Question about Archos Tablets & eReaders
How to unroot my archos 80b platinum
I am trying to load sky go - but it is telling me that it is not supporting rooted devices
Trying to factory reset proscan plt7810k but comes to android robot with red triangle
If you have rooted your tablet you will have to unroot it for it to update
Jan 20, 2017 | Tablets & eReaders
Firmware upgrade failed
Similar problem on my Samsung Galaxy Note 8 when trying to upgrade to Kit Kat 4.4.2. Since my device had been rooted is registered as "Modified". There were dozens of posts instructing me to download drivers and decompilers and more software to trick the update server into seeing my tablet as "Official". Since a firmware upgrade will unroot the device anyway I simply used KEIS connecting with USB and it was effortless. Just make sure your device has at least 50% battery.
Apr 09, 2014 | Samsung Galaxy Tab Tablet PC
Forgot my password to get into my android table MID M729 the pattern on the top of the tablet
Normally, with Android devices, if you enter the wrong pattern five times in a row, the device will give you an option to enter your Google account information (e-mail address and password). Once you have done this, it will let you reset your security pattern.
If this doesn't work, the next best thing to try would be a firemware The firmware update process will wipe the root of the device (but leave your SD card and books intact), basically resetting it to factory settings, before you even set a security pattern.
Should this fail to work, contact Velocity Micro Support by calling +94756523353
Dec 28, 2012 | mid Archos M729B Android Tablet
Archos 10g2 wont load up
Just flash the default firmware from the manufacturer:
http://arnovatech.com/support/firmware/2/arnova10g2/111010/update.img
http://arnovatech.com/support/updates.html?country=us&lang=en&p=2
Flashing a firmware means installing it in the device protected flash memory, more explanations here: http://www.addictivetips.com/mobile/what-is-meant-by-firmware-stock-custom-roms-and-flashing-guide/
The firmware flashing procedure for your device is detailed on Arnova web site:
http://arnovatech.com/support/firmware.html?country=us&lang=en&g=2
Jun 25, 2012 | ARNOVA 10 G2 8 GB PC Tablet with WiFi...
Error 7 when i try sky go movies
according to the sky help forums at http://helpforum.sky.com/t5/Using-Sky-Go/Sky-Go-Errors-5-7-amp-9-on-iPhone-iPad-amp-iPod-touch/td-p/208239/page/4
Try the following steps to resolve this issue:
  1. Locate the Sky Go app on your Mobile device.
  2. Hold down the icon until the app wobbles (You will see a White Circle with a Black Cross symbol, press on the cross to remove the app)
  3. You will then be asked to confirm you wish to delete the app - Press Delete the Sky Go App will then be removed
  4. Go back to the App Store and reinstall the Sky Go App. This can be found by searching for BSKYB
  5. Access the Sky Go app again and you should be able to view content after you sign back in using your Sky ID & password.
Hope this helps
Dec 25, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Can get my archos 5 to conect to my android phone
If you mean to connect your Archos to your Android device through Wi-Fi, than, yes, you can! But, only if your android device supports the tethering feature. For example if you have an Android 2.2 (Froyo) device than you go to Settings->>Wireless & networks->>Tethering & portable hotspot and tap "Portable Wi-Fi hotspot". From the Archos, go to the the Wi-Fi settings and connect to the network you've just created. If you do not have the tethering option available, you should find out if your carrier or device manufacturer has an update for the device. Hope it helps!
Feb 20, 2011 | Dba Archos 5 160 GB Internet Tablet with...
Tablets & eReaders Logo
44 people viewed this question
Top Archos Tablets & eReaders Experts
Joseph Prosser
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Archos Tablet and eReader Expert? Answer questions, earn points and help others
