OKI C5510 MFP All-In-One Led Printer Logo
A
Anonymous Posted on Apr 21, 2014
Filed to detect printer - OKI C5510 MFP All-In-One Led Printer
Cannot print from my application
I am not able to detect bluetooth in Zebra rw420
3answers
Error 163 on oki c5500 printer
163 Toner Sensor Error, Color: Black An error has been detected in your printer's Toner Sensor.
1 Machine Check Exception A problem has been detected in the printer hardware
2 DSI Exception The printers main logic has attempted to look up an invalid address.
3 ISI Exception The printers main logic has attempted to read the next instruction, which has failed to execute for some reason.
4 Alignment Exception The printers main logic cannot access the memory for some reason.
5 Program Exception The printers main logic has issued an exception code.
6 Floating-point Unavailable Exception A floating-point instruction is executed when the MSR floating point enable bit is set to Disable.
7 Instruction Address Breakpoint Exception The printers main logic has attempted to look up an invalid address.
20 CU ROM Hash Check Error 1 CU ROM hash check error has been found. Check reproducibility if possible.
21 CU ROM Hash Check Error 2 The printers CPU has a checksum error in it's memory.
23 CU ROM Hash Check Error (resident) Seek service if restarting the printer does not correct the problem.
25 CU ROM Hash Check Error (DIMM2) Seek service if restarting the printer does not correct the problem.
30 CU Slot1 DIMM RAM Check Error An error has been detected in operation checks on the RAM in slot 1
31 CU Slot2 DIMM RAM Check Error An error has been detected in operation checks on the RAM in slot 2
35 Slot1 RAM Spec Error Check the specification and install in slot 1 RAMs supported by the product
40 CU EEPROM Error The EEPROM mounted on the CU board needs to be replaced
41 CU Flash Error The CU Flash needs to be replaced
43 Flash File System Version Mismatch Seek Service if restarting the printer and initialising the flash memory does not correct the problem
42 Flash File System Error Seek Service if restarting the printer and initialising the flash memory does not correct the problem
43 PS Flash File System Error An Flash Memory error has occured and the printer needs to be serviced if restarting the printer does not correct the problem
51 CU Fan Error The CU cooling fan needs to be replaced if restarting the printer does not correct the problem
70 Postscript Failure An error has been detected in your printer's Postscript Core.
72 Engine Communication Error A communications error has occurred between CU and PU boards.
73 H/W Overrun Detect An error has been detected in your printer's hardware input area.
74 F/W Overrun Detect Occurs when the firmware is unable to set video data in response to video DMA's data request.
75 VIC Limiter An error has been detected in your printer's
80 Parameter I/O Error An error has been detected in your printer's Input/Output area.
81 Parameter Consistency Check Error The EEPROM and flash memory reformatted and initialized.
102 Engine RAM Error An error has been detected in your printer's engine RAM.
103 Engine SRAM Error An error has been detected in your printer's engine SRAM.
104 Engine EEPROM Error An error has been detected in your printer's engine reading/writing the EEPROM at power-up.
105 Engine EEPROM Missing Error An error has been detected in your printer's Engine
106 Engine Control Error An error has been detected in your printer's Engine Controller.
122 Power Supply Fan Motor Error An error has been detected in your printer's Power Supply Fan Motor.
123 Humidity Sensor An error. has been detected in your printer's Humidity Sensor
124 Temperature Sensor An error has been detected in your printer's Temperature Sensor.
127 Fuser Unit Fan Error An error has been detected in your printer's Fuser Unit Fan Error.
131 LED Head Missing, Color: Yellow When yellow LED head connection cannot be detected
132 LED Head Missing, Color: Magenta When magenta LED head connection cannot be detected
133 LED Head Missing, Color: Cyan When cyan LED head connection cannot be detected.
134 LED Head Missing, Color: Black When black LED head connection cannot be detected.
140 Drum Up/Down, Color: Yellow An error has been detected in your printer's Yellow Drum
141 Drum Up/Down, Color: Magenta An error has been detected in your printer's Magenta Drum.
142 Drum Up/Down, Color: Cyan An error has been detected in your printer's Cyan Drum.
150 Drum Fuse cut NG, Color: Yellow An error has been detected in your printer's Drum Fuse.
152 Drum Fuse cut NG, Color: Cyan An error has been detected in your printer's Drum Fuse.
153 Drum Fuse cut NG, Color: Black An error has been detected in your printer's Drum Fuse.
155 Fuser Unit Fuse cut NG An error has been detected in your printer's Fuser Unit.
154 Belt Unit Fuse cut NG An error has been detected in your printer's Belt Unit.
160 Toner Sensor Error, Color: Yellow An error has been detected in your printer's Toner Sensor.
161 Toner Sensor Error, Color: Magenta An error has been detected in your printer's Toner Sensor.
162 Toner Sensor Error, Color: Cyan An error has been detected in your printer's Toner Sensor.
170 Upper Thermistor, State: Short An error has been detected in your printer's Upper Thermistor.
171 Upper Thermistor, State: Open Restart the printer. If the problem continues the printer will need to be serviced
172 Upper Heat Temp, State: High An error has been detected in your printer's Upper Heat Temp.
173 Upper Heat Temp, State: Low Turn the printer off to let it cool down, then restart the printer.
181 I/F Error, Loc. Duplex An error has been detected in your printer's Duplexer.
182 I/F Error, Loc. Tray2 An error has been detected in your printer's Tray2.
187 I/F Error, Loc. Control Pnale An error has been detected in your printer's Control Panel.
190 System Memory Overflow An error has been detected in your printer's System Memory Overflow.
191 Page Memory Overflow An error has been detected in your printer's Page Memory Overflow.
200 PU F/W download Check Sum Error Error during PU flash download
201 PU F/W Flash Write Error An error has been detected in your printer's PU F/W Flash Write Error.
202 PU F/W Flash Data Missing An error has been detected in your printer's PU F/W download Check Sum Error.
203 Engine Page Sequences IMAGACK Error An error has been detected in your printer's Engine Page Sequences IMAGACK Error.
204 EnginePageSequences IMGSET Error An error has been detected in your printer's Engine Page Sequences IMGSET Error.
2005 Oki Data Americas, Inc.
3helpful
Computer cant detect the printer
Go to C:/windows/inf and look for files called oemXX.inf oemXX.pnf.
Open the .inf files one by one and look for the EPSON label in them and when you find one just delete the .inf and .pnf file equivalent. There might be more than one EPSON files in the inf library.
Then unplug the printer, restart the computer, and the add wizard should pop again when you replug the printer.
Hope this helps.
We moved an okidata 520 printer to another computer and now it won't print. We connected the printer it detected the driver and auto installed it then we tried to print and nothing happens. There are no...
~ Check the unit physically. Try to copy stand alone. ~ Check if the drivers are properly installed ~ Check device manager/system profiler if the printer is detected ~ If the unit is on wireless connection, try network settings and ping the printer ~ If on usb connection, check printer icon ~ You can try to replace the usb cable or try a different computer
1helpful
My 8gb imation pen drive is not working. it is not being detected by the system and contains important document which need to be recruited
If it can be detected on other computers (Macs or linux) than the documents can be saved. If cannot detect on other PCs you will need someone with the knowledge to recover files from memory chips.. Good luck..
1helpful
2answers
NEED DRIVER FOR WIPRO EX5400.
1. if you dont have ex5400 dotmatrix driver, no
problem..
2. goto start, then settings, then printer and
faxes
3. Add a printer, then next, local printer
attached, then next
4. computer will detect and display not wizard
was unable to detect then press next
5. select printer port, then press next
6. install printer manually which is nearer to
your printer model no..
7. eg. Ex5400
8. nearer no is : Eq5400, Cx5400 or 5400
9. hope this will install and give you print
try it.. all the best... for more details..
[email protected]
I have just conected the mpc600f & when the box came up saying new software detected install now i accidentally said do not show again or something along those lines. I have put the disk in but it says...
I suggest you to remove printer connection from the pc Restart the computer and then connect the printer if it detects the printer continue with the steps of Found New Hardware( insert the printer cd into the drive and continue with the installation
if it is not detected then Start--->Control panel ----->printers and Faxes and delete any printer icons in same dailogue box click file menu File-->server properties---> in this dailogue box choose drivers tab select the drivers if any and click on the remove button (remove all the Drivers)
and then restart the printer the printer will be detected
if assume that you know the installation of printer
if not --->control panel--->printer and faxes----> Add printer option
Installation
Go to www.hp.com let the website auto-detect your printer and download the drivers automatically
2answers
Computer cannot detect printer
ok..
remove all software from computer for printer
go to www.canon.com and get new drivers by model and operating system
re install
try it again.
3helpful
4answers
Printer Driver
i want hp jaserjet 1010 driver
Top OKI Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
