Question about E-Machines eMachines Desktop PC
My computer will only turn on in "sleep mode"
Anytime i turn on my comp, a desktop, it will only start in sleep mode ie. the power button is orange and not green like a normal start up. The cd/dvd opens and closes but the mouse and the keyboard have no power, and the monitor says "screen in power save mode". All i can do is turn it off and on by holding down the power button nothing else...any ideas?
  • tlittle187 Jun 19, 2009
    thx for the advice but the thing is i can't even turn my comp on...period...i have no option to do anything...as soon as i even plug my comp into the outlet it is immediately in sleep mode it won't boot at all. it was my friends old comp so im assuming it's WIN '98 or something along those lines...he said it worked fine for him but i can't even get it to turn on...
    Problem Solver:
  • 7 Answers
You have to go to control panel/power options, make sure that you just disable sleep mode or hibernation and also that it is set to turn on and off when you press power button or shutdown. What Operating System are you running ie: Vista, XP? You might need to switch control panel to classic view to see power options. If this doesn't work then sometimes it can be set in the bios. Repost if that is the case and I will give you instructions.
Posted on Jun 19, 2009
  • Jason Jun 19, 2009
    It either has no operating system on it (do you get the post screen...where the white writing runs across the screen?) or it is set to start in sleep mode. Try turning on and holding down the delete key or maybe f2 key. this will take you straight into BIOS, you can click on the power settings tab and make sure it doesn't have sleep enabled but I recommend going straight to the exit tab and and load system defaults then exit saving changes. The tab names and layout can vary depending on mainboard brand and its BIOS. Hope this helps, keep me informed.
  • 59 Answers
When the computer is on try just pushing the power button in and out once. if this doesn't work you may need to change some settings in the startup setup menu to keep sleep mode off. Usually when a computer is turned on there is something like "press F1 for Bios or DEL (something else) for setup" setup is where you'll want to go. it will look like an old MS DOS program but using your arrow keys to navigate you should be able to change the settings.
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Windows sleep mode problems
Dec 21, 2012 | Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
Start button flashing
It depends on the color, if it's green or amber. This may indicate the computer is in sleep mode. Press the power button to see if you can turn on the pc. If it doesn't press and hold power button for five seconds. You may give more details. I hope this helps
Mar 10, 2011 | Dell OptiPlex GX260 PC Desktop
Sleep Mode Lockup on Dell Inspirion 530 w/ Vista
Try hitting the "Windows" key on your keyboard to bring it out of sleep mode. The "Windows" key is generally found on the bottom row of the keyboard, near the Alt and Ctrl keys, and it has no letters on it, just the Windows logo. That key brings my Windows Vista machines out of sleep mode when other keys won't.
As for the power button, anytime you need to force a computer to turn off, you can press and hold the power button to do so. Usually, you need to hold the power button for 5-10 seconds and it will shut down. Use this option with caution, as it turns the computer off without running through the shutdown process and can cause you to lose data.
Hope this helps.
Mar 08, 2009 | HP Media Center m7060n PC Desktop
Dell comp
To help you better , could you let me know , when the system goes into sleep mode, the power light in the front of the tower is it amber or blinking amber or is it of some other color.
If the power button is blinking amber , the power supply on the unit is going bad.
Thanks
Proton
Oct 29, 2008 | Dell Dimension 2400 PC Desktop
Turn off sleep mode, It causes prob. turning on programs to use computer
I have a hp desktop, each time I push the sleep button, the computer goes to sleep, however about 10 seconds ofter entering sleep mode it starts up again.How can I make the computer stay in sleep mode. thanks
Oct 13, 2008 | E-Machines eMachines Desktop PC
Stuck in sleep mode
Press the power button on the Computer it should come out of sleep mode then if it doesn't hold the power button of the computer down until the system turns completely off.
Then turn back on the computer should now boot fine. Once in windows goto control panel and select power option then adjust the setting.
Hope this helps you
Cheers J
Jan 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
E-Machines eMachines Desktop PC Logo
269 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
