Question about RTO 110cc Basic Manual ATV # ATD-125C
No firing on 90 cc atv qinqgi - RTO 110cc Basic Manual ATV # ATD-125C
My hi bird 250 cc ATV getting fire and gas but want start whats wrong with it.
maybe not enough compression or timing is off airfilter clogged or needs valve adjustment
Feb 04, 2015 | ATVs
Does the spark start at the mag on a 2003 90cc Honda ATV?
Its time for a professional, take your Honda to the HONDA dealer for assistance
Sep 01, 2014 | Cycling
Atv wont start has fire gas in cylinder wasrunning fine quite on it own has only 1500kms on bike
you have a carb issue. turn the set screw all the way in and back it out 1 1/4 turns. this should work for you. if you need to adjust it... do it in 1/4 turn increments.
Dec 22, 2013 | Quad 47 cc / 49 cc Pocket Mini Bike...
No fire from spark plug
either spark plug is bad or coil is bad also check clearance between fly wheel and coil
Oct 08, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
My 49cc wont fire over
My 49cc 2 stroke pull start scooter wont turn over
Aug 19, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
My quad wont fire
The valve may be off a bit get the valve specs and check it usually the intake valve that causes that you will have compression but it it will stay open just enough that it won't start
Apr 17, 2010 | RTO 200cc Full Size Four Wheeler ATV
Hi i have a artic cat atv 90 cc everytime i open
replace the spark plug and clean the air filter
Jan 30, 2010 | Sport & Outdoor - Others
Koplin 90 cc atv will not fire
First check tank breather is not blocked and fuel is on allso kill switch is off, then give it a good try. Remove the spark plug quickly ,If dry no petrol getting to cylinder ,strip clean carb,and put spark plug end onto cylinder head hold with plyers and try to start if no spark ,check condition of your battery and all earth connections.if still no luck call back.
Dec 17, 2009 | Lego Creator Revvin' Riders, Motorcycles...
RTO 110cc Basic Manual ATV  # ATD-125C Logo
37 people viewed this question
Top RTO Cycling Experts
John Egan
John Egan
Are you a RTO Cycling Expert? Answer questions, earn points and help others
