Question about Fuji FinePix S5200 / S5600 Digital Camera
Finepix s5600 doesn't turn on
I don't know how, but my camera doesn't turn on or go to play mode when i turn the lever in their position.
SOURCE: focus error
hi i need help with my focus errar
Posted on Jan 18, 2008
SOURCE: Camera only works in "play" mode
SAME
ROD FROM ESSEX
Posted on Feb 13, 2008
SOURCE: s56oo fuju finepix camera focus error
Hit the lens (smack it on you're leg); that seems to be the solution..........
But try cleaning the lens and the AF assistent first!!
Posted on Dec 13, 2008
  • 5 Answers
SOURCE: focus error
You will have to disassemble the unit. 2 screws on 1 side and 1 on the other and 2 on the bottom, pop the back off, being careful of the 2 ribbon cables attached to the rear and unock these cables and remove. 3 screws holding the top circuit board (remove the eye piece first and unplug the 2 cables attached to it) carefully unplug all cables attached to this top board and unscrew and remove (there is one on the bottom of the board that you must flip to unlatch. After you remove that board there is the power board... BE CAREFUL!!! The flash capacitor (the black tube looking unit on the bottom of this board) stores chrge and you WILL feel it if you touch the terminals... it they touch metal you will see fireworks so be careful. unplug the single red and black wire plug and unscrew the 3 screws here You do not have to remove the white plug with the 4 or 5 wires because you can just flip the board over out of the uni.. BE CAREFUL!!. unscrew the 2 silver screws securing the metal plate underneath and remove this plate. now remove the single screw left and pull out the lens assem. Here check 2 places... 1 is he zoom screw (it is behind the long silver panel) and also the focus screw (behind the shorter metal panel. Do one at a time. remove the screws from one of them and carefully lift off the motor plate. for he zoom line to metal ring on the screw into the groove of the lens (Shaped like a V) carefully screw the screws back in bu d ni tighten to tight, leave a LITTLE slack. (1/8 turn from tight). Now for the focus screw, remove the cover and align the ring to encase the top of the V The ring is shaped like < the lens is a > so just allow the rinng on the screw to "pinch" the top of the lens groove. secure like you did the other plate (dont forget to back out 1/8 of a turn) reassemble the opposite of disassembly and you are done... it look hard but it is actually pretty easy... any uestions email me at worldin1@gmail.com
Posted on Feb 21, 2009
  • 244 Answers
SOURCE: Focus error on Fuji Finepix S5600
See my solution or email for help
Posted on Mar 10, 2009
Finepix S5600 camera is not recognised by my
Solve your problem by getting a separate card reader.
Jun 30, 2010 | Fuji FinePix S5200 / S5600 Digital Camera
My camera will also show pics that I have already taken so I know the screen is still good but won't go into camera mode. I changed the batteries, even the card and still have the problem. I have been...
If it won't go into camera mode then maybe the micro switch underneath the swtich is damaged. It's on a small pcb with 2 micro switches for either of the 2 functions. play back and camera
Jan 18, 2010 | Fuji FinePix S5200 / S5600 Digital Camera
I have a Fuji Finepix S5600 and would like to know if you can change the lenses on it or not. Just don't want to break it trying. Thanks
The S5600 uses a non interchangeable lens. It's a fixed lens camera.
You can how ever purchase filters or adapter rings etc to attach to the front of the lens.
Oct 04, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Lcd screen
EBAY has lots of camera parts stores. Just search fujifilm s5600 lcd screen , or parts camera.
Aug 26, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Finepix S5600 screen flashes
It sound as though you may have liquid damage in your camera causing electrical shorts or bad electrical contacts. Camera will have to be opened.
Jul 02, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Can't get it to picture mode
This camera's playback function works through the lever around the shutter release button. Change it to picture taking mode (the red camera icon).
Feb 14, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Lens for a finepix s5600
I need to know if my wide angle lens will fit other camera brands
Nov 18, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
CAMERA WILL NOT TURN ON
Try new good quality batteries.
i experienced this issue last night. Even after replacing the batteries i had the same problem though the batteries were from a very cheap pack & i'd had them a while. The camera worked fine once i'd recharged my normal batteries. I'm no expert but I expect switching the camera on must use much more power then review mode causing the camera to switch off before it has time to tell you your batteries are low.
Hope this solves your problem!
Sep 03, 2007 | Fuji FinePix S5200 / S5600 Digital Camera
Fuji FinePix S5200 / S5600 Digital Camera Logo
66 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
