Question about Samsung Refrigerators
Micro switch RFG297HDRS - Samsung Refrigerators
Samsung model RFG297HDRS manual
then you need a repairman . or a new one
Oct 22, 2015 | Samsung RFG297HDRS 29 Cu Ft Stainless...
Why is water leaking in?
If this is a freezer on top unit you may have a blockage in the drain tube that is beneath the evaporator in the freezer
Jul 17, 2015 | Samsung RFG297HDRS Stainless Steel
Samusung RFG297HDRS Ice maker not cold enough to produce ice.
Suspect that the rubber boot that runs all around the edge of your freezer door is deformed, allowing warm air to seep into your freezer. You will see where your temp sensor is located by clicking into the site of a parts supplier like ShopJimmy.com and pulling up their photo of the guts of your unit.
Oct 29, 2014 | Samsung RFG297HDRS Stainless Steel
Locate ice maker water level control?
This should be automatic. What is the problem--too litte ice? Do you have a in line water filter out side of unit? Filter in the fridge? Check for dirty filter and you may fix the issue of not enough water getting thru.
Jul 16, 2014 | Samsung RFG297HDRS Stainless Steel
How do I clean, what appears to be, rust marks on my stainless steel refrigerator
DO NOT use anything but a dedicated stainless steel cleaner. Some types of Windex have ammonia as one of the ingredients and you can imagine what that will do to your stainless steel finish.
Mar 23, 2014 | Samsung RFG297HDRS Stainless Steel
My micro sd card is locked how to unlock
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
Aug 12, 2011 | SanDisk 2GB microSD Memory Card
My micro sd card get write protected help me to retrive it...
I hope this helps.
Aug 10, 2011 | Computers & Internet
The machine does not stop grinding - until all the beans are up & everything clogs up inside
Hi
The problem with a constant grinding and overflow of coffee is a micro switch in the doser box needs to be replaced. If you get the top off there is a solenoid in the center of the machine on top that has to be removed. There is a micro switch below and to the right that is bad or dirty and needs to be replaced. This micro switch turns off the grinder when the coffee pushes a arm against the micro switch. If the micro switch doesn't shut off the grinder the coffee overflows the box and falls into the brew unit. This is a very special micro switch that is only a 6 gram switch not like the others that look like it and are a 32 gram switch.
Feb 06, 2011 | Solis Master 5000 Espresso Machine
Refrigerators Logo
21 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
