Question about Hotpoint Dishwashers
A-10 ERROR Open/Short circuit fill valve triac*
3 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: fill valve vibrates loudly
i would look to the valve solenoid as the issue, if not the pressure from the incoming water supply( try decreasing under sink perhaps to high)
Posted on Dec 02, 2008
  • 3247 Answers
SOURCE: A10 - Open/Short circuit fill valve traic
Please provide full model number of the hotpoint dishwasher.
It appears the electronic relay on the control card that drives the water inlet valve has shorted out.
Generally the whole control card needs replacement in this case. In addition if the valve has caused this fault then it too will need to be replaced.
you can find the parts on this site after you find the model number.
Posted on Sep 26, 2011
Washer stops working and displays F6
hotpoint?
"EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Aug 24, 2015 | Washing Machines
Tip
List of codes for Hotpoint, Creda, Ariston, Indesit, Cannon
Appliance tagged Hotpoint, Creda, Ariston, Indesit, Cannon are all distributed by the Indesit appliances group.
All this brands share parts, they share the same error code list, and the service is provided by same centres.
I will publish a list of error codes for Hotpoint, Creda, Ariston, Indesit, Cannon.
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
  • F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
  • F12 - No mixed fill. It is likely that the water is not turned on at the taps.
  • F13 - Check the water supply, inlet valve and hot and cold hose connections.
  • F14 - A fault with the water heating has occurred
  • F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked
  • F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more.
  • F17 - Door not closed properly. Close door firmly at 3 o'clock position
  • F20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing
  • F30/31 - A motor drive problem has occurred. Try running the programme again. If the problem persists book service
  • F40 - Water below protection level during a heat step
  • F41 - Water level detect sequence incorrect
  • F50/51 - Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language).
Fault codes for LCD EVO1 Washers
  • F13 - Dryer fan or dryer thermisotor fault
Fault codes for LCD EVO2 and V4 Washers
  • F01 - Motor traic short circuit
  • F02 - Motor jammed or tacho detached
  • F05 - Pressure switch jammed on full - Check pump for blackages.
  • F08 - Heater relay stuck
  • F09 - Setup error
  • F12 - No communication between cards
  • F13 - Drying thermistor open/short circuit
  • F14 - Drying element faulty
  • F17 - Interlock error
  • F18 - Communication error
  • H20 - Not filling. Check tap, hose and inlet valves
Fridges and Freezers
  • F1 - Freezer thermistor open circuit
  • F2 - Freezer thermistor short circuit
  • F3 - Fridge thermistor open circuit
  • F4 - Fridge thermistor short circuit
  • F7 - Evaporator thermistor open circuit
  • F8 - Evaporator thermistor short circuit
  • F9 - Temperature set switch open circuit
  • FA - No feedback from Baffle
  • FB - Fridge Baffle motor operating continuously
  • FE - Defrost time out
Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level.
  • F20 - Temperature under range
  • F21 - Temperature over range
LCD Dishwasher Models
  • A01 - Float switch
  • A02 - Open/Short circuit heater relay
  • A03 - Short circuit on thermistor or Time-out drain- Check filter for blockages then book a repairif the problem persists.
  • A04 - Unable to reach or sense temperature within 70 minutes
  • A05 - Pressure switch has not been reset
  • A07 - Open/Short circuit wash motor triac
  • A08 - Open/Short circuit auxiliary wash motor triac
  • A09 - Open/Short circuit with main wash traic
  • A10 - Open/Short circuit fill valve traic
  • A11 - Half load valve traic or alternating motor action
  • A12 - Open circuit heater rely
  • A13 - Open/Short circuit dispenser traic
  • A14 - Drain hose too low causing syphoning. Check drain hose.
  • H20 - Check tap and pressure of incoming water.
Hotpoint Tumble Dryers
  • F1 - The level of required dryness has not been reached within the time period. Check that the correct programme has been selected
  • F2 - Thermistor or sensing circuit failure
  • F3 - Heater plate over temperature. Check the filter and vent hose for a possible blockage
...Follows--->
on Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius super silent WF630 FAULT CODE F02
[/spoiler] [spoiler title="EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
Error Codes Hotpoint Service
Aug 24, 2015 | Hotpoint Washing Machines
WF-T1022TP(H) INCOMMING WATER DOES NOT STOP
could b eather a pressour switch prob or inlet valve sticking open
Apr 29, 2015 | LG Washing Machines
What does e 62 error code refer to?
E62: Overheating during washing this is real ans now iam giving u more tips abt error -
E11: Difficulty in filling during wash phase
E13: Water leakage.
E21: Difficulties in draining .
E23: Malfunction of drain pump triac.
E24: «sensing» circuit of the component (triac) that controls the drain pump faulty
E33: Incongruence between closure of anti-boiling and 1st level contacts of pressure switch
E35: Water level too high
E36: «sensing» circuit of anti-boiling pressure switch faulty
E37: «sensing» circuit of 1st level pressure switch faulty
E39: "HV" «sensing» circuit of anti-overflow pressure switch faulty
E40: Door open, Interlock, wiring or main PCB
E41: Door open
E41: Problems with aperture of door
E42: Problems with aperture of the door
E43: Problems with the triac which actions the door interlock
E44: Door closure «sensing» circuit faulty
E45: Problems with the «sensing» circuit of the triac that actions the door interlock
E51: Motor power triac short-circuited
E52: No signal from the motor tachymetric genetaror
E52: No signal from the tachymetric generator
Procedure for checking commutator motors
E53: Problems with the «sensing» circuit of the triac which powers the motor
E54: Motor relay contacts sticking
E61: Insufficient heating during washing
E66: The contacts of the heating element power relay are always closed
E71: NTC washing sensor faulty.
E82: Error in reading the RESET/OFF position of the programme selector.
E83: Error in reading the programme selector code
E93: Incorrect machine configuration.
E94: Incorrect configuration of washing cycle
E95: Communications error between microprocessor and the EEPROM
E96: Incongruence between control panel version and configuration data
E97: Incongruence between selector version and configuration data
EA1: Drum positioning system (DSP) faulty (top-loaders only)
EB1: Incorrect mains frequency
EB2: Mains voltage too high
EB3: Mains voltage too low
E32 INCORRECT CALIBRATION OF ANALOGIC (ELECTRONIC) PRESSURE SWITCH. IF THE MACHINE IS DRAINING OK, THEN IT IS THE SWITCH
E32 relates to the electronic pressure switch, normal pressure switch,inlet valves,poor water mains pressure and finally the main control board
E90 means theres a fault on the main control module so A;will need a new control module or B; get an engineer to try re-configureing the module
May 16, 2011 | Hoover Washing Machines
Im facing one problem if e 004 what is the
VIII. SELF DIAGNOSIS The microprocessor on the copier’s DC controller PCB is equipped with a function that checks the condition of the machine (especially the condition of sensors). It runs checks at such times as programmed, and will indicate any fault it finds in the form of code. A. Copier E000 • The thermistor (TH1, TH2) has poor contact or an open circuit. • The fixing heater (H1) has an open circuit. • The thermal switch (TSW1) has turned on. • The triac is faulty. • The DC controller PCB is faulty. • The thermistor (TH1, TH2) has a short circuit. • The triac is faulty. • The DC controller PCB is faulty. • The thermistor (TH1, TH2) has poor contact or an open circuit. • The fixing heater (H1) has an open circuit. • The thermal switch (TSW1) has turned on. • The triac is faulty. • The DC controller PCB is faulty. • The thermistor (TH1, TH2) has poor contact or an open circuit. • The fixing heater (H1) has an open circuit. • The thermal switch (TSW1) has turned on. • The triac is faulty. • The DC controller PCB is faulty. • The triac has a short circuit. • The DC controller PCB is faulty. • The surface temperature of the fixing upper roller does not reach 40°C within 14 sec after power-on. • The surface temperature of the fixing upper roller exceeded 230°C. • The surface temperature of the fixing upper roller does not reach 60°C within 10 after it exceeded 40°C. • The surface temperature of the fixing upper roller does not reach 80°C within 10 sec after it exceeded 60°C. • The surface temperature of the fixing upper roller does not reach 100°C within 10 sec after it exceeded 80°C. • The surface temperature of the fixing upper roller does not reach 120°C within 10 sec after it exceeded 100°C. • The surface temperature of the fixing upper roller drops to 130°C or less after it reached the target temperature (160°C) for standby. • The triac is identified as having a short circuit. Code Cause Description E001 E002 E004 E003
Oct 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
A05 code
Indesit Error Messages and Error Codes Indesit Dishwashers
  • F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
  • F20 - Temperature under range. Book a service engineer. .
  • F21 - Temperature over range. Book a service engineer.
Fault codes for Indesit LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
_uacct = "UA-1207243-4";urchinTracker();
Sep 14, 2008 | Indesit 24 in. DE73 Evolution...
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Hotpoint FDW80( A10 Appears ondisplay half way through cycle)
here are the fault codes for your machine...
Fault codes for LCD Dishwasher Models
  • Hope this helps?
    Jan 06, 2008 | Hotpoint 24 in. FDW60 Free-standing...
    E60 error code
    Found These Fault Codes On Internet, Hope This Helps, Daz
    ALARM CODES
    E00(E00)- Problems with water fill during washing
    -Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
    E01(E00)- Problems with water fill during drying
    -Tap closed; solenoid valve, wiring , main PCB, pressure switches
    E10(E10)- Problems with water drain during washing
    -Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
    E11(E10)- Problems with water drain during drying
    -Drain hose kinked, filter blocked, drain pump, pressure switches
    E20(E20)- Door open
    -Cycle in Door delay, wiring , main PCB
    E21(E20)- Fault in door delay power triac
    -Wiring , main PCB
    E30- Fault in electronic pressure switch
    -Electronic pressure switch, wiring , main PCB
    E31- Fault in electronic pressure switch circuit
    -Main PCB (fault in electronic pressure switch circuit)
    E32(E10)-Calibration error in electronic pressure switch
    -Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
    E33- Incongruency between electronic pressure switches and safety switch 1
    -Electronic pressure switch, safety pressure switch,wiring, main PCB
    E34- Incongruency between electronic pressureswitches and safety switch 2
    E35- Intervention of anti-overflow pressure switch
    -Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
    E36- Water leakage (maximum number of resets exceeded)
    -Water leakage, drain hose too low, pressure switch,wiring, main PCB
    E40- Motor power triac short-circuited
    -Main PCB (triac short-circuited)
    E41- No signal from tachimetric generator
    -Tachimetric generator on motor, wiring, main PCB
    E42- Fault in tachimetric generator circuit
    -Main PCB (tachimetric generator sensing circuit)
    E43- Intervention of motor overload protection
    -Motor, wiring, main PCB
    E50- Insufficient heating during wash phase
    -NTC sensor setting incorrect, heating element, wiring,main PCB
    E51- Overheating during wash phase
    -Heating element (to earth), main PCB (relays)
    E52- Insufficient heating during drying phase
    -NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
    E53- Overheating during drying phase
    -Drying heater (to earth), main PCB (relays)
    E55- Fault in power relay for heating element (K3)
    -Safety pressure switch 2, wiring, main PCB- 6 -
    E60- Fault in washing NTC sensor
    -Washing NTC sensor, wiring, main PCB
    E61- Fault in drying NTC sensor(condenser)
    -Drying NTC sensor (condenser), wiring, main PCB
    E62- Fault in drying NTC sensor(duct)
    -Drying NTC sensor (duct), wiring, main PCB
    E63- Fault in 1/2 power thermostat
    -Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
    E70- Power triac to distributor motor short-circuited
    E71- Fault in power relay to distributor loads
    -Main PCB (relay open)
    E72- No distributor position signal
    -Water distributor motor, wiring, main PCB
    E73- Incorrect timing on distributor contacts
    -Water distributor, wiring, main PCB
    E90- Fault in tank fill pump
    -Hoses obstructed, tank fill pump, wiring
    E91- Fault in tank drain pump
    -Hoses obstructed, tank drain pump, wiring
    E92- Fault in power triac to tank fill pump
    -Tank fill pump, wiring, main PCB
    Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
    Dishwashers Logo
    46 people viewed this question
    Top Hotpoint Dishwashers Experts
    AcmeUK
    Level 1 Expert
    Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
