Question about Canon iR3035 Copier
I400-000 error 400-000
On the GS1510 the error A-400 is showing
ftp://ftp.zyxel.com/GS1510-16/user_guide/GS1510-16_1_ed2.pdf
The error is not mentioned in the manual. 400 itself is a familiar error number on the internet but I do not know what A-400 represents. You may have to contact Zyxel Support with this query.
ZyXEL Support Center
Jun 16, 2017 | The Office Equipment & Supplies
Apparently I forgot my password when I try to reset it I get this messagd
How To Fix the 400 Bad Request Error
  1. Check for errors in the URL. The most common reason for a 400 Bad Request error is because the URL was typed wrong or the link that was clicked on points to a URL with a specific kind of mistake in it, like a syntax problem.
    Important: This is most likely the problem if you get a 400 Bad Request error. Specficially, check for extra, typically non-allowed, characters in the URL like a percentage character. While there are perfectly valid uses for something like a % character, you won't often find one in a standard URL.
  2. Clear your browser's cookies, especially if you're getting a Bad Request error with a Google service. Many sites report a 400 error when a cookie it's reading is corrupt or too old.
  3. Clear your DNS cache, which should fix the 400 Bad Request error if it's being caused by outdated DNS records that your computer is storing. Do this in Windows by executingipconfig /flushdns from a Command Prompt window.
    Important: This is not the same as clearing your browser's cache (next thing to try below).
  4. Clear your browser's cache. A cached, but corrupt copy of the web page you're trying to access, but are getting the 400 error on, could be the root of the problem. Clearing your cache is unlikely the fix for the majority of 400 bad Request issues, but it's quick and easy, and so worth trying.
  5. While this is not a common fix, try troubleshooting the problem as a 504 Gateway Timeoutissue instead, even though the problem is being reported as a 400 Bad Request.
    In some relatively rare situations, two servers may take too long to communicate (agateway timeout issue) but will incorrectly, or at least unhelpfully, report the problem to you as a 400 Bad Request.
  6. Contact the website directly that hosts the page. It's possible that the 400 Bad Request error actually isn't anything wrong on your end and it's something they need to fix, in which case letting them know about it would be very helpful.
May 28, 2015 | Computers & Internet
How to go service mode Cannon ir 400 ?
Here is the error code page http://www.scribd.com/doc/56428927/iR-400-Code-List
And here is the service manual
http://www.scribd.com/doc/135167936/canon-Ir-400-Service-Manual
Looking at what the error is, getting into the service mode will not allow you to fix it; you have some parts to replace first.
Jul 20, 2014 | Cannon Office Equipment & Supplies
C-6 and 400 error on olivetti d-copia 200
cant find c6 or 400 in the manual. make sure all the doors are closed 1 st
Oct 25, 2012 | Kyocera Office Equipment & Supplies
C-6 ( 400 )
KEY IN 1087 TWICE N PRESS START, ENTER CODE ERROR EG.400 N PRESS START. ONCE IT SHOWS CLE, ENTER 163 N PRESS START. WAIT FOR IT TO RESTARST. LALI.
May 18, 2009 | Kyocera Copystar CS-1620 Black and White...
Could not communicate to the network server error 3. 400 bad req
When i install Smart draw it shows "could not communicate to the network server error 3. 400 bad request".Please help me.Thank in advance.
Mar 25, 2009 | YouTube Videos
I work in a lab and we use a monarch paxar 9825 label printer and this morning it has an error code 400. What is this error code?
These types of errors are data errors. If you post your datastream, I may be able to tell you where the error is at.
Dec 11, 2008 | Paxar Monarch 9825 Thermal Label Printer
Http error 400
Error 400 is a bad request error which is almost always a problem with the website programming itself and not necessarily your computer configuration.
Jun 14, 2008 | Compaq Presario Notebook
Canon iR3035 Copier Logo
15 people viewed this question
old marine
old marine
