I tried connecting to the 770 using a T-989 galaxy S 2 and a SCH-U365 a prepaid phone with verizon, both phones would find and pair with the 770, however the 770 would`nt pair or even a option to connect.There is a message on the nokia 770 stating (selected phones dont have services that can be used. select another phone.)
SOURCE: unlocking a verizon lg prepaid phone
go to www.mobile2mobile.net or take it to a mobile service center or tech and have them unlock it for you.
SOURCE: I can't connect Verizon Gleam SCH-U700 to Parrot CK3100
I paired my SGH-U700 phone with the CK3100 kit, however, when it tries to connect, the phone automatically turns off then back on...5 seconds later, it goes off again and back on...while the CK3100 just says "SGH-U700 DISCONNECTED"? Please help!
SOURCE: HTC Viva and WIFI Problem Connection
Hello, wifi is a sort of WLAN conection. you need a wireless router to be able to use wifi. there are two ways to connect to the internet on the touch viva. 1st way is by the sim card and that costs you a lot of money!!! the other way is by a wlan router, you can access to the internet as long as you want is you have a flatrate. My good tipp: switch off the gprs connection, it will only cost you a lot of money. you will still be able to make phone calls. Ilost about 60$ (i mean it!) by trying to access to the internet by gprs.
SOURCE: My phone doesnt conect to my PC.
1. Make sure that the theme that you have downloaded is compatible with Nokia 5310.
2. Yes, there's a way to connect the phone to the PC without using the PC Suite. Follow the steps below:
* On your phone, go to Menu and then go to Settings.
* Go to Connectivity and then select 'USB data cable'
* Then connect your phone to the computer
NOTE: The computer should recognize the phone as Mass Storage Device. You may now save any file to your phone and it will be saved directly to the memory card.
Have a great day!
SOURCE: same problem
for xp you need ActiveSync 4.5 and for Vista WMDC6.1. also in connection under USB to PC uncheck Advanced conection.
