Question about HP LaserJet III Printer
PAPER JAME CODE 13
I HAVE A CODE 13 PAPERJAM ON A LASER JET III AND CANNOT SEE A PAPER JAM OR FIND MY MANUEL
  • jeffrey_spry May 11, 2010
    Are there any numbers after the 13? like 13.01 or 13.02?
  • 484 Answers
Try looking for the jam from the rear of the printer. Also, using one of those compressed air cans, blow all the paper dust our of your printer, because the sensors usually are photo-electronic sensors, and paper dust wil register a paper jam, even when no paper is in the printer.
Posted on Jun 19, 2009
My HP color Laser Jet 2600 printer has a paper jam
Jul 21, 2014 | HP Office Equipment & Supplies
Paper jam printer
kindly check it what shows in the display:
"paperjam 0" , its related to pick up roller related problem.
"paperjam 1", its related to cartridge unit, kindly re inserted the cartridge.
"paperjam 2", its related fuser unit, kindly open the rear cover of printer, ther you can see the fuser unit. check the one liver from fuser unit to HVPS .
kindly check all these things and contact
Jan 29, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Hp laser jet 5025 paper jam
Clear the paper jam...
Also make sure all the pick up rollers are not smooth, if they are replace them. Also make sure the tray is set to the right paper and not offset. A lot of times people slam the tray and it moves the setting bar.
Jul 09, 2012 | HP LaserJet M5025 Printer
Paper jam - where do I get instructions on how to fix?
To remove the paperjam in machine you need to:
Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well. Remove the paper tray there could be a piece of paper stuck there.
Wherever you find the Jam remove it slowly so it doesnt rip.
Jun 24, 2010 | Brother HL 2140 Laser Printer
Hi there...we have an error saying paperjam - code=007. I have checked for paperjams and there doesnt visually appear to be any. What can you suggest?
When you removed paper from the machine, did it rip at all? If it did, a small scrap could have been left behind, causing the jam code. Depending on where the machine is located and who uses it, there might also be a foreign object lodged in it (like a staple or paper clip). If you think there is nothing in there causing the jam, try turning the machine off and turning it back on, and see if it still shows the jam.
May 27, 2010 | Panasonic Panafax UF-585 Plain Paper Laser...
I have a paperjam on my colour laser printer CLX 3170 and I dont know how to get to the paperjam inside the machine
Step 1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step 2
Turn off the printer.
Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step 4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step 5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step 6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step 7
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Step 8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Inspect the paper path once again.
Feb 19, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Getting the message "241 Paperjam Check Tray 1" I've checked tray 1 and have not found a paper jam
Turn the printer upside down and shake to find any paper jam as in most cases you will find some paper or dust falling out and then try.
Jan 26, 2010 | Lexmark T630 Laser Printer
Papaerjam lite stays on, no paper jam
It is possible that there may still be a small piece of paper blocking or lodged in the exit sensor area. It is also possible that when removing the jammed paper that the sensor arm became dislodged and thus creating a false jam code.
Jun 25, 2008 | Sharp AL-1641CS All-In-One Laser Printer
Curled corner causing a paper jam
Try replacing all paper. Sometimes paper that is overly humid or has gotten wet will curl. Replace with new paper and report results.
Dec 17, 2007 | Dell 1600n All-In-One Laser Printer
HP LaserJet III Printer Logo
328 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
