Question about Razor E100 Electric Scooter
No power When the scooter has been charged it goes but has no power
    Habit-Forming:
    Scholar:
  • 89 Answers
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
The control module is simple and can be replaced with only a 24 volt relay without the kick start feature or Brake. If you want the brake then you can use two 24 volt relays still no Kick Start.
For those of you who know electrical, below is circuits I developed to replace the controller. This diagram will also give you a better understanding on the Razor circuit.
NOTE : This is not a schematic diagram of the Razor E100 Control Module. I designed this circuit. for my Great Nephew's Scooter.
1. The Brake is a normally closed switch that opens when you squeeze the Brake handle.
2. The throttle is two normally open switches that close when you turn the throttle.
3. The Kick Start circuit is described in the Diagram below.
4. The resistors values may need to be tweaked for best performance.
Posted on Jul 28, 2014
How do I charge a moxie power scooter??
  • Turn the scooter's power switch to the OFF position.
  • Connect the charger's plug to the charging port on the scooter.
  • Plug the charger's power cable into a power outlet.
  • When the charger's LED red/orange light is on, the battery is charging. Optimal charging time is 6 to 8 hours, or up to 10 hours to achieve a complete charge. The scooter manual will have the exact charging
  • Times recommended for your scooter.
  • Stop charging when the LED light is completely green.
  • Disconnect charger from the scooter, then from the power outlet.
  • Run your scooter before riding it to verify the battery charge.
Feb 02, 2016 | Health & Beauty
Scooter battery meter dips
After 10 to 12 hour charge, unplug the charger, make sure the freewheel lever is in drive mode, you will know if it is because you have a hard time trying to push the scooter. Turn it on and try to drive if the meter goes to above the middle on the meter, it should ok, but, if the needle goes to red right away time for new batteries. Will need more info to go any farther. or you could go to www.strege.com/BlueDoc it is an app to help trouble shoot scooter problems.
May 14, 2014 | Electric Mobility 4 Wheel Power Electric...
Razor e200 power scooter goes very slow
the battery is probably dying out and you need a new one, or need to charge
Jun 23, 2012 | Razor E200 Electric Scooter Green
Mobility scooter goes slow
driving range of 20 to 38 miles per charge depending on unit. Check out our E Wheels electric power bikes, and mopeds that goes 20 plus mph. Want a fast outdoor mobility scooter, check out the EW - 36 that goes 15 mph. This deluxe outdoor power scooter has a driving range of about 25 miles per charge, depending on the terrain and the weight of the user.
Jan 21, 2012 | Health & Beauty
Gogo elitescooter lights indicate battery fully charged but scooter will not go
Make sure the free-wheel lever is engaged and the charger is unplugged from the scooter before you try to turn the scooter on. If the battery gauge goes up when you turn the scooter on and there are no beeping sounds you should be good to go.If the battery gauge drops to the red when you try to accelerate slowly, your batteries are shot. (Typical replacement in 24-48 months).If there is any beeping when the key is first turned on then there is a problem and the number of beeps indicates the problem found by the computer during the POST. [Power On Self Test]
Dec 26, 2011 | Electric Mobility Mobility Electric Power...
Spare Batteries for Pride Revo Scooter
You can't do it with a car battery charger as it takes a 24 volt charger and it has to be designed to charge the sealed batteries that go in scooters and power chairs or you will blow the batteries up!
Order another battery case and swap the battery packs on the scooter with the spare pack once a week. Sealed batteries do not store well and need to be charged fully at least once a month to ensure long life. These batteries aren't cheap, and it's worth keeping them in shape.
Aug 13, 2009 | MK Battery U-1 Sealed Gel Pair Power...
I have a Rascal 600f scooter that seems 2 work okay except both the power meter and charging meter indicates energy loss wrong.As the power is used the meter very very slowly goes down from full charge...
It is pretty common for the meters on the charger to either not work at all, or give an inaccurate reading. They get bounced and dropped, and they aren't that well built to begin with. Basically, just ignore the charger as long as you are getting a full charge out of it, and getting good distance with each charge.
Jul 11, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Pride victory mobility scooter
A fully charged battery should be over 12 volts. You may need to change your batteries.
Nov 07, 2008 | Pride New Mobility Legend 4 Wheel Scooter
Razor E100 Electric Scooter Logo
231 people viewed this question
Top Razor Toys Experts
Clif Roberts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
Are you a Razor Toy Expert? Answer questions, earn points and help others
