita drill new.but the front part of
Here is a link to the manual page 6 shows how to attach bits
Here is a link to the parts Breakdown
Posted on Jun 04, 2009
radar001
  • 1051 Answers
SOURCE: removing chuck from Makita 64C1 drill
secure the short end of an allen wrench in the chuck, making sure it is as tight as possoble. Useing a wood or hard rubber mallet strick the long end of the allen wrench so it turns counter-clockwise. This should loosen the chuck from the spindle enough that you can unscrew it by hand.
Posted on Feb 19, 2010
  • 885 Answers
SOURCE: wiring diagrams for makita hammer drills
Go to http://www.makitatools.com/en-us/Modules/Home/Default.aspx, put your model number in the search box and the parts breakdown and owner's manual can be viewed or downloaded.
Posted on Jan 16, 2012
Hey! I have a problem with the 2015 Makita DDF482, it works, but it smells like burning wires or something like that, listening how drill works, the turns seem to fluctuate. What could be the problem?
The smell of burning /ozone could be something as simple as a dirty commutator. The carbon brushes are worn out and do not make good contact with the copper in the commutator, this produces the excessive sparks at the back of the drill, the carbon builds up and sparks as the drill turns and give the peculiar smell. Try cleaning the drill vents and commutator, oil, grease, dust, solvent, etc are a NO! NO! in this area, if that does not improve, change the brushes. Buy good quality replacements and clean the whole area again before replacing them. Bear in mind the new brushes will need to "bed in" so don't despair if at first you see some sparks. Assuming there is nothing really wrong with the drills electronics (it is relatively new drill), the fluctuation in RPMs could be a combination of the worn out brushes and/or depleted battery pack. Depending on the charge/ discharge cycles the battery pack has undergone, it could be that some NiCd batteries do not fully charge or hold their charge for long. The result is that as the drill operates at a lower voltage than rated and with fewer amps available, the battery pack struggles to deliver the power needed to turn the motor, so you notice some fluctuation. Does the drill struggle to drill through thin metal? Does it get stuck? There is a possible answer
Check the lubrication of the planetary gears assembly, poor lubrication/ dry grease will further load the motor, making it run slower.
Hope this helps you resolve the issues
Dec 05, 2017 | Makita Drills
My Makita drill stops spinning mid drill and starts again whilst stopped it makes a horrible grinding noise. Can anyone tell me what is causing this? And how do I fix it?
as with any power tool there are gears attached and when things are used they wear . the stopping might be a dirty connection . and being under the load when it stops puts much more stress on the moving parts .you could open it and grease it goos , cleaning the contacts at the same time but sooner or later it will go again ,and possibly never restart .
Aug 14, 2015 | Makita Drills
What grease do you use for a makita demolition hammer
MAKITA HAMMER DRILL GREASE 30G (181490-7) or for the older HM models Hammer grease Makita P-08361
Nov 05, 2012 | Makita Hammering
I have a makita Hammer drill # 6914D model 527047E looks like it is need of some oil what kind. The glass window is empty can you help me tried to find a manual but cannot.
Go to the below site for a manual. There isn't any reference to a glass window in the manual but the tool does need to be regreased as indicated in the manual, especially if it's used frequently. If you do it yourself, pay close attention to how much grease you put in the tool. Too much grease causes excessive drag and makes the motor work harder.
You can find an owner's manual and parts breakdown on Makita's website: http://www.makitatools.com/en-us/Modules/Tools/ToolDetails.aspx?ID=173.
Apr 26, 2011 | Makita HK1810 Power Scraper, Small,...
Drill will not turn but will you can here a grinding sound. Drill will turn when done by hand. Drill has not been run for over three years.
The gears are worn out,take it apart to verify. They need to be washed out with mineral spirits and greased if okey,otherwise they wear out the gears
Buy a new one on--- Tool Barn.com
Best prices for Makita
Nov 06, 2010 | Makita 6402 3/8" Drill, 5.2 AMP, 0 - 1,200...
Is there any internal lubrication needed on the 6221D steel 3/8 model
If this is a Makita Brand, you can use Bosch Grease part number 1615430005. About $6.00 for 45ml tube.
Apr 16, 2009 | Drills
I have a makita hr2455x rotary hammer drill that won't hammer
you need to get that service,
the grease causes the hammering.
and probably too much pressure was applied
to it.
Mar 25, 2009 | Makita HR2455X 1" Rotary Hammer Drill
Makita 8406C Gearbox oil
It uses grease to lube the gearbox. makita supply their own grease so you should be able to get a small tube from your local dealer. You don't have to use Makita grease though, just general grease should be fine. Not too thick and heavy, or too oily and light. I know that sounds a bit vague. Do you have other machines that you have grease for? SDS hammer drills, saws, any small power tool like that will use a similar type of grease.
Nov 01, 2008 | Drills
Makita BHP451 Question
Buy a hitachi li-ion 18 volt ds18dl.
All parts are repairable & replacebable should they breakdown. Ie gearbox.
Gearbox parts are not available on makita , only whole gearboix which can be expensive.
Cheers
Laurie
Aug 27, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Drills Logo
71 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
